Question about Samsung CLX-2160N All-In-One Printer
Samsung CLX-2160 All-in-One
I just replaced the toner for the first time in my new Samsung CLX-2160 All-in-One. I cannot get it to work, and get a "Toner Empty" error message. Rebooting, repositioning, etc does not help. The toner cartidge is a CLP-K300A but it looks a little different from the original that came with the unit. It has a little square metal contact where the original just has an empty spot. Should this be removed? Is this the right toner? Please help. Thanks.
  • javito Dec 09, 2008
    I replace the tonner with original one and still the toner empty message and the printer doesn´t work
  • Samsung Master
  • 4,338 Answers
That is the correct cartridge. It should look and work the same. Is this a Samsung cartridge or one from a third party, ie: Office Depot, OfficeMax?
Whenever you see metal on cartridges, that means it is a grounding point. I would take it back where you purchased it and have them compare it with another new one. Take your old one with you.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on Nov 22, 2008
Where is the waste toner container on a Samsung CLX 3300
Google search your manufacturer make and model and the word manual. If one is available, you can find it in the search results.
Mar 16, 2015 | Samsung CLX-3300 Multifunctional Laser...
Get rid of the error message "toner empty stop" after replacing the cartridge with a new Samsung cartridge?
After replacement with OEM cartridge it will never show Toner empty
however refil cartrdige will show the same , You need to replace the chip to remove the empty indication
Oct 01, 2014 | Samsung Office Equipment & Supplies
My Samsung CLX-3175 printer will not print - the message is replace/install toner waste bin. I have emptied the waste bin of all the ink and replaced it and still the message will not go. I have a stack...
open the cover and now remove the waist toner container (you say it is empty) check the conection to the drum unit sometimes if the waist toner is verry full there is a pille of toner closing this connection, now clean it and all the sorounding from the toner and mount the waist container back in his possition, close the front cover and try, it should work now.
Apr 27, 2011 | Samsung CLX-3175FN Color Laser All-in-One...
CLX 2160 Message: Deve Home Sensor Error. What can i do to correct it.
There could be two problems
A minor error occurs and the machine is waiting an error to be cleared. Check the display message, and solve the problem referring to Understanding display messages, see page 11.3.The toner cartridge is low. Order a new toner cartridge; see Ordering supplies on page 12.1. You can temporarily improve print quality by redistributing the toner. See page 10.4.
For referring this page numbers, please download the manual from this link.
The error message, which you have told me, not in the error message list. I think there is an internal failure for the printer. It is always recommend servicing your printer with authorized service centers. If the error message is not in the error list, owner cannot repair but, technician can repair the printer. I hope this information is useful for you. Thank you.
Apr 19, 2011 | Samsung CLX-2160N All-In-One Printer
I have a Samsung CLX-2160 print. It says "transfer
Try this steps it might help,
1. detach the paper tray and push it back correctly.
2. open the front door and remove toner cartridges, on left inner side u may see a light sensor which detects the toner cartridges.. simply clean this section by a small cotton bud. and in the left side of toner unit there is a sensor door, behind that door there is also a light sensor bulb, which needs to be cleaned by a cotton bud.
Please rate this solution if found useful.
Jan 17, 2011 | Samsung CLX-2160N All-In-One Printer
My CLX-2160 keeps warning that the yellow toner is low. I have put in a new one, but it still gives the same error message. What could be the cause of this ?
is the toner a refilled toner cartridge..if it is try to change the chip around and make sure that the chip seet properly in the grooves.if it is a new cartridge go bak and exchange it.
Oct 19, 2010 | Samsung CLX-2160N All-In-One Printer
Samsung clx-2160 says waste tank is full. What must I do and where is the waste tank?
If you open the front of the printer then you will find a waste tank in the left side - its gray. Take it out and empty it, and put the tank back in place.
This works for Samsung CLX-2160
Jan 31, 2010 | Samsung CLX-2160N All-In-One Printer
I have a samsung clx-3160fn printer. All toners are ok, espcecially the black one - BUT when I print black&white doc, it is comign out really faded - as if the black toner is low. BUT it is not!! ...
Go to printer properties and check whether you have selected print in grey mode and also check whether you have selected the economic mode. Rectify the same will solve your problem.
Revert back for more assistance.
Jan 31, 2010 | Samsung CLX 3160fn All-In-One Printer
Printer is a Samsung CLX 3175FN. It says the
To run a quick check on your black toner, insert your old black toner back to the printer.
press on the menu button -> system -> report-> supplier info-> print. and same for your new toner, if it show u both the old n new black toner are under the same serial number. the new toner might be faulty. Invalid toner detected.
get the new toner with the box packing back to the shop for replacement.
Oct 02, 2009 | Samsung CLX-3175FN Color Laser All-in-One...
Replace waste toner container message
I have a CLX-2160N and have just emptied my own waste toner container. (Disclaimer: not sure how toxic or environmentally friendly this is).
Emptied carefully and thoroughly (fine dust). Immersed in bowl of warm soapy water, and vigorous shaking to get nice and clean.
Shook all water out well, and dried off as much as possible. Reinstalled. Turned printer back on. Hey presto - seems happy.
Mar 04, 2009 | Samsung CLX 3160fn All-In-One Printer
Samsung CLX-2160N All-In-One Printer Logo
336 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
