Question about Fuji FinePix V10 Digital Camera
File size How do I adjust the resolution of the photos on my camera so that the file sizes of the pictures are smaller? Thanks!
    President:
  • 1,114 Answers
Hi - You can download the manual from the link underlined in blue below:
FinePix V10
See page 39 to set the quality:
Please take a moment to rate this solution & let us know if the information given was useful to you - Good Luck!
Informatica
Posted on Aug 25, 2008
I would like to transfer a photo file of 7500 MB. Tells me not enough room. Help!
then resize the photo file of split it into several smaller ones
Jun 06, 2015 | Computers & Internet
Changing Resolution On A Fuji A350 Camera
photos that have been already taken before any changes will not be affected after photo setting.Use camera menu or setup to look for RESOLUTION, PHOTO SETUP, IMAGE TYPE,STANDARD OR TYPE on menu to change photo resolution..
Dec 06, 2007 | Cameras
I have my S610 set to take photos @ 5MB. But when I download them to Picassa, they are ~1.2 MB. Is this a camera setting or Picassa?
Neither. The camera is taking pictures at 5 megapixels resolution. The file size of the image is only loosely related to the resolution. You'll note that your pictures are all different sizes. The size is dependent on the content of the picture. If you take a picture of a blank wall or a plain blue sky, the file size will be smaller than the file size of a picture of a cluttered scene, because it takes more bytes to record detail.
If you look at your pictures in your image viewer, you'll see that the pictures are all the same dimension (width and height), regardless of the file size.
May 15, 2011 | Cameras
My images save at sizes of 3-4 MB!!! how can i get them to be (way) smaller files??? powershot SD790is digital elph
Your solutions are varied, but the results will be (mostly) the same. Option 1: Lower the resolution and quality settings on your camera. If you are seeing 3-4 MB per photo, then they are probably at least 4000 pixels wide, and your file size will be larger to reflect that. If you set the camera to a lower quality and or resolution, you will for sure save disk space. Consequently, you will also lose image quality. If you are mainly archiving the photos for the purpose of viewing them online, on your PC, or through a digital picture frame, this is no big deal. If you intend to print, especially a large print, you will see pixelation occur in the print. This will take smooth parts of your picture and chunk colors together in a "boxy" appearance. Your second option, is to import your photos in a program like Google Picasa or many other free options, and then convert your image to a compressed format, such as a compressed JPEG or PNG file. PNG files are usually the better choice for file size, but not every devices (frames, TVs, etc.) recognize PNG files. So you may want to stick with JPEG depending on your use for your photos. Additionally, you can lower the resolution of hi-res photos within Picasa (or its alternatives) after importing the photos. This is the preferred route as you can take every photo like you want to print it as a poster, and then choose which photos to drop the resolution. This gives you the safety of shooting each picture as if you want to keep the quality and then later decide which are worth archiving at what resolution. Remember, the detail in a photo also reflects upon its size, not just resolution, if you take one 12 MP picture of the sky and another of a bunch of different color balloons, the balloon will have more color data and thus a higher file size.
Mar 10, 2011 | Canon PowerShot SD790 IS/ IXUS 90 IS...
I have a Sony DCR-SR43 handycam. I am a amateur photographer. When i shoot some shots, the file size is very large (208 or so..). Is there any software to compress the file.
The size of the file depends mostly on the resolution. Higher resolution gives more detail and the picture can be printed larger without showing pixelation, but this requires more data, so the files are larger. Recent cameras offer resolutions stated in terms of 10 or 14 megapixels. That much data needs a large file to store it. Reducing the resolution in the camera settings to 5 or 3 megapixels (or less) will give you a much smaller file. In the camera, this will usually be specified in terms of pixels wide by pixels deep (e.g. 1600x1200).
You can reduce the size of a picture in a photo editing program (resize or resample), which will also reduce the resolution.
Compressing the file is not likely to help much. Usually these files are in a format (.jpg) that is already compressed. The camera may allow more than one quality of compression. You can set this to compress the pics more, but this will reduce the quality of the image and introduce more digital noise. It is also possible to increase the amount of compression when saving an edited file in a photo editor, by specifying this at the point of saving. None of these will make as large a difference as reducing the resolution by resizing.
Feb 03, 2011 | Sony Handycam DCR-SR42 Camcorder
Hello, My camera had been taking photos under a file size of 1 MB, normally 800 KB. Today for some inexplicable reason (I must have done something!), the photo file size is 4MB, too large to send and use...
On your camera, look for settings. You must have set it on "Large" or "Max" picture quality. Thus making your 'normal' 800kb into a more better quality.
On your laptop/computer try to open it in a image editor and change the resolution of the picture.
Dec 14, 2010 | Sony Cybershot DSC-T200 Digital Camera
Picture Size to Large?
This may not be the solution; however, please obtain a larger capacity memory card.
A 2GB card will give you several hundred photos. Cost is less than $10.
You really should not lower the resolution. you will lose detail that you may want in the future (really). (4GB card will hold over 999 pictures - $15)
If you must lower the resolution, press "Menu" and use the arrows to move the highlight bar to "resolution" ... change it to a lower number like 6MP. keep the "FINE" setting in place (if your model has that setting) or maybe "BEST".
Do not use "RAW" - (very large pix).
Hope this helps!
Sep 03, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Hi..I've downloaded pictures and videos from my digital camera. I am able to send the pictures but not the vidoes.....can you help? Thank you, Rachel
I'm suspecting your internet service provider can't handle the large files (maybe the connection is too slow, or your email account has a file size limitation). Try to create a SMALL video file with your camera...literally no more than 1 or 2 seconds, so that it will have SMALL size. If possible, use a smaller/lower resolution video setting to help keep the file size down. Then upload the small file to your email. Check the file size to see the size as compared to the other videos, and your regular photos. If you are able to send it, and the size is similar to your photos, then it means that the other videos are just too big. (how big are those original video files you were having touble with?).
Nov 28, 2008 | HP Computers & Internet
Confused about Resolution Sony DSC-T7
2.2 MB is the size of the file on your hard disk. Being a .jpg, it is a compressed file. The file size does not reflect the size of the image stored inside the .jpg. Yes, the size sounds about right. It will increase or decrease depending on how much detail there is in the picture. If, for instance, your picture is made up of nothing but uninterrupted blue sky, the disk file will be quite small - as the .jpg does not need to store much information (the more repetitive information, the smaller the file). On the other hand, if your photo consists entirely of nothing but blades of grass, the disk file will be comparatively large. When you see "DPI", that refers to print resolution. So, since you're not printing, but rather, viewing onscreen, Photoshop "assumes" a convenient "screen resolution", as though you printed on the screen (don't ask!). If you look at the other settings, you'll note that Photoshop also thinks your photo is 36" wide!!! You adjust the DPI (or photoshop will) when you print. Till then, it doesn't mean much. Let me give you an idea of your image's possible DPIs. Assume you really want to print a 36" photo: 2592/36" = 72 DPI If you make the picture 12" wide: 2592/12" = 216DPI At 10": 2592/10" = 259.2 DPI At 8" 2592/8" = 324 DPI How do you get my photos above 200 DPI? By printing the picture small enough, less than 12.96" on the wider side. See calculations above. The resolution at which you shot the image (2592X1944), will not cause blurriness. As for the cause? There could be any number. Was the subject moving? Were you? Did you shake the camera while shooting? Is your shutter speed too slow? Should you have been using flash? Is the camera autofocusing correctly? Are you waiting for the autofocus to lock before pushing the shutter the rest of the way? Etc. Hope this helps somewhat...
Sep 12, 2005 | Sony DSC-T7 Digital Camera
How do I make an image file smaller so I can send it by e-mail?
To make an image file smaller for e-mail transmission, change the image file size in "Exif Viewer" or "FinePixViewer". Changing the size of an image file 1. Start up the Viewer and select the folder containing the image you wish to send. 2. Double-click the thumbnail for the image file you want to resize to open the image in its own full-size window. 3. Select "Image size" in the "Image" menu. 4. Set "%" as the "Unit" used for file size display. Then enter a value lower than 100 as the "Width" or "Height" and click the [OK] button. 5. Select "Save as" in the "File" menu to save the image. (You can also reduce the image file size by lowering the quality in "Save as type".)
Aug 30, 2005 | Fuji FinePix 2600 Zoom Digital Camera
Fuji FinePix V10 Digital Camera Logo
50 people viewed this question
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Are you a Fuji Camera Expert? Answer questions, earn points and help others
