Question about Compaq Presario Notebook
Install memory i have a 1gb DDR2 memory to add to my COMPAQ Presario V5209US laptop. I've never done it and have been told it is easy and to just open up the back. But I don't want to screw up my PC. What steps should I take to install the memory? Can you help?
  • Anonymous Oct 11, 2008
  • 2,071 Answers
The solution is very usefull and effective..
Posted on Aug 26, 2008
    LORETO LACARON Aug 28, 2008
    Thank you very much for rating so my votes is increasing...
  • 125 Answers
Use the following steps to remove a memory or continuity module:
Turn off the computer.
Windows 98 or 2000: Click Start , Shut Down , and then Shut Down
Windows XP: Start and then Turn Off .
Unplug the AC adapter, if present, and remove the battery.
From the bottom of the computer, remove the screw holding the RAM cover, and remove the cover.
Remove the board by pulling it away from the connector at a
45-degree angle.
Align the keyed (notched) edge of the board with the keyed area in the expansion slot. Insert the board into the slot at a 45-degree angle until it is seated.
Push the front edge of the board down until the retention clips snap into place. Then replace the cover
Posted on Aug 25, 2008
  • 89 Answers
Check this website for a step by step instruction:
I have compaq presario V3070TU with 512mb ddr2 RAM. i tried to upgrade to 2 gb RAM into one bottom slot (not 2 numbers of 1GB), but 2gb RAM is not working(display is not UP). only 1gb RAM is working....
I could not figure out the relationship of the hard disk with the memory.
try change the memory dimms put 512 in bottom and 1gb in the other possition and see what amount of ram you get
Aug 02, 2013 | HP Pavilion ze4365us Notebook
How to add or change DDR2 Memory Compaq Presario SR5110 desktop computer
Just remove the power cord, open the case, turn the computer on it's side and you will see the memory sitting in the slots. Push down on the latches on both ends of the memory slot and then you can pull the memory out.
Be sure to replace it with compatible memory or it will not boot up. Also it you install more than your system will hold, it will not register the excess.
Try 4 All Memory website. It will tell the type, how many slots you have and the maximum amount of memory it can hold.
It looks like your system uses DDR2-PC2-5300 Memory. It has 2 slots and a total capacity of 4GB which means each slot can hold a 2GB chip.
Jun 03, 2012 | Computers & Internet
I have a laptop of compaq brand whose modle no is presario C700 in which intel celeron microprocessor is installed. 512 MB ram is installed i want to update it 4 improving its speed. i want to setup a...
I found the manual on the net that gives you instructions on replacing components if you're not sure how, it can be found here.
RAM upgrade
The Compaq Presario C700 uses DDR2 Laptop RAM as shown below.
slasher_x_11.jpg The motherboard of the Presario C700 has two RAM slots, one of them will be occupied by the 512MB RAM (running at 667MHz) module you have at present. This leaves one more that can accomodate a DDR2 667Mhz card of up to 1GB or you could get two 1GB DDR2 800MHz (the faster DDR2) cards and remove the 512 leaving you with a wopping 4GB of memory, that'll definately speed it up. Just remember the Presario C700 can only have up to 2GB of RAM so don't go higher than that or Windows will not boot for some reason.
Processor upgrade
The Presario C700 supports any Socket P, Core 2 Duo or Pentiun Dual Core chips. The fastest processor you can get is the Intel T8300 2.4GHz Core 2 Duo Processor with 3MB L2 cache and an 800MHz FSB
For a full list of compatible processors go to page 9 of the user manual found here.
Jan 11, 2011 | HP Computers & Internet
Hi i want to know if my laptop is with ddr 2or ddr 3,it is 1gb presaroi cq 60
The details about your laptop's ram,
Maximum = 4Gb
Technology= DDR2 SDRAM
Form Factor =SO DIMM 200-Pin
So, ram installed on your laptop is DDR2. If you need/want to upgrade, you have to look for and buy DDR2 type ram.
Good luck.
Thanks for using FixYa.
Aug 15, 2010 | Compaq Presario CQ60-220US PC Laptop
How to increase memory hp presario c502
In reviewing your message, I understand that your Compaq Presario C502 Notebook PC is running very slow and you wish to upgrade the memory of your Notebook.
I greatly appreciate that you have forwarded your concerns and have given me a chance to assist you with this matter.
I have checked the database and found that the Notebook is preinstalled with 512MB DDR2 System Memory. However, I am providing you the exact specifications as below,
DDR2 PC2-5300
And, also provoding you the part number for the 512MB and 1GB memory module as below,
512MB, 667MHz DDR2, PC2-5300, SDRAM Small Outline Dual In-Line Memory Module (SODIMM)
1GB, 667MHz DDR2, PC2-5300, SDRAM Small Outline Dual In-Line Memory Module (SODIMM)
You can purchase the compatible media from your nearest HP retailers. HP has a network of authorized retailers and resellers within the U.S. You can find the nearest HP authorized retailer by visiting the Following Web site:
Under the "other ways to buy" section, click "find Compaq retailers" option. Enter the required details in the Web form and click the "find" button. This will display a list of Compaq retailers nearest to your location.
You can also order the memory module from the web link given below,
NOTE: The URLs above will take you to non HP Web sites. HP does not
control and is not responsible for information outside of the HP Web site.
After purchasing memory module for remove and replacement, I am providing you the web link that contains detailed information,
Moreover, I would like to inform you that you can also improve the performance of your Notebook by performing the steps provided in the web site given below,
I hope this information has been of assistance to you.
Please let me know if the issue still persist or you have any other issue because it is important that I resolve your issue in a timely manner. I would like to add that we value your precious time and We assure you of our dedicated support, 24 hours, 365 days a year.
May 12, 2010 | Computers & Internet
Which ram support for compaq presario c700 tu''
This laptop can have a max of 2Gb of ram, (2x1gb)
Each memory slot can hold DDR2 PC2-5300 with a maximum of 1GB per slot, None-ECC
Hope this helps.
Aslong as you get 512Mb or 1Gb sticks of PC2-5300 none-ecc laptop ram, you will be fine.
Jan 02, 2010 | Compaq Presario 700 470024-192 Notebook
Memory Upgrade for Compaq Presario 2580US
no 'coz these two memory card differ in size and slot especially when the mainboard doesn't support ddr2
Nov 18, 2008 | Compaq Presario 2580US Notebook
Compaq presario c714nr upgrade memory too 2gb laptop
Page 43 of this manual seems to have the best documentation on memory for this machine. I saw a 2GB max in another document and this shows the biggest module as 1GB. I would believe that infers a pair.
Dec 18, 2007 | Compaq Presario 700 470024-192 Notebook
Compaq Presario Notebook Logo
59 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Lee Durbin
Lee Durbin
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
