Home | Panasonic | (PV-GS500) Camcorder | Panasonic sdr-h40p can...
Panasonic Camcorder
Problem for Panasonic (PV-GS500) Camcorder
Panasonic sdr-h40p cannot connect to my pc
By vegapenguin on Aug 25, 2008
I have installed the videocam suite 1.0 that came with the camera and the program works fine. I plug my camera into the usp port and it wont let me select the pc connect option, it will just tell me to connect ac adaptor. So my pc cannot recognize the camera or something.... so i cannot have my movies i recorded on the pc. but if i go down to the pictbridge option it will connect to the pc just fine but i can only see the pictures on the pc. im just super frustrated because i just bought this camera and it wont connect to my stupid computer which is windows xp by the way. please help!!!
Clarification Request
Posted by jisoldi1 on Feb 15, 2009
I am having trouble sending pictures from the Lieca lux 3 to pc. I was told I do not need any software that it is in the camera itself. What is the easiest way to do this using the cables - I do not have a card reader.
Same Problem
Apr 28, 2009
-   ALL ITS DOES IS TELLS ME TO DO NOTHING DURING THIS ACTION BUT NEVER DOWN LOADS THE VIDEO'S-   CNLEWIS61
Feb 23, 2009
-   I have the exact same problem. Installed the software that came with the panasonic SDR H60. Plugged in the aux power cable to the camera and the usb cord to the computer and camera. I am using Windows XP. The software takes for-ev-er to load and then shows my camcorder listed on the left hand side but WON'T let me select my camcorder to unload the files/movies. It just won't let me click on it at all. I tried using Windows movie maker and it won't work , either. So I downloaded a free movie maker software...and it says "device not found". I checked on "my computer" and it shows that the camcorder IS linked to the computer as F drive. I don't understand. I am getting ready to return the camera. I have a few cute vids of my kids on it, so I hate to do that ! -   jmertn
Feb 23, 2009
-   I have the exactly same problem. I bought the camcorder to take some video for my assignment. I am so frustrated now coz I can't transfer the videos to my pc. I would like to try the solution above but don't know how to initialize to safe mode and couldn't find "run". Btw I am using window vista. Can someone help me plz? thanks for your kindness.-   esc84
Feb 17, 2009
-   same problem :/-   Guest
Jan 15, 2009
-   i have the same problem....help!-   Guest
Solution #1
posted on Nov 13, 2008
Somewhat Helpful)
SavioS
Rank: Apprentice
Rating: 77%, 3 votes
Hey All,
I did not have any problem to install the software but I had a hard time to the files transfered to my PC. Actually I only was able to do it once and the I couldn't do it anymore. I've been trying for months and fortunately I've found a temporary work around which allows me to transfer files from the camcorder to PC with no problem.
These were the steps taken:
1-Connect the camcorder to PC
2- Initialize Windows on a Safe Mode
3- Log as Admin
4- Click on Start\Run type msconfig
In General TAB select Diagnostic Startup click on OK
5-Restart Windows on normal mode and log as your regular user
6- Start VideoCam Suite and transfer the files from camcorder
7-Repeat step 1 to 4
In General TAB select Normal Startup click on OK
8-Restart Windows on normal mode and log as your regular user
9-Start VideoCam Suite and then will be able to work
normally with software (edit and burn DVDs)
Well, it is not best solution but at least I won't be stuck with movies inside the camera. The only inconvenient it is to have to change settings every time I need transfer files from camcorder. I think I can live with that.
I hope that can help anyone.
Cheers,
Savio Silva
Was this helpful?
Yes
No
Solution #2
posted on Feb 23, 2009
Very Helpful)
esc84
Rank: Apprentice
Rating: 96%, 6 votes
hi all, i had exactly the same problem and finally managed to sort it out, here to share with u all. The AC adapter is the one looks like a battery cable which comes with the camcorder. You have to remove the battery first, and plug the AC adapter into the place where the battery was, then connect the other end to the battery charger. Now you can select the PC connect option and transfer your videos. Hope it helps. =)
Was this helpful?
Yes
No
5 people thought this was helpful
Solution #3
posted on May 30, 2009
Somewhat Helpful)
noname123456
Rank: Apprentice
Rating: 75%, 1 votes
Did you think to buy a FIREWIRE cable?
USB connections are only for tranfering from card, not for TAPE!
Was this helpful?
Yes
No
Solution #4
posted on Jan 03, 2009
Somewhat Helpful)
justdoitrigh
Rank: Apprentice
Rating: 75%, 2 votes
have you tried to connect the ac adaptor and toggle the joystick down to hdd and then push the joystick
Was this helpful?
Yes
No
Solution #5
posted on Dec 19, 2008
Somewhat Helpful)
gennike1
Rank: Apprentice
I just bought this camara and i can not sync wth the pc this sucks just got this camara and it dont work all my videos and there is nothing i can do
Was this helpful?
Yes
No
Solution #6
posted on May 21, 2009
Not Rated)
camera fix
Rank: Apprentice
Rating: 0%, 0 votes
There is a download for this on the panasonic website. I had the same problem, did the download, retried and it worked. All videos downloaded. It took a LONG time but I got them.
Comments:
May 21, 2009
- There is a download for this on the panasonic website. I had the same problem, did the download, retried and it worked. All videos downloaded. It took a LONG time but I got them.
Was this helpful?
Yes
No
Popular Solutions for Panasonic Camcorder
Questions and Unsolved Problems for Panasonic Camcorder
Do you recommend Panasonic (PV-GS500) Camcorder?
Answer
Answer
I have a panasonic TM10 camcorder - every time I try to burn recorded footage on to a disc the... (More)
Answer
how to connect my Panasonic camcorder to TV or computer to watch what I have recorded?
Answer
cant get my camcorder HDD SDR-H80 to download onto the mac laptop
Answer
I have a SDR-H40P I can't get my pictures from the Camcorder to my computer--
7 Other Users Have The Same Problem - Continued
Comment by bjcapt3785, posted on Sep 13, 2008
I have the SDR-H60 Camcorder with the same issue. Windows XP Service Pac 3 is the problem that causes the VideoCam Suite Software to not work with the PC. I am also super frustrated.
Comment by Guest, posted on Sep 02, 2008
you need to remove the battery and plug in the ac adaptor
Bob
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Panasonic Camcorder:
Top Camcorder Experts
Rank: Guru Guru
Solutions: 632
Experience: im jack of all trades but a master of none! and being an old f*rt you get to learn a fair old bit
Ask Me
Find more Camcorder Experts
Top Camera & Camcorder Repair
(888) 435-5080
Worldwide AFFORDABLE digital camera repair &...
Digital Camera Repair and Parts: Darntoothysam.com
(915) 239-6199
CamerasAndParts.Com Specializes in the Service /...
CamerasAndParts.com
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
