Question about Apple Ipod Nano Second Gen. Green (4 GB) MA487LLA MP3 Player
Iopd wheel not responding
Ipod nano is stuck on chose language. followed all the 5 Rs. tried holding all buttons at once nothing. It is fully charged.    Shortly after updating my 2nd generation 4GB iPod Nano with the 1.3.1 software, I noticed that I couldn't use the iPod wheel. I can hook up devices via the charging port (e.g., in my car) to hear the music, but I can't use ear buds via the aux port because the wheel doesn't work to press play. I tried to reset it via the menu and select button - no luck because the wheel isn't responding. I toggled the hold switch a couple times - no luck. I restored it through the computer to it's original factory settings, and it still won't work (and now it's stuck at the language screen). And of course my warranty ran out about 6 months ago. Has anyone contacted Apple about this since there are so many of us? Or anyone else come up with a solution besides taking iPods apart?
  • lilmoneybank Oct 30, 2008
    the ipod turns on after i unplug it but the ipod wheel will not work at all
  • 89 Answers
Check this website for the forum and there are people that has a few tricks to make it work
http://forums.ipodlounge.com/showthread.php?threadid=151974
but it is not a guarantee.. chances are it might be a mechanical problem with the device already.
Posted on Aug 25, 2008
4 Suggested Answers
  • 36 Answers
SOURCE: iopd wheel not responding
Send it in. Call apple or go to  https://selfsolve.apple.com/GetWarranty.do
Posted on Jan 11, 2008
Agent Aaron
  • 265 Answers
SOURCE: Only the left ear bud has sound
Hey NoRightSound,
If your earbud headphones function normally with other devices, there are a number of reasons why this problem may be occurring, including faulty connections within the iPod itself or a potentially defective headphone jack. While both of these issues can typically be resolved fairly easily, I would first suggest contacting your local Apple-authorized service center for a complete diagnostic to pinpoint the exact cause of the problem.
Remember that if your iPod is still under the original manufacturer's warranty, you can always call Apple directly for technical support over the phone in addition to working with a technician in your area.
Hope this helps you out.
Sincerely,
Aaron
Go Ahead. Use Us.
Posted on May 30, 2008
I have the same problem and since mine was out of warranty, I decided to try and fix it. I ordered a new ipod nano wheel from ebay for roughly 15 dollars. Search youtube for how to open your nano, which is pretty straightforward. Not as difficult as I thought actually. You can then remove the wheel circuit pad and replace it. It peels right off of the plastic part of the wheel and the metal back part also peels off. They used some sort of sticky back tape, which sounds bad when you try to take it off, but reallty not all that bad. Mine is Gen1, so yours maybe different, just be sure to search fro the right model.
Posted on Jul 08, 2008
Instruction manual
Which model ipod ??
In keeping with Apple's goal to make user-friendly, streamlined products, the designers of the iPod built in easy-to-use reset functions into each iPod model.
Resetting the iPod is similar to rebooting a computer as all songs and data stored on the device stay there, and only temporary information (such as which song is playing) gets reset.
Follow these steps to reset an iPod.
Toggle the "Hold" switch to the "On" position, then "Off."
The "Hold" switch is the small sliding switch on the top of the iPod.
Move it to the "On" position to show an orange rectangle. Move it back to the "Off" position to show a white rectangle.
Hold the "Menu" and "Center" buttons.
Press the 2 buttons at the same time for between 8 and 10 seconds.
Your screen will go blank and then boot up with a dark Apple icon.
The icon eventually turns bright and brings you back to your main menu once the reset is complete.
Check your iPod to make sure it plays properly. If the iPod still does not work repeat the reset process.
Scroll Wheel and Touch Wheel iPods
Move the "Hold" switch from "On" to "Off."
Press the "Play/Pause" button and the "Menu" button at the same time.
Press both buttons together for approximately 6 to 8 seconds.
This initiates the self-running reset process.
Make sure the reset was successful.
If problems persist you may need to perform the reset process once again.
iPod Nano
Move the on-off switch to the "Off" position that shows the green strip.
Leave the iPod Nano in this position for 5 seconds.
Move the switch back to the "On" position.
Use your iPod Nano to make sure the reset worked properly and all your music is intact.
Aug 06, 2013 | Starlite Nextplay Fashion iPod Docking...
Ipod nano click wheel is frozen. followed all the standard steps on apple support site and still no good. stuck frozen on ''choose language'' and click wheel does not respond
First make sure the lock is not on. Second, I have read in a number of threads people have tried putting scotch tape over the wheel and it started working. I know it sounds crazy but it's worth a try. Otherwise I would say you have a hardware issue and should contact Apple if it is still under warranty.
Jan 10, 2010 | Apple iPod nano
Ipod is stuck on the language screen. Scroll
push center and menu button same time
Jul 25, 2009 | Apple iPod nano
Ipod not responding
You may be doing the reset wrong. Try doing this: Toggle the hold switch and put it back in the off position. Then press and hold the center button and the menu button simultaneously for ten seconds and the apple symbol should come up on the screen. Then it should work like normal. Hope this helps you!
Apr 18, 2009 | Apple iPod nano
My i-pod nano chromatic 8 GB is stuck!:S
Press and hold the Menu and Centre buttons at the same time until the apple logo appears. (This usually takes between 5 and 10 seconds.)
Information from: http://ipodsurgery.com/reset-frozen-ipod
Feb 01, 2009 | Apple iPod nano MP3 Player
Change language to english
You have to reset your iPod. (Note: This is for the 3rd generation iPod Nano)
To reset iPod nano:
1 Toggle the Hold switch on and off (slide it to HOLD and then back again).
2 Press and hold the Menu and Center buttons for at least 6 seconds, until the Apple logo appears.
If iPod nano won’t turn on or respond
- Make sure the Hold switch isn’t set to HOLD.
- The iPod nano battery might need to be recharged. Connect iPod nano to your computer or to an Apple USB Power Adapter and let the battery recharge. Look for the lightning bolt icon on the iPod nano screen to verify that iPod nano is receiving a charge.
-Logan
Dec 22, 2008 | Apple iPod nano
Dec 20, 2007 | Apple iPod nano
Ipod frozen on language screen
you have to hold the the menu and middle ong for 10-20-30 secs
hold the menu +center button and it will turn off and reset
Nov 24, 2007 | Apple iPod nano
to be honest with you all you all have the same problem so id get in touch with apple.com exsplain your problem and see if they can help as it seems it a fult on there part with seven pepole with the same model all have the same problem/ if not id take them back if under waranty and try a nother model
Nov 01, 2007 | Apple iPod nano
Apple Ipod  Nano Second Gen. Green (4 GB) MA487LLA MP3 Player Logo
607 people viewed this question
Top Apple Audio Players & Recorders Experts
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
