Question about Olympus Stylus 410 / ? 410 Digital Camera
All-weather capability
What do I need to do maintain all-weather capability of my camera?
    Master:
  • 852 Answers
The following steps can be taken to maintain the all-weather: Make sure that all the covers are closed before using the camera. The camera loses its all-weather capability if the battery compartment cover, connector cover or DC-IN jack cover is open. Wipe any water off the camera before changing the battery or card. If the camera gets splashed, wipe the water off as soon as possible with a dry cloth. Saltwater spray or droplets can cause damage to the camera if the camera is not wiped dry as soon as possible. Do not apply excessive force to or attempt to peel off the rubber packing of the battery compartment cover, connector cover or DC-IN jack cover. If the rubber packing of the battery compartment cover, connector cover or DC-IN jack cover contains dirt or sand, wipe it off before closing the cover. If the rubber packing becomes worn or damaged, contact the nearest Olympus service center to obtain a replacement part.
Posted on Sep 01, 2005
3 Suggested Answers
neta
  • 852 Answers
SOURCE: Maintain all-weather capability of my camera
The camera loses its weatherproof capability if the battery compartment cover, connector cover or DC-IN jack cover is open. Make sure that all the covers are closed before using the camera. •Wipe any water off the camera before changing the battery or card. •If the camera gets splashed, wipe the water off as soon as possible with a dry cloth. Salt water spray or droplets can cause damage to the camera if the camera is not wiped dry as soon as possible. •Do not apply excessive force to or attempt to peel off the rubber packing of the battery compartment cover, connector cover or DC-IN jack cover. •If the rubber packing becomes worn or damaged, contact your nearest Olympus service center. (A charge is made for replacement of parts.) •If the rubber packing of the battery compartment cover, connector cover or DC-IN jack cover contains dirt or sand, wipe it off before closing the cover, otherwise water may get inside the camera. •The rechargeable battery and other camera accessories are not weatherproof. Care should be taken when using the accessories.
neta
  • 852 Answers
SOURCE: All-weather
The camera loses its weatherproof capability if the battery compartment cover, connector cover or DC-IN jack cover is open. Make sure that all the covers are closed before using the camera. Wipe any water off the camera before changing the battery or card. If the camera gets splashed, wipe the water off as soon as possible with a dry cloth. Salt-water spray or droplets can cause damage to the camera if the camera is not wiped dry as soon as possible. Do not apply excessive force to or attempt to peel off the rubber packing of the battery compartment cover, connector cover or DC-IN jack cover. If the rubber packing becomes worn or damaged, contact your nearest Olympus service center. If the rubber packing of the battery compartment cover, connector cover or DC-IN jack cover contains dirt or sand, wipe it off before closing the cover. The rechargeable battery and other camera accessories are not weatherproof. Care should be taken when using the accessories.
What type of deck chair is more durable and easiest to maintain?
Plastic deck chairs are the most durable because they are not affected by the rain and bad weather. In addition, they are really easy to maintain and clean.
Aug 19, 2012 | Garden
Can you exchange a 450cca battery for a 500a cca battery
Yes! If the question is can I replace my 450 with a 500cca battery. The more the better. CCA means cold cranking amps so it will perform better in the cold than a 450CCA. The higher the number means you will have more cold cranking capabilities in colder weather. The voltages are the same.
Sep 23, 2011 | 2004 Chevrolet Silverado 3500
Which Nikon S.L.R. cameras can I use my 70/300mm AF-S Nikor and still maintain auto focus, it is currently on a D40x
Every one (assuming the camera supports autofocus in the first place, of course--old film Nikons didn't). The lens has an autofocus motor, so the camera doesn't need one.
Film Nikons supported autofocus starting with the N2000. (Actually, the F3 also had autofocus capabilities, but used a different system). All the digitals support autofocus.
May 15, 2011 | Nikon Cameras
I need to know where the volume for this camera is
Unfortunately there isn't one. The ViviCam 5022 is primarily a still camera, with some video capabilities grafted on. Those capabilities do not include audio. You can add a soundtrack using video-editing software on a computer, but you cannot record one on this camera.
Dec 18, 2010 | Vivitar ViviCam 5022 Digital Camera
HOW DO YOU GET THE WEATHER CHANNEL ON WALKIE TALKIE?
Your radio must have VHF capability, as weather channels are VHF. Then your radio must be programmable to the weather channel for your desired area. If you repost a question including your Motorola radio name/model, we could be more specific.
Jul 20, 2009 | Motorola Walkie Talkie 2-Way Radio
Recording from the TV
I don't thinks it possible. Usually those cameras can record through a DV port that is two way not though an analog device.
You will have to use a Tivo, a DVD recorder, a VCR, or a computer with at TV tuner and DVR capability.
Jul 14, 2008 | Hitachi DZBX35A DVD Camcorder
Sep 01, 2005 | Olympus Stylus Verve S / ?-181 mini S...
All-weather
Sep 01, 2005 | Olympus Stylus Verve / ?-mini Digital...
Sep 01, 2005 | Olympus Camedia Stylus 300 Digital Camera
Flash
Yes, the FL-CB05 Shoe Mount TTL flash cable will allow full TTL capability with the FL-40 flash off camera.
Aug 31, 2005 | Olympus Camedia E-20N Digital Camera
Olympus Stylus 410 / ? 410 Digital Camera Logo
61 people viewed this question
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you an Olympus Camera Expert? Answer questions, earn points and help others
