Question about Whirlpool Washing Machines
I have a sttackable washer and dryer. The softner dispenser keeps on flying off and won't stay on the spinner. Help?
  • 868 Answers
If the spinner is not worn ,then replace the dispenser.
Posted on Aug 25, 2008
LG washer detergent dispenser won't open The dryer is on top of washer
if you are patient, if you are lucky, you can take a very flexible tool like a frosting spatula and work it into the right hand side of the dispenser drawer and work it back and forth while moving the drawer in and out from its stuck position and maybe get it over the top of the softner tray and free the drawer. the top of the softner is popped up a bit and is catching on the top of the dispenser's enclosure top. about an inch or so in from the right. takes luck, skill and most of all patience. not easy but maybe less work than removing the dryer and going into the top of the washer. (if you get it out, then thoroughly clean everything up, then file down the front of the softner cup so it will not happen again--or throw away the softner cup and stop using softner) GOOD LUCK
Oct 20, 2016 | LG Washing Machines
Whirlpool washer model wfw9150ww01 won't dispense bleach
My guess is that the valve that pushes water into the bleach compartment has stopped working. It should be accessable from the top. I have some maytags similar to your machine that i have to remove the front panel to remove a couple screws to lift the top like a car hood. Not sure about your machine though.
Jan 12, 2013 | Washing Machines
Why do I have water in the fabric softner dispenser after the cycle is completed.
because the way the washer adds the softener is to spray water thru the dispenser. If your washer is not 100% level a small amt of water will stay in the dispenser
Dec 30, 2010 | Frigidaire Affinity ATF7000E Front Load...
The fabric softner release has stopped working
Most likely the fabric soft dispenser is clogged . this happens when you wash alot in cold water the left over fabric softner get very pasty and can clog it up. You can try filling the dispenser with hot water and run a cycle with hot water this should unclog the dispenser .
Nov 26, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
After washer is done the fabric softner dispenser is filled with water
this can be normal in some models it can be caused by dry softner in dispenser
Sep 27, 2009 | Kenmore HE5
Whirlpool Duet frontloader washer's dispenser stays filled
I had a similar problem, but mine was with the detergent side. I removed the top of the washer and had to clean the dial that advances to let the cyle of dispensing continue. It worked, but now the machine shakes and I am told is 'unbalanced'
Jan 16, 2009 | Whirlpool LAB2700ML Pedestal Drawer for...
Fabric Softner not leaving dispenser
Run some vinger through it. Fabric Softner leaves a filmy residue that can clog it up.
Jan 11, 2009 | LG DLE5932W Electric Dryer
Fabric softner dispenser
Start by cleaning the dispener, pull the dispenser out the owner manual should show you how to do this.
Take the cover off and clean and rinse the dispenser out, reassemble.
If this doesnt help let me know, there may be other problems.
May 04, 2008 | Speed Queen ATS90AWN Front Load Washer
"downy ball" is designed to open at the end of first spin that is the way to go without stopping machine. works very well and costs just a few dollars
Feb 07, 2008 | Maytag Neptune MAH5500B Front Load Washer
Washing Machines Logo
Dan Webster
Dan Webster
Sal De
