Question about Sony VAIO VGN-S460 Notebook
Noisy fan--sony vaio vgn-s460
Fanhas become noisy. How to I get it replaced
This isn't the best solution. Sony Vaio's VGN-S series are very infamous for grinding fan noises. One should see about oiling it or replacing (which is very expensive).
Posted on Sep 30, 2008
    Guru:
  • 257 Answers
Then if that is the problem to your pc then turn your pc upside down and dissassemled the screw at the back then your keyboard should be lift up slightly and if you can not do that on your own try to contact someone in that field to help you but just for you to tell the person that you know what is wrong w2ith the pc the person should try and check if there is anything too close to the fan that the fan is touching and if there is nothing the fan is touching and the noise continue then change the fan with a new one. bye any question again.
Posted on Sep 05, 2008
How to Boot Sony Vaio VGN-S460 Laptop without CD/DVD ROM and With bootable USB
If the BIOS does not have the USB as one of the boot options then you cannot boot up with an USB memory stick.
In this case you need to replace the CD/DVD drive with a new one.
Jan 17, 2013 | Sony VAIO CS VGN-CS220J/T Notebook
Sony vaio fan is making a grinding noise, how can i fix this?
The sony VGN-S460 seems to have an inherent problem with their cpu fans. It is apparent that the fan uses a ball bearing system which over time becomes worn and causes the grinding sound.
The only solution is to replace the entire fan assembly as they are inseparable.
Nov 15, 2009 | Sony VAIO VGN-S460 Notebook
I have the same problem for Sony VGN-S460 heatsink fan problem
I trust that you have purchased the entire fan assembly as they are inseparable from the heatsink. You must disassemble the entire laptop in order to remove the fan assembly. they are two screws that are below the motherboard that must be remove in order for the fan assembly to come apart.
If you cannot achieve this yourself, or lack confidence in your ability to rebuild the unit after, you can send the unit to us at www.cowetacomputerstore.com and we will accomplish the desired outcome. We have worked on this system resolving this very issue.
farewell
Oct 05, 2009 | Sony VAIO VGN-S460 Notebook
Sony vgn-s460: screen blinks, fan runs very loud
Possible clock timing of CPU is wrong. Is it two fan on this laptop? Maybe one is not functioning. Plus check your power supply if gives correct power!.. If none of this , it comes to the MB and possible a CAPS making problem. Need expert.
JMC
Aug 06, 2009 | Sony VAIO VGN-S460 Notebook
I need steps to replace Fan for my Sony VAIO VGN-S460
the fan is screwed together with the motherboard, the only way i figured is to separate it is completely unscrew the motherboard, cd drives.....then unscrew the fan from the bottom side of the motherboard....
i took the fan out just today, wantted to add some lubricating oil to it, but then can't manage to separate the blades & expose the centre
how much did the replacement fan cost? i am in canada, not even sure sony stores here have it.
Dec 25, 2008 | Sony VAIO VGN-S460 Notebook
Sony VGN-460 Memory & CPU Upgrade? Noisy Fan How do I replace it?
The Crucial website suggests you can put 1GB in each slot. http://www.crucial.com/uk/store/listparts.aspx?model=VAIO%20VGN-S460%20Series Sony might know which CPUs will work with this. Hopefully any Pentium-M with 533 FSB.
Sep 21, 2007 | Sony VAIO VGN-S460 Notebook
VAIO VGN-S460
check adapter output also may be problem with dc socket on laptop loose or somthing.
Apr 11, 2007 | Sony VAIO VGN-S460 Notebook
Sony VAIO VGN-S460 Notebook Logo
417 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
