Question about Electrolux Vacuums
After cleaning the filter the self clean just keeps on flashing and will not go back to working mode
  • lherewin Aug 25, 2008
    yes! it made me look at alignment and that there may have been an issue still to be addressed as you suggested. I gave it a thorough clean and found a small christmas bauble with a lot of dust backed up behind it. Thank you so much for your help because without your comments I probably would not have given it such a thorough going over.
    Much appreciated. Once again thank you.
  • Electrolux Master
  • 19,396 Answers
Check if it does reset when you unplug power, and by emptying completely the bag.
Posted on Aug 25, 2008
  • 1,586 Answers
First thing to do is double-check and make sure everything is reinstalled just as it was before taking it out - if something is out of adjustment or not aligned properly it can cause problems and the vacuum may think there's still an issue. Double-check that (and clean up any parts that you can reach or remove) and let me know if it helps out. If so, great. If not, we'll take the next step.
  • Jeremy Dellow
    Jeremy Dellow Aug 25, 2008
    Great:) Glad it worked out for you, and you're welcome:)
Self clean and power lights flashing on electrolux
you either need new filters or you have a bad electronic board or possibly both. Most of these machines only last a couple of years. Not to discourage you, but do yourself a favor and don't buy another one. It's a chinese made Eureka with a lux label. Electrolux went bankrupt many years ago and Eureka bought the name. Miele, Sebo, Riccar, or Lindhaus are all better choices.
Oct 19, 2013 | Electrolux Twin Clean Bagless Canister...
Eureka lightforce 300 poor suction, power paw doesn't spin and self cleaning duster doesn't clean its self when the button is depressed.
When this happens to me I do two things. The first is to empty the cannister but when you do (with the vacuum unplugged) stick your hand up inside of where the cannister goes.Sometimes that is filled with debris. Pull as much as you can out. There is another part inside there that you can twist and pull out - this will help you pull out more of the trapped debris. Replace that part and the cannister - usually there's a blockage and just removing some of that debris will cause a bunch more to dump in to the cannister. You may have to repeat this process two or 3 times untill no more debris comes out when you turn the vacuum back on.
The second tip solution is to clean the filter which can be found on the front of the vacuum.There's a clear plastic cover, a black rectangular this that hold the filter sponge and inside of that, the filter sponge. I just rinse the little sponge inside and shake off the thing that holds the sponge (Sorry, don't know the technical terms). Put it back together and you should have suction - viola.
Hope this helps.
Oct 28, 2012 | Eureka 4718AVZ LightForce 300 Bagless...
How do i operate self clean mode
Before you go working too hard to get you oven to go into the self clean mode(self destruct)....check out this tip...
Self Cleaning Oven Problem
heatman101
" Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!!
Jan 04, 2011 | Vacuums
I have a Hoover Wind Tunnel Self propelled 12amp. There seems to be very little suction. I have cleaned the hoses and filters but still not much suction. any ideas? thanks.
Make sure all filters are cleaned out and entry ways are clear of all debris. Remove hose and check for blockage. Usually the low suction can be remedied when all filters are cleaned. Hope this works for you.
Jul 17, 2010 | Hoover Self-Propelled WindTunnel Bagless...
My VAX Vacuum has lost ALL suction power. I've
vax power pet 1 filter keeps getting clogged up so dirt not going into cylinder
Jul 05, 2009 | VAX Appliances Vax X5 Bagless Upright...
Red flashing light with 6 beeps
It means you need to clean the sensors. I have had this problem every now and then. There are 4 plastic clear sensors that you can clearly see when you put roomba upside down.
I have found the best and most effective way to clean them is with a dust wipe. You push the dust wipe in with a cotton swab or even a pen, and rub it around the face of the sensors cleaning the dust off, and it will work fine again.
The reason you need to use a dust wipe like a Swiffer brand is that it is very effective and will pick up all the dust. You may not see the dust and you will keep getting that red flashing error though the sensor may look clean to you.
I just had that problem, and after I used the dust cloth, it's working fine again. Good luck.
Jun 11, 2009 | iRobot Roomba 530 Robotic Vacuum
I purchased a hoover windtunnel 2 model#u8361900 in Dec 2007.I am very disappointed because the self cleaning filter is not turning and particles keep clogging in that area. I have manually removed the...
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=724091
Generic problem for all Vacuums
I purchased a Hoover WindTunnel
Posted by billmar082 on Jun 30, 2008
I purchased a Hoover WindTunnel 2 model#u8361900 in Dec 2007.I am very disappointed because the self cleaning filter is not turning and particles keep clogging in that area. I have manually removed the particles but the filter will not turn. I also haven't been able to use the pet brush for some time. The cleaner has not been used hard about once a week since it was purchased. I am not happy that this product has stopped working efficiently since purchased 6 months ago. Thank you Marcia Long Pottstown Pa
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. I sorry you are having a problem with the Hoover WindTunnel Vacuum Model #U8361-900 but I never heard of a filter that you say is self cleaning and NOT turning. I have never seen a filter that turns inside the chamber, the dust and dirt basically go around and circulate around the filter and you can clean the filter by either brushing it off, vacuuming it off or using some type of brush to clean off the filter such as and old paint brush or if you have some type of blower system – that would work as well. You said your vacuum is less than one year old so I would contact your local factory authorized Hoover dealer in your area or to cal the cust serv @ the Hoover factory listed below. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jun 30, 2008 | Kenmore Progressive Bagless Upright with...
My hoover wind tunnel vaccum has a hepa filter that is supposed to be self cleaning but continues to plug up. it is not easy to get to and takes forever to clean it out so the suction is strong again.
do you have the SELF-CLEANING, rotating HEPA filter?
I just fixed my HEPA filter not rotating!!
It involves taking apart the vacuum HEPA area. All screws are the same size. There are a LOT of 'em. Really straightforward putting it back together too.
ok, once you take the HEPA canister area off the vacuum, careful with the wires! Unplug them from the controller board. You open up the HEPA chamber by removing more screws until you see where the motor that turns the filter is mounted on the side. Remove motor from the green chamber. Note where the washer goes. Once the motor is off, you'll see that the center hub that drives the HEPA filter is rounded out. What I did was jam little bits of aluminum from a pop can into the space between the circle and the square to force the walls back to square. I started by folding a little piece of aluminum over and over so it was about three layers thick. Jammed that in. That wasn't quite enough thickness so I shoved another piece with it. If you can find something that is about 4 times the thickness of a pop can aluminum, that'd probably work too. Slight wedge shape on the tip would help. Any sort of tiny shim.
To test your work, just put a couple of holder screws into the HEPA cannister housing, plug in the cover/switch, plug in the HEPA moter. Turn it on for a few seconds to make sure the filter turns. Then you can add more thickness to the hub or put things back together.
Apr 29, 2008 | Hoover U5444-900 5100 Wind Tunnel 15 Inch...
THe supposed "self cleaning" filter
That filter is coated with a telfon coating and will only "self clean" to a point. You will have to remove it periodiaclly and tap it gently to dislodge dirt from the element. You should also check the secondary filter located under the dirt cup. It is visible through the hole that the filter sits on top of. This filter is washable as is the main cartridge filter. It's important that they are completely dry before installing.
The hose on this machine is very limited in how much suction it will provide. It is activated by a valve in the base that opens and closes with the handle. When the handle is positioned in the upright position, the valve closes off the front roller suction and diverts it to the hose. These valves are very limited in how well they seal and you normally don't get the full benefit of the suction that the motor actually produces. This is further compounded by debris collecting in the valve and not allowing it to close fully and hence, it will leak. It's just the nature of the beast.
Keep the filters clean and the hose and the floor function will work much better.
Feb 22, 2008 | Hoover U5753-900 WindTunnel Bagless...
Vacuums Logo
152 people viewed this question
Top Electrolux Vacuums Experts
Mack Baxter
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
