Question about GE Profile PSW26P Stainless Steel Side by Side Refrigerator
Refrigerator Door Lost Suction
The refrigerator side door of this model is not closing properly, causing it to fill with ice and persperation. Can't figure out why.
  • Anonymous Sep 21, 2008
    Door will not **** close like it use to
  • pussycat123 Dec 23, 2008
    refridgerator door is not closing properly so I was told to use a little vaseline on it but it hasn't helped - what can I do?
I have a GE Profile Stainless Steel side by side. I also noticed that the refrigerator side door was not sealing like it had previously. There was no "suction" when opening. I started inspecting the gasket around the door to see if this needed replaced, as I had read that may be the problem from this forum. My particular model has the grill / vent at the bottom of the door, in the front, which just pops off. I found that down by the grill my model has magnets there that match up with magnets on the bottom of the doors. I inspected this and found a foreign object had attached itself to this magnet. I removed this object and waaahlaaah the door now has suction! I was relieved to find that I didn't need to replace the gasket. Worth a try. Hope this helps.
Posted on Dec 07, 2012
  • 65 Answers
SOURCE: Refrigerator suction/vacuum noise, rear section when freezer door is closed
there is no suction system. flush your defrost drain tube with boiling water and a turkey baster. should get some pretty nasty sludge out and sound will go away.
Posted on Feb 16, 2008
  • 82 Answers
SOURCE: kenmore refrigerator door seems to be crooked
Hello joejanehen,
You can usually take off the top cover of the upper hinges, loosen the hinges with a 5/16 socket and move the door around that way. If this doesn't work then the door may need to be removed and have new door cams installed on the bottom hinges.
Another way to make the door shut better is to lower the front wheels or legs so that it will tilt back slightly.
Hopefully this helps.
Sincerely,
shays5415
Posted on Dec 03, 2008
joboo1
  • 257 Answers
SOURCE: Refrigerator Door not closing properly
Hi, No the door is not adjustable like you might think Since it is smaller than the other door any alignment problem is really visible. First do check the bracket to make sure you didn't lose a screw and that the brackets are solid and don't move. The problem is the level of either the refrigerator or the floor. If you have a 3 ft bubble level put in on the top of the refrigerator along the front, NOT on the door. There are feet on the bottom front corners of the refrigerator, you may have to remove the plastic grill to access them but depending on the model and age of your refrigerator it should be attached with clips. The feet screw in and out but with weight they won't move easily so you may have to jack the front a little, remove some stuff or try a crescent wrench. Once the front is level check the front to back, the refrigerator needs to tilt slightly to the rear so the door when partially open will close by itself. Again you didn't give a model so on some the rear feet are not adjustable and some are. I suspect you may have adjustable and the box is not squared up. If after adjusting the front and the entire refrigerator tilts like an uneven table leg then you have to adjust the feet likewise. Use your level diagonally across the top both directions, it should be exactly the same. If you have non adjustable and they are uneven it is the floor and you have to use shims under the low foot. Good Luck!
Posted on Jan 30, 2009
  • 10 Answers
SOURCE: sub-zero 500 series refrigerator door wont stay closed
If Your Refrigerator's Freezer Door Pops Open When You Close the Fresh Food Door... If a 'top-freezer' refrigerator's freezer door pops open when the larger fresh food door's closed, it's actually a good thing. That tells us the seals are in great shape, sealing well.
Some freezer door 'pop' is unavoidable bc the bottom door's so much larger than the top one and the hydraulic effect of compressing all that air kicks in. The two compartments share the same air via a duct between them, and that compressed air rushes up into the freezer compartment and can 'pop' the door.
To improve the situation, apply a few drops of oil (sewing machine oil or 'three in one' - NOT WD-40) to each freezer door hinge pin. (Even better: if you can, pull the doors and coat the hinge pins with petroleum jelly). This will help the freezer door swing back closed by itself. The freezer door usually stays ajar because it's binding a bit, and that's usually caused by it's swinging 'dry', with no lubrication.
It’s also a good idea to ‘kick’ the habit of letting the refrig door close hard.
Posted on Feb 11, 2009
  • 56 Answers
SOURCE: Refrig door gasket does not prevent gap when door is closed
Lift up the gasket and look for screws securing the gasket to the door.
Loosen all of these screws a few turns and twist the door in the direction needed to seal.
Hold the door in this position as you tighten the screws.
This can be tricky and sometimes requires multiple efforts.
Posted on Apr 03, 2009
GE Profile side by side refrigerator. The freezer side started to have leakage and caused frozen ice along the walls & Extreme suction on freezer side.
Not sure on this one, but many freezers draw a vacuum like that for a little while to try to get all of the air and moisture out. Commercial units are designed that way. If Ice is building up, there is most likely an air leak. Check the door gaskets and see if they are sealing up properly.
Aug 02, 2016 | GE Refrigerators
I have a Frigidaire side by side refrigerator, model # FRS26LH5DQ5. When the ice maker fills with water, water also comes out of the water dispenser on the front of the left door. What is causing the...
HI, TO ME LOOK THAT YOUR REFRIGERATO HAS A BAD ICE MAKER, BUT IF YOU REFRIGE IS OVER 5YEARS OLD REPLACED THE ICE MAKER AND SELENOIDE WATER VALVE ,100%PROBLEM REPAIR..
Feb 21, 2011 | Frigidaire Side by Side Refrigerator 26...
Sub zero refrigerator model 532 problem the freeze is warm on the top but the ice & items below the ice are OK. i suspect that the light may be always on. also the freezer door does not make its...
I suspect a bad fan motor, door switch, or not defrosting.The suction when door closes is caused by the low temperature created when working properly.
Feb 14, 2010 | Freezers
Ice is forming around the auger under the ice bin. constantly have water dripping from ice cube shoot
the door that the ice comes down to fill glass is not closing; the ice chute door just above the lever to fiil glass with ice it is either jamed with ice or is broken and needs a new repair kit.you can inspect by opening door and look at approx. 3 inch door that ice falls threw to see if closed.warm air causes ice to form.
Sep 07, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ice depensing door will not close on LG model LSC27926ST
It is probably frozen in place. The old ice tray bend and spils in the Ice Bin and eventually leaks out that door. Have you changed the ice tray with the update? This might fix your problem. Do you know if the door has illumination for the buttons? Mine doesn't and I think there should be somethng cause it is hard to read the buttons in the dark.
Sep 07, 2009 | LG LSC26905TT Side by Side Refrigerator
Ice cube flap door
try this site...input your model # and look for the ice door parts. Maybe a bad spring. They are also very helpful with their chat and phone assist., video repair etc. Make sure to get the model # though.
https://www.repairclinic.com/RepairHelp/How-To-Fix-A-Refrigerator/62-5-1414685-/Whirlpool-Refrigerator-ice-maker-overflowing-WRX735SDBM00?r=%2fShop-For-Parts%2fa4b5c21i2659d1414685%2fModel-WRX735SDBM00-Whirlpool-Refrigerator-Gasket-Seal-Door-Gasket-Parts
Best to you.
Oct 22, 2017 | GE Refrigerators
Freezer door won't seal
its a visual thing inspect and look for somthing not right[ie..door seal torn,door warped.hinge cam broken.somthing in the way food package wise so door wont close.God bless,tom
Jan 01, 2009 | Maytag MSD2732GR Side by Side Refrigerator
Amana 22 side-by-side refrigerator, freezer door opens slightly
There are three possibilities to this problem:
1. Door seal which should be magnetic is faulty.
2. Ice maker caddy (container) has not socketed properly into ice maker rear drive tang.
3. Door stay closed plastic hing pieces are damaged. These are tapered pieces that fit in hinge area that allow door weight to help close and hold door. Some are black in color and some are white. As far as I know they are interchangeable.
Jul 17, 2008 | Amana 22.6 cu. ft. Side-By-Side...
Side by side
Suction at door is caused by the rapid reduction in air volume after you have had a freezer door open and then close it. The refrigerator door side does not have as pronounced air reduction volume due to less temperature difference.
Test you door gasket seal by closing the door on paper (dollar bill) works fine. If you have resistance when sliding or pulling on the paper you have a good seal. No resistance means your door is not sealing properly.
Apr 29, 2008 | Frigidaire FRS23H7C Side by Side...
Side by side refrigerator
The ice maker is not producing ice or not enough ice
 Refrigerator connected to a water supply and the supply
shutoff valve turned on?
Connect refrigerator to water
supply and turn water shutoff valve fully open.
 Kink in the water source line? A kink in the line can reduce
water flow. Straighten the water source line.
 Ice maker turned on? Make sure wire shutoff arm or switch
(depending on model) is in the ON position.
 New installation? Wait 24 hours after ice maker installation
for ice production to begin. Wait 72 hours for full ice
production.
 Large amount of ice recently removed? Allow 24 hours for
ice maker to produce more ice.
 Ice cube jammed in the ice maker ejector arm?
Remove ice from the ejector arm with a plastic utensil.
 Reverse osmosis water filtration system connected to
your cold water supply?
This can decrease water pressure
OR
The water dispenser will not operate properly
 Freezer door closed completely? Close the door firmly. If it
does not close completely, see “The doors will not close
completely.”
 Is the water pressure at least 30 psi? The water pressure to
the home determines the flow from the dispenser. See “Water
Supply Requirements.”
 Kink in the home water source line? Straighten the water
source line.
 New installation? Flush and fill the water system.
 Water filter installed on the refrigerator? The filter may be
clogged or incorrectly installed.
 Is a reverse osmosis water filtration system connected to
GOOD LUCK TO YOU!!! LET ME KNOW IF THIS SOLVED YOUR PROBLEM
Jan 31, 2008 | Whirlpool ED2FHEXN Side by Side...
GE Profile PSW26P Stainless Steel Side by Side Refrigerator Logo
688 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
