Question about Apple 15" PowerBook G4 Aluminum 1.67 GHz LCD Display (p/n 1002587) (661-3749 1002587) Mac Notebook
Water damage What can I do if I spilled water on my laptop? water in screen
    Novelist:
    Champion:
  • 382 Answers
Unplug it, take the battery out and turn it on its side, like an open book and resist touching it for 2 days. If it happens to come up after, get a latex keyboard condom and count your blessings, if not, hit me back.
Posted on Sep 01, 2008
Spilled some water on my phone and now my screen wont turn on. everything else works fine but the screen wont turn on???
Like all water damage on electronics, it is critical to do the following right away: (1).Remove the battery to slow down the corrosion process. (2). Have someone remove the case to expose the circuit board. (3). Assess the damage. It's easy to see where the water/moisture is as you should notice a whitish/greenish deposit at the spill site.
If it's minor, you might be able to clean the damage and resume operation. Good luck, hope this helps.
Sep 23, 2015 | AT&T GoPhone ZTE Maven 4G with 2GB Memory...
Gray screen
The liquid has damaged the screen driver chips on the rear of the screen. Replace the screen.
Jan 29, 2014 | Toshiba Qosmio Computers & Internet
Water fall into my laptop, whenever i switched it on nothing appear on the screen
It probably requires replacing as water will damage electronics beyond repair.
Dec 15, 2013 | HP ProBook 4510s FM849UT Notebook
I have Macbook pro and spill water.It is now 6days and dying out.Very hard to remove battery as Macbook has 6-8 screws to remove batteryMac book is only year old.Is there any easy way to start without
Was it just water or was there any salt or sugar in the liquid water? Did you set the Macbook vertical ( so the water would not sit on the motherboard?
BTW: The first thing you should have done after water spillage was to remove power and the battery!
http://www.wikihow.com/Save-a-Laptop-from-Liquid-Damage
Feb 03, 2013 | Apple MacBook Pro Notebook
How to drain water spill on laptop's lcd screen
Set up a thick towel on the table, open laptop and carefully lay LCD face down so more water can drain, don't forget to remove main battery and unplug the adapter. I strongly recommend having a computer repair shop strip it down for water damage and cleanup.
Jul 20, 2012 | ASUS Eee PC 1000H Laptop
My laptop is only a month and a half old. It got accidentally wet and it is turning on but the screen does not come on. It is an Acer Aspire 5250. I believe the computer is aired out and dry now.
In most cases, the problem is going to require significant dis-assembly to dry out the computer and get it working again. Depending on the liquid involved the damage can be minimal or severe! If it was just water with nothing else in it, then getting it dried out within a few hours will likely have no affect on it, provided of course it did not sustain damage from being shorted out. unplugging it and removing the battery IMMEDIATELY is the best choice to prevent significant damage. Since the liquid can get into areas that simply are not going to dry out until evaporation occurs, it is best to not delay and remove as many access covers as possible and try blow drying it. if the water got into the screen, this is not going to work and the screen will have to be dismantled.
If the liquid involved ANYTHING other than water (soda, coffee, sugary, etc) the damage that can result from continued exposure to these substances WILL do permanent damage if not removed within a few hours of the initial spill.
You will be surprised how many little spaces that water will go that simply will not dry out until exposed.
The last laptop I worked on had coffee spilled on the keyboard. The entire main board, processor and several tiny socket connections were saturated and letting it air dry would not have helped.
I suggest taking it to a professional for service and repair. I also recommend ANYONE buying a laptop, get damage warranty coverage just for reasons like this, its definitely well worth the price.
You can expect the repair on this to be easily more than the cost of the damage warranty.
Jul 19, 2011 | Acer Computers & Internet
I can't switch on the laptop because water spilled
Flip it upside down and remove the main battery, leave in that position to drain water out as much as possible. Take it to a computer technician quickly as possible, chances are it will need a new keyboard, also he will need to check the motherboard under the keyboard for water damage.
Jun 29, 2011 | Acer Computers & Internet
Will not power on, spilled a tablespoon of water on keyboard
liquid spilled on laptop is bad news, even thou it might be just a tablespoon, on the right spot might render your laptop useless, its recommended that you Do Not turn on the laptop, remove batt, allow it to dry for a week, if the laptop does not turn on then its possible that internal components might be affected/damaged. if the system is still in warranty and covers accidental water damage, call your manufacturer, if not, bring it to your local computer shop for repair...
Hope it helps!
Mar 05, 2010 | Computers & Internet
Water spill on my AOC2216Vw LCD Monitor
Hey man, thanks for coming to me. Um yea, massaging may help but too hard will do damage since it is LCD is Liquid Crystal Display and it is fragile and easy to damage. The water should clear up in a few months, if not i would look at replacing it which can be costly. Here is a link to fix your unstuck pixels
http://www.wikihow.com/Fix-a-Stuck-Pixel-on-an-LCD-Monitor]
Now im not liking that bit about how you mentioned was spreading so leave it for about two days, give the therapy for the screen a try and let me know if the laptop screen is healing. For the moment if you have one i recommend you hook up a VGA Monitor, old school stuff if you can and give the LCD a rest. I will post as a solution but comment back and i will keep helping you as much as you need it.
Dec 21, 2008 | Computers & Internet
Water spill on laptop
Shut it down, unplug the battery. The water is shorting out some of the circuits and leaving it on may cause more damage. Put it in a dry environment for a couple of days, you can also try a hair dryer (be careful not to get it too hot) to speed the drying process but the water is inside so it will be hard dry. A small room with a dehumidifier going would be great. With time it will evaporate and if you are lucky none of the components will be damaged.
Oct 10, 2008 | IBM ThinkPad T41 Notebook
Apple 15" PowerBook G4 Aluminum 1.67 GHz LCD Display (p/n 1002587) (661-3749 1002587) Mac Notebook Logo
251 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
