Question about Altec Lansing IM7 (WMM137039)
IM7 docking cradle
The docking cradle on the iM7 was pulled open instead of being pushed to open. The cradle will not close now. The unit still plays fine but you have to tilt the unit to read the i-pod.
  • 5 more comments
  • Anonymous Sep 04, 2008
    ditto, exact, same. looking for solution, parts, etc
  • hansmeu Oct 10, 2008
    same problem
  • Anonymous Oct 11, 2008
    Same thing here. Does anyone know where I can get it repaired?
  • POfart Nov 12, 2008
    Picked up unit by the cradle by accident and now it will not latch. A-L says they have no repair facitlities. Who does?
  • RickGreens44 Nov 24, 2008
    mthomson79,
    Thank you so much. I will check it out and let you know how it goes.
    -Out for now-
    rickgreens44
  • kmartin683 Dec 12, 2008
    mthomson79 - I've got the same issue with my IM7 - I love your clever solution - can you tell me what a desk-top computer case is?
  • Dodgy Geezah
    Dodgy Geezah Mar 15, 2017
    Hmmmmm. Need a new plastic door catch for my beloved IM7. I live in the UK. Searching around, it looks as if the company now providing these is called Digi-Key electronics, a US company. I've just been in touch with them and requested a sample but they tell me it is a non-stock item and I need to order 500 of them at the princely sum of 375 USD!! Lol. Don't think so. As it happens, the dock itself still works fine even if the door won't close but I'd like to fix it if it's possible. Anyone think of a way round this? What pc did you pinch the latch from?
    Problem Solver:
  • 5 Answers
I also had my latch broken. I called the latch manufacturer and they sent me a "sample" pack of latches since you can only buy in large quantities; so I now have ten of them. I love my IM7 and will be happy to share my latches if anyone needs one.
Posted on Jul 15, 2011
  • 4 more comments
  • ckasper1 Sep 11, 2011
    Hi, I have the same problem with the latch. If you still have any extra could you contact me at christopher.kasper@gmail.com. Thanks much.
  • kiwimc Sep 18, 2011
    Hi, I too have the same problem - do you have a spare latch left - I may be contacted at scott.mcfarlane@nokia.com. Cheers Scott
  • Tony Rozzi
    Tony Rozzi Sep 26, 2011
    Any latches still available? Our IM7 is suffering the same problem...trozzi@gmail.com
  • Douglas Oct 02, 2011
    Same thing with me. I would also greatly appreciate it if you had a latch you could part with. You can contact me at djms28@yahoo.com. Thanks!!
  • bernard ainoje Nov 13, 2011
    my iM7 is now suffering same problem. Please do you still have any of these latches left? Also how were you able to disassemble and fix it? Thanks to please contact me through: bainoje@slb.com. I'd appreciate any assistance because I really love this unit.
  • Don Wong
    Don Wong Mar 22, 2012
    Hi, just wondering if someone could help me with this problem as well, or with a spare latch. The solution using a clasp from a computer case sounds like it could work also. Has anyone else tried it with success? Any help would be much appreciated! Thanks. - Don - thatbloke@gmail.com
After much searching on the internet for a replacement clip/clasp part, and not finding anything, I realized that I had an old desk-top computer case from Fry's Electronics that has two plastic doors on the front of it that use the same clasp part to hold them shut. I was able to remove the broken clasp from the IM-7 using a small pair of pliers and a very small flat-head screwdriver, and pop the used part in from the computer case, and it works perfectly. It's literally the same part. Not only that, but I have one more clasp to use should this one break as well. Hope this helps. -- Mike
mthomson79@gmail.com
Posted on Nov 24, 2008
  • Natalie
    Natalie Oct 08, 2011
    Do you know how to pull out the dock cradle? Better yet how can I dissassemble the im7 properly? I've tried the obvious screws already and can't seem to figure it ougt., Thank you.
I've found a solution. The latch is the black piece of plastic behind the door with a claw sticking out. Most likely you have broken the catch inside this part so it needs replacing but don't worry, it's relatively easy to do.
1. First, email the manufacturer and and ask for a sample latch to be sent out to you. After a bit of research I finally found them. In the UK they make them in white so I ordered one of those as I think it looks better (part #DL1WH): http://www.richco-inc.com/component/jumi/search-parts.html?searchinit=true&searchtype=rohs&interest=DL-1&Submit3=Submit
2. Get a pair of thin pliers and carefully pull out the old latch. To do this pull on on any part of the outer rim. I used the lower edge. Don't worry of you damage it. You'll be throwing it away anyway. Just don't damage any of your speakers.
3. Slide the new latch into position and push into place.
4. That's it. All fixed!
Posted on Aug 30, 2012
In the US Richco, Inc. http://www.richco-inc.com/
Door Latch and Striker in the online catalogue (DL/DLS)
The latch is DL-1X on page 63 as of 9/11/2012
Thank you all for the help.
PS. at the bottom of the page on the Richco online catalogue it says,
"For free samples visit www.richco-inc.com"
I'll post again if they come through with a 10 pack of "samples" like they did for bourge and Don Wong.
Posted on Sep 11, 2012
  • 2 more comments
  • Fultronics Sep 27, 2012
    Follow-Up: Richco, Inc. comes through !!
    Richco (US) initially said there was a 4 week lead time on the part that I would be sent a sample when they became available. 2 weeks and 2 days later I've received a dozen DL-1X samples. Constact me if you need 1. I'll try **** Wong's needle nose plier technique and let you know how it goes. Thanks !
  • Fultronics Sep 28, 2012
    For some reason I can't post my email, but it's my username at live dot com
    I uses a pair of needle nose pliers to replace the latch last night. I was able to pull the old latch by maneuvering the pliers over the top of the opened dock door. It came in pieces, but eventually pulled away cleanly. As Don W. stated, the rim or collar to the old latch assembly was out far enough for me to grab. I pusehd a new latch into place with my relatively big fingers. There was an audible "click" as it went into its final position. I am so psyched to have a fully functional Ipod boom box again. Gratitude to bouge and Don Wong.
My IM7 docking cradle does not close. Someone lifted it from the docking cradle side and since then it is refusing to lock. Can you please help? The docking station is in India. If you need someone to...
Jan 22, 2011 | Altec Lansing inMotion iM7 (021986950806)...
Docking cradle doesn't close
Jan 22, 2011 | Altec Lansing IM7 (WMM137039)
My Oreck XL upright vacuum is blowing air instead of sucking air.
I've solved the problem! I had exactly the same problem, with dust being sucked up properly and then some blown out where the bag connects. The XL machine has a hinged plastic dock for the bag, which slides in the dock and you then close the hinge, there's a slight click and the velcro keeps it shut. The problem is that the plastic dock is not behind the ridge, but is in front. So when you start up the bag connection is pushed forward. So:
Undo zipper, open dock hinge and push it back squeezing the panel on the cloth bag. One side will go behind the ridge and you need to push it firmly, opening it a bit if you can. It will go behind that ridge all the way round. You'll see now that the dock is firmly in place, and can be hinged closed as you did before. But instead of the joint being loose, the bag is now tight.
Mine now works fine... thanks to fixya for encouraging me to fix it! I was close to binning the machine. But it sucks well, and I don't go for bagless... like my dirt packaged for disposal. And if you're a farmer, try farmideas.co.uk !!!!
Nov 25, 2010 | Oreck XL Deluxe U3700 Bagged Upright...
Blown bass speaker, hoping I can buy a replacement.
  1. Contact Altec Lansing.
  2. twist the Speaker frame anticlockwise to open then unscrew the speaker then look for a similar/something close to it(size and amps) one in the local audio shop.
  3. Get it to some audio shop for a recoil and or diaphram change.
May 16, 2010 | Altec Lansing inMotion iM7 (021986950806)...
Docking cradle in bose sounddock
Order Prod Number 041615 , Description: "279103-004 MOD ASSY CRADLE BLK SOUNDDOCK" from Bose spares. Costs £35. Undo the four philips screws in base, romove cover and replace whole cradle assembly. There is a circuit board attached to the main unit by a ribbon cable - you do not need to remove this cable you can instead can thread the circuit board through the old cradle. Then pull out the ribbon cable that connects the new assembly to the circuit board. Installation of new one n reverse. Protect from static by using wrist strap etc.
Sep 07, 2009 | Bose SoundDock digital music system...
My altec lansing im7 stopped working during class
I am having the same problem. Did you ever figure it out??
Jul 28, 2009 | Altec Lansing inMotion iM7 (021986950806)...
Altec lansing inmotion IM7 how to fix dock door?
I've found a solution. Most likely you have broken the catch inside this part so it needs replacing but don't worry, it's relatively easy to do. The latch is the black piece of plastic behind the door with a claw sticking out.
May 14, 2009 | Altec Lansing inMotion iM7 (021986950806)...
IM7 No power. Found out that the plug in switch
re your IM7 'plug in switch' which changes it from battery to 110-----where is that switch located, and how much of the unit did you have to disassemble to get to it? Thanks
Apr 21, 2009 | Altec Lansing inMotion iM7 (021986950806)...
In both my car cradle and my home dock I have to put a piece of paper behind the radio and try numerous positions with the paper to get my radio to charge or even play. It doesn't seem to charge at all in...
I posted on this myself looking for solutions, and then discovered the solution my self. The base pin connectors at the bottom of the receiver apparently become loose, and in order to make a good connection you need to push/pull the top of the receiver forward to achieve a connection. In the car cradel, I do this by jamming something between the receiver and cradel at the top to force and hold it forward). In the home base, I pull it forward at the top, and prop it that way with something heavy behind it. No one ever posted on how to take the unit apart and actually fix the loose connection.
Jan 30, 2009 | Delphi MyFi SA10113 XM Radio Receiver with...
Altec Lansing IM7 (WMM137039) Logo
1,053 people viewed this question
Top Altec Lansing Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Sharps s
Level 1 Expert
Are you an Altec Lansing Audio Player and Recorder Expert? Answer questions, earn points and help others
