Question about LG DLE2514 Electric Dryer
Pleae help I unpluged the cord and fliped the breaker too but still the "Check Filter" light keep flishing. The dryer turns on but it doe NOT blow any hot air? Is there any other thing i can try. PLEASE HELP!!!!!
  • momof4hlf Sep 24, 2008
    Check filter light keeps flashing what do I do
  • Anonymous Jan 08, 2009
    same
  • 979 Answers
You may have a bad control board that is giving it a bad signal. It will not heat until that is fixed. Call the manufacturer and tell them what is going on and they may be able to shed some light on it.
Posted on Feb 07, 2009
Dryer light bulb burned out
follow this steps and fix it. God bless you
Light Socket
The light socket can get corroded or a wire connection can come loose. You will need to remove the front panel to access the housing on most dryers.
Door Switch
If your dryer has an interior light, it probably uses a standard 40-watt appliance bulb, but check your owner's manual to be sure. If the bulb is good but the light won't come on, check the door switch, which serves two functions: When the door is closed, it turns off the light and allows the dryer to start. When the door is open, it turns on the light and prevents the dryer from starting. To check the door switch check for continuity. You should have some when the door is closed and none when the door is opened.If not replace the door switch by removing the front panel.
It blows fuses or trips the circuit breaker
Electric dryers use 220 volts or two power lines of 110 volts each. Some components in the dryer need only 110 volts; the heating element requires 220 volts. So it's possible for one part of the dryer to be fine and another part to have a short circuit. Short circuits can be caused by the heating element, the main power cord, or any other part of the internal wiring. Loose connections on the power cord cause failures and or fires. This can be checked with the dryer unplugged and removing the service cover and visually check for burning and mechanically check for tightness.
If the circuit breaker trips or the fuse blows when the dryer is unplugged, it's likely the problem is with the house wiring, fuse box, or circuit box. Contact a qualified electrician.
Jul 09, 2013 | GE Profile Harmony DPGT750EC Electric...
Clean Lint Filter Light Keeps Dryer from starting
Evidently the fuse blew for some reason.
Keep the dryer unplugged from power for one hour or so. If it still does start, you will have to take apart the dryer, check the fuse, check the thermal fuse, and test the wirings inside.
If you need to call arepairman use the number listed on the owner manual.
Oct 06, 2008 | Frigidaire FGQ1442ES Gas Dryer
Does not heat I have cleared the vents and filter
if your dryer doesn't heat, check these:----
Power from the house Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected. Heating element Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable. Thermal fuse On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.) Wiring A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya
Jan 11, 2010 | Kenmore Elite Oasis 6808 Electric Dryer
No heat coming from dryer
Double check the circuit breaker for the dryer (Electric Neptune). Turn it off, then turn it back on. Its possible that the breaker may have tripped for some reason, but wasn't able to trip all the way.
Does the interior of the dryer get warm at all? You could have a 1 of multiple heating elements that has shorted. If no heat at all, the likely a heating element has opened up. Unplug dryer from wall (turn off circuit breaker first!). Use a ohm meter to measure and check continuity of the heating elements.
There may also be a sail switch in the air path of the dryer. The purpose of the sail switch is to keep the elements turned off until there is enough air blowing through the dryer. This helps prevent fires, as well as shrunken denim.
Jan 04, 2010 | Maytag Neptune MCE8000AY Electric Dryer
2year old ge dryer trips breaker when it's turned on, but sometimes will run a complete cycle before it shuts off.
HELLO THERE
Electric dryers require the use of a 220 volt line. The dryer heating elements run off of 220 volts. An excessive draw of electricity, or a short in the wiring can blow a fuse or trip a breaker. This happens to protect sensitive components from damage, and to help prevent fires. Every other dryer component operates off of 110 volts, the timer, motor, etc. Usually when a fuse blows or a circuit trips, it's because there's to much draw on the power line.
It is very possible for one part of your dryer to work fine, and yet another to have a problem, such as a short circuit. A short circuit may be caused by the heating element, internal wiring, or the main power cord.
To troubleshoot this problem, unplug the dryer and check to see if the circuit breaker or fuse remains on when the dryer is unplugged. If they stay on, it's more than likely the problem is somewhere in the dryer.
If your fuse blows, or the circuit breaker trips when the dryer is unplugged, it's likely the problem is with the circuit breaker, fuse box, or house wiring; contact a professional electrician.
OK I hope this is very helpful for you
Best regards Michael
Dec 01, 2009 | GE DBSR453EBWW Electric Dryer
Dryer won't start when i push the button,checked breaker,removed back,i believe there is power to switch.what di i need to check for?
If your model number is correct, all the heating circuits on your dryer are easily accessible from the back of the dryer. All you have to do is unplug the dyer and remove the back panel. Look for the Thermal Fuse. This will be a small plastic looking component with two wires attached to it. Its mounted on the blower fan housing on the left hand side of the dryer (as facing from the rear). Unplug the wires from the Thermal Fuse and take a resistance reading across the terminals. If good, it will read 0 ohms. If bad, you must replace it.
This component will blow in an overheat/over-current condition and must be replaced. Usually when this component fails, it fails for a reason. Check your blower fan housing for any clogs or obstructions that may be causing the dryer to run hot.
For clarification, refer to appliancepartspros.com for exploded view daigrams of your dryer. Just type in your model number and look under Section 3 for item 19 (part number AP3132867).
Something else to consider:
1. Does the dryer have multiple breakers? An electric dryer runs on 220VAC. Some home use two 110VAC breakers instead of one 220 breaker. Double check your power distribution and make sure you have the breaker(s) set properly.
2. Have you checked the voltage at the wall receptacle? Unplug the dryer and take a voltage reading across the two hot (left and right slots) terminals. If good, you should read 220-240VAC.
3. Have you verified the power cord is good? You can check the power cord by leaving the dryer unplugged and remove the back panel where the power cord is installed on the back of the dryer. This is called the terminal block. You can either perform continuity checks between the prongs on the cord to the terminals at the terminal block, or you can plug the cord back in and take a voltage reading across the RED and BLACK wires at the terminal block.
If good, you should read the same 220-240VAC that you read at the wall receptacle.
If continuity is good you will read 0 ohms resistance from the end of the power cord to the terminal block.
4. Have you verified the door switch? When you open the door is the drum light on? With the dryer plugged in, you should be able to open the dryer door and see the light on insode the drum. Toggling the door switch with your finger, this light should go out if the switch is making contact. If the switch is defective, the dryer will not run.
I hope I've given you enough items to consider. If you have any questions, please let me know. I hope you find this information helpful.
Jul 30, 2009 | Whirlpool LER4634J Electric Dryer
Whirlpool dryer power but won't run
A thermostat will not keep a dryer from running, but a broken belt will. If the model number you have this listed under is correct, you can access the dryer interior by lifting the lint screen door on top of the dryer and removing the two screws. With the screws removed, the dryer top will lift up. The belt should easily be seen wrapped around the dryer drum. If you pull on it, the belt should not have any play in it. If the belt is broken, it needs to be replaced. If the belt is loose, it probably has come off the belt tension idler pulley and needs to be reinstalled. Another common problem is a blown Thermal Fuse. All the heating circuits this model dryer are easily accessible from the back of the dryer. All you have to do is unplug the dyer and remove the back panel. Look for the Thermal Fuse. This will be a small plastic looking component with two wires attached to it. Its mounted on the blower fan housing on the left hand side of the dryer (as facing from the rear). Unplug the wires from the Thermal Fuse and take a resistance reading across the terminals. If good, it will read 0 ohms. If bad, you must replace it.
For clarification, refer to appliancepartspros.com for exploded view daigrams of your dryer. Just type in your model number and look under Section 3. The Thermal Fuse is listed as item 7.
Something other things to consider:
If you have any questions, please let me know. I hope you find this information helpful. NOTE: The start switch popping back out when you open the door, I would assume to be normal. The dryer is supposed to shut off when the door opens.
Jul 30, 2009 | Whirlpool LEQ9858L Electric Dryer
Blowing breaker
hi. I can help you.
Electric dryers use 220 volts or two power lines of 110 volts each. Some components in the dryer need only 110 volts; the heating element requires 220 volts. So it's possible for one part of the dryer to be fine and another part to have a short circuit. Short circuits can be caused by the heating element, the main power cord, or any other part of the internal wiring. To decide where the problem lies, unplug the dryer, then:
  • If the circuit breakers or fuses remain on and/or intact when the dryer is unplugged, it's likely the problem is with the dryer. Contact a qualified appliance repair technician.
  • If the circuit breaker trips or the fuse blows when the dryer is unplugged, it's likely the problem is with the house wiring, fuse box, or circuit box. Contact a qualified electrician.
Jun 22, 2009 | Kenmore 63942 Dryer
Dryer keeps stopping - check filter light on
For Sgt 48 - You are not reading the original message very well - The original help question didn't say they saw check filter at the beginning or end of a dry cycle they indicated that the dryer STOPS MID DRY and says check filter - this is not a friendly reminder, it is indicating something is wrong and the filter needs to be completely cleaned out (and past the filter down in the interior of the dryer) and if that does not work then you need to also check the dryer hose for kinks, lint build up, etc. Lastly, reset the dryer by unplugging it (or flipping the breaker) for a minute or so and hold down on the start/pause button for 8 seconds while it is unplugged (this will reset the error code for check filter, among other things).
May 13, 2008 | LG DLG2525S Electric Dryer
Dryer won't work, Check Filter light is on
I had exactly the same problem with my newish LG dryer. I deduced that the dryer's computer essentially needed to be rebooted. I pulled the plug for a minute or so, then plugged it back in. It works perfectly now.
Mar 11, 2007 | LG DLE2514 Electric Dryer
LG DLE2514 Electric Dryer Logo
119 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Richard Roth
Richard Roth
Are you a LG Dryer Expert? Answer questions, earn points and help others
