Question about Gateway MX6920 Notebook
Circuit or mb replacements
When my gateway laptop is off it charges but when i turn it on and its plugged in the screen blinks light dark cuz its chargeing then not charging i asked a friend and he said its probly the circuit or mb need to be replaced how can this be fixed and how much is it gonna cost cuz my warrenty ran out
  • 1 more comment
  • Anonymous Nov 20, 2008
    My computer does the same thing, except it rarely charges even when it is off. At first we got a new power cord and it worked better for about a month, then it stopped working again.
  • eljimmy70 Jan 30, 2009
    I think I got a similar problem. When I plug the adpter it doesnt work well. I have to be moving the cord around till I see the screen light up bright. I have to move it constantly or else it will not charge my battery. The problem is, this is the second cord I get and it works great for about 5 months and then it does the same thing. Its weird, I cant take it nowhere cause I have to keep the cord still so it wont move. If anyone knows what I can do, id appreciate your help/advice. thank you.
    eljimmy70@hotmail.com
  • zsmills Feb 24, 2009
    I have the same problem. I am on my 3rd power cord. My first one worked for about a year, my second one lasted for maybe 5 months and the one I currently have only lasted like 7 months.
    I think its a problem with the chargers they use for this laptop becuase this computer is great in every other way...
    I get the same blinking on and off while it is plugged into the wall- the blinking is it changing from ac to batters.
    It never charges completely and always drains while I am using it.
    Brigadier General:
  • 5,158 Answers
My suggestion is to check this website to see if the battery has been recalled in your laptops
http://www.gateway.com/battery/
Robert
Posted on Jan 03, 2009
GATEWAY NETBOOK DROPPED IN THE BATHTUB :(
At this point you would be further ahead replacing the netbook.
Mar 04, 2012 | Gateway LT2001u Netbook
Laptop will not charge. After wiggling the cord
That's a short in the power input section of the motherboard- I've found, much to my dismay, that the power input/charging circuit on these laptops is not a separate circuit board as it is on some other models, but is a small area of the motherboard itself. You'll either need to have someone repair the motherboard or replace it entirely.
www.dfwsupergeek.com
Feb 16, 2010 | Gateway MT6705 Notebook
Gateway Laptop W340UA black screen
  1. take out the memory
  2. turn on again without memory (you should hear long beep sound) and turn it off again
  3. clean memory using eraser (better if you have spare memory to replace it)
  4. now try again
  5. if not working, checks whether the work properly? and clean the fan from dust. and try to switch it on again.
I look forward to hearing further.
Dec 14, 2009 | Gateway Computers & Internet
Charger makes my screen dark
GO into the control panel and check your power settings. You might have it set to use less power when plugged in.
Oct 03, 2009 | Compaq Presario Notebook
Blinking yellow light on Acer Aspire
You can find the broken piece on line to purchase,This can be repalced by soldering it to the motherboard.You will need to find someone to replace this probably a tv repair technician who is good at soldering small circiut boards.You can also purchase the motherboard and replace it
Good luck
Sep 28, 2009 | Acer Aspire 5500 5570-2609 Laptop
Lcd of my gateway laptop lost ligth inside so is to dark but i can see the destop icons but is to dark
Your Backlight bulb has burned out, or the Inverter for it.
1.General information on replacing a Backlight lamp,
(Bulb)
http://www.laptoprepair101.com/laptop/2007/12/09/replace-laptop-backlight-ccfl-lamp/
2.General information on replacing an Inverter,
http://www.laptoprepair101.com/laptop/category/replacing-screen-inverter/
May 28, 2009 | Computers & Internet
Gateway 7405 battery and charge problems
This sounds like a problem with the charging circuit on the board.
There could be a problem with the power jack:
http://www.laptopking.com/kingpartdetails.asp?ref=583&category=dcjack
They are available but will require disassembly and probably some soldering to replace.
It might be best to try another MB if you can find one cheap. Like this:
http://cgi.ebay.com/GATEWAY-7405GX-7422GX-7426GX-MOTHERBOARD-102567_W0QQitemZ200316906366QQcmdZViewItem
Mar 14, 2009 | Gateway 7405GX Notebook
Gateway not turning on with or without battery/AC adaptor
these people are right and there is definitely some hardware issues with your computer...which can be repaired but not really worth the money or effort.
Feb 17, 2009 | Gateway MT3705 Notebook
Power light comes on but no screen or hd activity, gateway mx6447
Sounds like you have a bad motherboard. Bad mother boards give alot of different signs and 1 is no screen display. If it was a a bad HD you would still see something on the screen
Feb 08, 2009 | Gateway MX6447 Notebook
Boot up menu restart; will not power
Boot up to the safe mode screen & select last known good configuration.
Jan 15, 2009 | Gateway 4026GZ Notebook
Gateway MX6920 Notebook Logo
93 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
