Question about Scanport 610A 14 in. Flat Panel LCD Monitor
Gem PD-70FA monitor
I am looking for a power supply for this monitor. Can anybody give me some help finding the right aftermarket plug.
Thanx,
Craig
3 Suggested Answers
  • 3278 Answers
SOURCE: Need user manual
Hi, Anita.
Here's a link to Softpedia's Sampo Driver pack:
http://drivers.softpedia.com/get/MONITOR/SAMPO/Sampo-LCD-Driver-Pack.shtml
Select the smaller icon "Download".
Hope this helps.
Posted on Aug 03, 2009
budmrtn
  • 11361 Answers
SOURCE: Help. I'm attempting to plug in my GEM GL1920S
This monitor uses an AC adapter12vdc. 5A: http://lcdpayless.com/productpage.php?productId=3872
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
Posted on Sep 30, 2010
I am looking for a power plug for my gem monitor #LCAO1F D3350382G
On eBay or Google Product Search or Amazon, search
GEM GL-822 power
or
GEM GL-822 12V 5A
There are a number available there. It is 12V DC, 5A
Apr 19, 2011 | 3G Technology GEM GL-822A/B 17" Flat Panel...
Someone gave me an old Sylvania monitor (L15) Model no. PD-70FA but the 12V DC power cord is missing. It is not a standard type of powervcord and none of the stores I've been to (Staples, Office Depot,...
The power chord for this monitor is attached to a power adapter which converts mains voltage to 12 volts.
Check the power label on the monitor for the amp rating of the monitor and get an adapter that has an output of 12 volts and with the amp rating on the label or higher. Make sure the 0.3" power plug fits the monitor.
Feb 26, 2011 | Computers & Internet
WHERE CAN i GET A POWER SUPPLY CORD FOR THIS PRODUCT
Are you looking for the cord that plugs into the the electrical outlet that connects to the external power supply? Or are you are looking for the external power supply as well? If you are looking for just the cord itself, they should be common item that you should be able to purchase and any appliance store.
If you are looking for the cord and the external power supply, there are many online outlets that you can look like ebay, etc. You need to search for a 15 Volt 4 amp universal power supply. I would recommend the universal power supply since it will come with multiple adapters plugs so you should be able to find the right one to fit your monitor. Also note the polarity of the the plug otherwise it might damage your monitor.
Jun 30, 2010 | Advueu Technology ADV1901B (Black) 19 in....
Power Issues!
The AC adapter will go into shut down mode if the monitor is drawing too much current due to short circuits in the monitor, but it can also be bad caps in the power supply itself. You can try new adapter or check inside the monitor for shorted components.
Apr 24, 2010 | Scanport GEM GL-821A/B 17" Flat Panel LCD...
I have a GEM 17" with power issues!
Sounds like your power supply capacitors are causing the power supply to shut down. Or you have a short in the monitor loading the power supply. You should try a different power supply.
Monitor Mike
Toshiba P105, backlight dont turn on in my lap
If the LCD, inverter etc works in anothe laptop but not in the original laptop then it looks like a motherboard problem, possibly the power supply to the inverter.
Oct 11, 2009 | Toshiba Satellite P105-S921 Laptop PC...
Need user manual for Sampo 15'' lcd monitor - PD-70FA-16T
Hi, Anita.
Hope this helps.
Aug 03, 2009 | Sampo Computers & Internet
Power supply
Johnny... I have that power supply, and my PD-3015 no longer works. Email me at:
lanca@charter.net
I'll fix you up. bill
Jul 31, 2008 | Astar PD-3015 Portable DVD Player
Ac power cord for HP vf51 flat panel monitor
Good Day Tricia,
I had to pull up you owner's manual to get the spec's on your cord, so if you need the manual follow this link:
http://h10032.www1.hp.com/ctg/Manual/bph08231.pdf
Anyway after reading the spec's you need an AC-DC power supply that outputs 12volts at 3.3amps. What makes this difficult to find is the 3.3amps, most aftermarket power supply only go up to 2amps. So what's next? Well you can order directly through HP at this link:
http://partsurfer.hp.com/cgi-bin/spi/main?sel_flg=partlist&model=P4824A&HP_model=&modname=HP+vf51+15-inch+LCD+flat+panel+display&template=main&plist_sval=Power+Cord&plist_styp=subcat&dealer_id=&callingsite=&strsrch=&keysel=Power+Cord&catsel=%3F
If you do this make sure get part 8121-0740 if you live in the states, or part 8121-0731 if you live in europe.
The only other suggestion I can give is to bring the monitor into a radioshack and see if they have a 12VDC 3.3AMP (you can get a universal with higher amperage if needed, the monitor will only draw the 3.3 it needs even if it is supplied more) and the reason I say bring it in is so they can match the size of the plug that goes into the monitor, as there are about 20 diffrent diameters's. Again the problem you may have is finding one with a high enouge amperage.
I hope this helps
Good Luck
Jul 01, 2008 | ViewSonic VA720 17" LCD Flat Panel Monitor
Scanport 610A 14 in. Flat Panel LCD Monitor Logo
105 people viewed this question
Top Scanport Computers & Internet Experts
William Miller
William Miller
Jerry Umali
richie46
Are you a Scanport Computer and Internet Expert? Answer questions, earn points and help others
