Question about Frigidaire GLEQ642A Electric Dryer
Dryer won't start
I have a whirlpool dryer that won't start. I've checked the circuit breaker and all is well, it's plugged in, it closes properly. I've checked the basics but nothing seems to work. I have a Frigidaire Gallery Stackable Electric Dryer. It's been working great. But today, when I tried to turn it on, it just humed.
    Guru:
  • 674 Answers
Sounds like you have a bad capacitor this is what starts your motor by giving it a burst of energy
with model and serial number i could give more info
Posted on Aug 25, 2008
  • 1,879 Answers
Are they both working fine prior to this incident and connected in the same circuit ?
  • 1,800 Answers
The problem with the constant heat was either the centrifugal switch in the motor or a grounded heating element. The grounded heating element is easy to check for using you ohm meter-- just measure the resistance from one of the heating element terminals to the heating element case. Should read open (infinite resistance). If that checks out ok, then you most likely need a new motor-- would need to feast my squinties on the wiring diagram for your dryer to be certain.
dont forget rate this post
    Guru:
  • 1,894 Answers
Have you left the unit unplugged for one night and tried to start??
doe sit make any humming noise when trying to start
  • dewan nafees ahmed Aug 25, 2008
    Plug
    something else into the same outlet. If it works, you know you have
    power to the dryer. If it doesn' t work, you'll need to check for any
    blown fuses or tripped circuit breakers. Electric dryers should have
    the wiring checked at the terminal block to make sure that the
    connection is good, or to verify that the connection is burnt out.
    If the power is there, you will want to check the door switch,
    thermal fuse, thermostats, and start switch to see if one of these is
    faulty. Make sure that the control settings are appropriate, and that
    any buttons are fully depressed. Make sure that the start button has
    been fully pushed down or turned far enough to activate the dryer.
    The door or lid switch performs two main functions. When the
    dryer
    door is open, it keeps the dryer from starting, and turns on the light.
    If the door switch is faulty, your dryer won't work, and you'll need to
    replace the switch. The door switch is located inside of your dryer's
    main housing right by the door frame. You'll probably need to access
    this switch through the top or front of your dryer.
    There may also be a problem with the start switch. Test and
    replace if it is faulty.
    Many dryers use what's called a thermal fuse. This is often
    mounted
    within the exhaust duct in the back panel. This fuse is about an inch
    long, and is usually found within a white plastic housing. Your dryer
    will not operate if this fuse is defective. You can test this fuse, and
    if faulty, replace it.
    Most fuses have a thin wire that conducts electricity. When
    fuses
    blow, it means the wire is broken, they have no continuity and no power
    will flow through it. When this happens to the thermal fuse, your dryer
    either doesn't work at all, or it stops heating. Give your vent and
    heating system a visual check before you replace this fuse.
    You will also want to test each thermostat to determine if any
    one
    is faulty. A bad thermostat may prevent your dryer from working at all.
My Whirlpool gas dryer is not working
Instructions
Check that the dryer door is closing completely. Remove anything that blocks the dryer door from closing.
Ensure the "Start" button is pressed firmly to start the dryer cycle, the dryer is not overloaded and the clothing is not balled up. Any of these things can prevent the dryer from operating and/or drying the clothes.
Use a level to confirm your Whirlpool dryer is sitting flatly and evenly on the ground. Adjust the dryer as necessary for it to be level as the dryer will vibrate and make unnecessary noise when sitting unevenly.
Examine the inside of the Whirlpool dryer drum and in the space around the drum for loose change, pens, hair ties and other items that could have been left in the pockets of clothing. These items will cause noise and potentially cause the dryer to become inoperable.
5
Examine the Whirlpool dryer's lint trap for excess lint. Remove any lint from the trap and place it back into position. Always clean the lint trap between dryer cycles. Inspect the area around the dryer and in the ventilation and exhaust systems. Remove any built up lint and clean the area thoroughly. Built up lint is a fire hazard and can cause operating issues.
6
Check the gas shutoff valve if your Whirlpool dryer is gas powered. Ensure the shutoff valve is turned all the way to the "On" position.
7Check the electric plug and ensure it fits securely in the outlet.
8
inspect both the fuse box and circuit breaker for any electrical problems. Replace any blown fuses, if necessary, and reset the circuit breaker if it has been tripp
Jan 09, 2013 | Whirlpool Dryers
Dryer not heating
If your dryer won't heat up, it's possible that it is not being supplied with the proper voltage. Here are three ways to make sure power is getting to your dryer: First, make sure your dryer is plugged in. Next, check the circuit breaker panel to make sure all the circuit breakers are in the correct positions. Finally, check to make sure no fuses in your fuse panel are blown. Any of these could explain why power is not getting to your dryer.
Thanks.
May 16, 2012 | Kenmore Dryers
No power
Proper Voltage from the House
Your dryer may not be receiving adequate voltage to start. Make sure your dryer is plugged in. Also, check the circuit breaker panel to make sure all the circuit breakers are in the correct positions. Or check to make sure no fuses in the fuse panel are blown. Try plugging something else into the same outlet. If it won't work either, then there is likely something wrong with the power outlet. Any of these could be the reason power is not getting to your dryer. Also, refrain from using an extension cord to plug your dryer in.
If your dryer's door switch is defective, it will not allow your dryer to start. Test your dryer's door switch. If it is defective, replace it.
check the thermal fuse in the back of the machine,, remove the back you'll see it
Jun 05, 2011 | Dryers
My Whirlpool dryer is plugged in but will not turn on
I would start by checking to make sure the circuit breakers are not tripped. An electric dryer runs on 220 and will have a double circuit breaker - a gas dryer runs off of 110 and will usually not have a dedicated breaker. Once you have determined the power is on, the next most likely problem is the door switch. This prevents the dryer from being activated with the door open. You can "jiggle" the switch while attempting to start the dryer, or check the continuity with an ohmmeter.
Jul 20, 2009 | Whirlpool Dryers
Dryer wont start
your dryer may not be recieving adequate voltage to start.
also check the circuit breaker panel to make sure all circuit breakers are in the right position.
check fuse box for blown fuse.
try plugging in something else in the same outlet.
also refrain from using an extension cord.
Mar 04, 2009 | Whirlpool GEW9200L Electric Dryer
Whirl pool dryer LEC9000PW0 will not turn on
Has a household fuse blown or has a circuit breaker tripped?
There may be 2 household fuses or circuit breakers for the dryer. Make sure both fuses are intact and tight, or that both circuit breakers have not tripped. Replace the fuse(s) or reset the circuit breaker(s). If the problem continues, call an electrician.
Is the correct power supply available? (Electric dryers only)
Electric dryers require 240-volt power supply. Check with a qualified electrician.
Is the dryer door firmly closed?
Your dryer door may not be fully closed. It may look shut, but may not be latched. Push on the door to engage the latch or latches. Some models have an upper and lower latch. Both latches must be secure for the dryer to run.
Was the Start, Push to Start or Hold to Start button firmly pressed?
Large loads may require the Start, Push to Start, or Hold to Start button to be pressed and held for two to five seconds.
Is the Cycle Control knob set on a Sensor Dry or Timed Dry cycle? (on some models)
The Cycle Control knob must be set in a Automatic Dry or AccudryTM or Timed Dry cycle. The dryer will not start if set on the Wrinkle ShieldTM option.
Is Controls Locked status light on? (on some models)
Press and hold the Cycle Signal button for three seconds. This will turn off the Controls Locked feature.
Did you recently install a power supply cord on the dryer? (Electric dryers only)
The power supply cord may be incorrectly installed. If the power cord is incorrectly installed, the dryer may not start or heat. Review the Installation Instructions to check that the power supply cord is properly installed.
Dec 02, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Dryer will not start
Nov 13, 2008 | Whirlpool GEW9250 Electric Dryer
Whirlpool dryer will not heat properly
i am sending you all the possibilities for your problem, check either of these causes ----and than let me know if it is solved----
Power from the house
Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected.
Heating element
Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
Thermal fuse
On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Wiring
A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
Oct 17, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Frigidaire GLEQ642A Electric Dryer Logo
227 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
