Question about Acer Aspire L100 PC Desktop
Internal Hard Drive noise
The L100 started making strange noises recently. It is difficult to describe. At first, it seemed like a noise only a speaker could produce (like when cell phone activity causes interference) and it is also a bit like varying high-pitched mechanical noises. Once the noise started when the computer booted up and went away on its own a while after getting into vista. Now it is constant and the computer is running slowly. Is it time to back everything up and replace the hard drive?
  • jonhNZ Sep 12, 2008
    my L100 squeals like that some times when it starts up, then stops... reading the suggestion that it's the hard drive complaining, I'm thinking spinrite might help?
  • 89 Answers
It only means that your hard drive is experiencing bad sectors and it might become a mechanical problem which eventually the device should be replaced once the hard drive cannot be read or detected anymore. there is no solution to it.. all you have to do is wait.
Posted on Aug 25, 2008
2000 ford taurus strange noise when accelerating when vehicle is warm
start with don's post..
inner cv joints will make noise too. but not really popping as you said. more a click click....
Jan 10, 2018 | 2000 Ford Taurus
Making a terrible noise
its cloged or the pad behind it is burned up
Jan 25, 2012 | LG DLEX7177 Dryer
My hard drive is making a strange noise when it is used. It sounds like a heartbeat and it occurs in a random time interval. I know it isnot much to start with but i cannot say anything else about it then...
Any strange noise like excessive clicking, grinding, some weird sounds etc. actually indicate a failing hard drive.
Failing hard drives often show warning signs of their imminent demise. If you're lucky enough to see or hear one of these signs, stop what you're doing and immediately back up your data. They say prevention is better than cure so if your computer's hard disk is making some strange clicking sounds, BACK UP YOUR DATA IMMEDIATELY (As the drive is not operating smooth and may fail anytime).
After making backup of your important data on CD/DVD or External Drive, you may scan the drive for surface errors, format it and see if it works properly or not. It would be better if you seek professional assistance for examination of the disk.
Hard drives are mostly under warranty for at least one year. Claim warranty, if possible.
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
Sep 20, 2011 | Western Digital 2 TB SATA 6 GB/s 7200 RPM...
This AC makes a severe Churning noise when the compressor runs. It now makes a strange noise when your start the unit and then 'hums'. It seems to have problems with the compressor 'kicking...
lots of compressors make strange noises and run for years. I hate to suggest installing a hard start kit simply because I always wonder what we did before they came out with a hard start and machines lasted longer BUT, check amps on start up, amps while running, watch amps for a bit while it's running, install hard start kit. just like all mechanical equipment, it may last 5 weeks, it may last 5 years. Best Wishes!!
Oct 31, 2017 | Frigidaire FAS156N1A Air Conditioner
A new hard disk drive, Hitachi part
Hello there DLBurkhart.
Here's your geek-steer ...
"...is emitting strange whining sounds every now and then ... Is this strange noise a sign of an impending problem?" == EVERY strange HDD noise is ALWAYS a sign of impending failure.
Peform a "Check Disk" on it ...
chkdsk DRIVE_LETTER /X /R
  • There should be NO surface errors if it's new(er).
  • Regardless, if it's new, then immediately insist upon a replacement.
Good luck, and please do post back ...
  • to let me (and interested others) know how things worked out,
  • to provide clarification or feedback,
  • if you have ANY further questions.
Today's the best day of my life ... and NOW you're part of it!
Via-con-Dios and Godspeed -- Geekinator (aka Craig).
Oct 13, 2009 | Hitachi Deskstar T7K250 HDT722525DLAT80...
Internal engine noise
internal noise is hard to tell unless heard by tech however make suere that yo have oil first, sounds like a connecting Rod is broken
Nov 19, 2008 | 1989 Oldsmobile Eighty Eight Royale
Weird noise from Acer Aspire 3000
When you open the sound control panel, is the mic muted or turned down? The feedback may have been coming from the built-in microphone?
Jul 16, 2008 | Acer Aspire 3000 Notebook
Ipod making a grinding noise
Hey dduenas,
There are actually a number of problems that you could be describing, but without having an actual "hands-on" diagnostic performed by an Apple-authorized technician it would be difficult to provide you with a definitive answer.
Among some of the most common reasons why any device with a hard drive would make a grinding (or clicking) noise are the possibility of loose internal components and/or a failing hard drive. The battery itself should not be making any noise, as most batteries typically contain no moving parts.
If you are still covered by the manufacturer's warranty - or by coverage provided through a third party, such as a Best Buy Performance Service Plan (PSP) - I would strongly suggest contacting Apple directly or your local repair shop for further assistance. Even if you no longer have any kind of coverage, either of these parties should be able to provide you with a diagnostic and more information on how to resolve the problem.
Hope this helps you out.
Sincerely,
Aaron
Go Ahead. Use Us.
May 26, 2008 | Apple iPod MP3 Player
Hard drive making strange alarm/chiming noise and won't load onto desktop
Listen to your power supply and see if it is making a faint buzzing noise. Try your device with a new power supply. With a new power supply my drive now runs fine, and was not corrupted.
Jan 13, 2008 | LaCie 500GB d2 Quadra 500 GB USB 2.0 Hard...
Acer Aspire L100 PC Desktop Logo
280 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
