Question about Sony Handycam DCR-TRV19 Mini DV Digital Camcorder
Cables what kind of cable or cables do i need to transfer video, sound and data from the dcr trv19 to the laptop? because i bought the usb that connects to the smaller usb and it doesnt work and my labtop doesnt not have a port for the 4 in 4in what cable should i get? thank you!
  • puertoarenas Aug 28, 2008
    is the ecm hgz1 zoom microphone compatible withe the sony dcr trv19? if not then what kind of mics will be compatible?
    Master:
  • 763 Answers
Try the firewire cable.
Posted on Aug 25, 2008
How to transfer videos from Sony DCR-TVR19 to computer
Use Firewire cable to connect and you will be able to import video's,
You can also use USB cable if you have PIXLA software however the picture quality is bad using USB.
Dec 03, 2010 | Sony Handycam DCR-TRV19 Mini DV Digital...
SONY CAMCORDER DCR-TRV19 DOESN'T WORK ON WINDOWS
The Windows 7 Operating System is not compatible with the USB Streaming feature of the Camcorder.
You can transfer the videos to the Windows 7 Computer using an i.LINK (Firewire) Cable.
You can use the Windows Movie Maker Software to transfer the videos from the Camcorder.
Please follow the steps mentioned in the below link to transfer the videos from the Camcorder to the Computer
http://www.kb.sony.com/selfservice/documentLink.do?externalId=C111893
Mar 10, 2010 | Sony Handycam DCR-TRV19 Mini DV Digital...
I need drivers for DCR TRV19. I have Vista on my laptop. thx
If you want to use the USB cable to connect the Camera to the Computer to transfer the video to the Computer then:
ThisCamcorder does not support USB streaming with the VISTA OperatingSystem. Use an i.LINK cable to transfer the video to the Computer. Thei.LINK port is also called IEEE 1394 or Firewire port. (An i.LINK is ablack D shaped connector with 4 or 6 pins. The type of cable to be usedwill depend on the i.LINK port of your Computer. The Sony Camcorderwill have the 4 pin i.LINK cable and if the computer has the 6 pini.LINK port, then you may have to use the 4 pin to 6 pin i.LINK Cable).
You can use any video capturing software like Windows Movie Maker to transfer the video from the Computer.
Refer this link for the instruction to transfer the video to the Computer using i.LINK cable.
NOTE:As the Camcorder does not support USB streaming with Vista, it is notrequired to use any Sony Device Driver to transfer the video to theComputer. You do not require any Drivers or Software from Sony totransfer the video from the Camcorder to the Computer using thei.LINK/Firewire interface.
Good Luck!!!!!!!!!!!!!!!!
Sep 14, 2009 | Sony Handycam DCR-TRV19 Mini DV Digital...
Transfer video to computer
I would like to know more about this USB adapter cable you bought. The camera has a IEEE-1394 (commonly refered to as Firewire or i-Link) connection that is inherently incompatible with USB. I don't see how one cable could do the trick unless it had some kind of conversion hardware built into it. Does it have a little box on the cable or is it just a straight cable?
CNet.com says that your laptop has a four pin Firewire port on it. I would go to BestBuy and tell them you need a Firewire cable with a four pin connector on both ends. If they give you a weird look tell them that is the small Firewire plug, not the big one. If they are still confused, get somebody else to help you. Then use that cable to plug your camera into your computer. Windows should recogonize it automatically. If it doesn't there may be a problem with you camera.
Jan 13, 2009 | Sony Handycam DCR-TRV103 Digital Camcorder
DCR-TRV19 compatible with an apple computer?
Hi heather719,
Unfortunately, the DCR-TRV19 is only compatible with windows - see the list of compatible versions at this address:
http://esupport.sony.com/US/perl/swu-list.pl?mdl=DCRTRV19
The only compatibility it has with Macs (and it doesn't always work) is to view still images via USB cable. In order to do this, you must manually install the required drivers from the software CD on your Mac. See the user's manual for instructions on how to do this:
http://www.docs.sony.com/release/DCRTRV19.pdf
The reason the video playback is not compatible with Macs is that you have to use an iLink cable, which is Sony's version of an IEEE 1394 ("Firewire") cable, and the iLink is only compatible with PCs (since that's what Sony makes).
If you want to get content from the tape in your camera onto a Mac, you must either:
1) Load it onto a PC, save it to a portable memory device, and transfer it, or...
2) Connect a MiniDV deck to your Mac, take the tape out of your camera, and put in the deck (like a VCR).
I'm sorry I can't give you better news - please let me know if I can be of any further assistance.
Kind regards,
H2H
Dec 05, 2008 | Sony Handycam DCR-TRV19 Mini DV Digital...
Transferring digital video from dcr-pc109 to gateway laptop with only usb ports
If u have sony handycam then u got data cable for transferring data.
Use it for that u donot need any type of drivers for using that.
Otherwise use memory card reader if it is.
Aug 23, 2008 | Sony Handycam DCR-PC109 Mini DV Digital...
Mini dv to apc
I'm working out the same problem! From the looks of things, it can be done with the i.LINK cable (which is optional, of course). I've got Vista on my new computer, which is incompatible with Sony's USB driver anyway, but it looks like I can transfer video successfully using an i.LINK cable and Microsoft® Windows Movie Maker (came with Vista). I just need to find the cable I need, as it's "optional" and didn't come with my camcorder. BTW, here's where I found my info: http://www.kb.sony.com/selfservice/documentLink.do?externalId=C111893
Apr 23, 2008 | Sony Handycam DCR-TRV19 Mini DV Digital...
Cannot transfer my video data to computer?
Go to camera menu and enable USB Stream. problem will be solved.
Apr 22, 2008 | Sony Handycam DCR-HC40 Mini DV Digital...
Pcmcia card
i think you can connect the 2 using a firewire that can be connected thru the usb.
the camcorder has this with it. its a small cable which you connect from the cam into the laptops usb.
pcmcia port is usually for portable nics and extender slots. please do check with the firewire fisrt as this is the main route for transfering data from cam to laptop.
Apr 17, 2008 | Sony DCR-HC28E Camcorder
Sony Handycam DCR-TRV19 Mini DV Digital Camcorder Logo
182 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
