Question about Nokia 6500 Slide Cellular Phone
Ringtone Problem! My n6500s has this one problem, it always reverts back to the nokia standard tone from the one i set, even the ringtone set for my contact group also reverts back to the nokia standard tone, why is that? is there a setting for me to change? P.S any other tips and tricks for this phone?
  • pwrigz Mar 25, 2009
    My Nokia 6500 slide keeps reverting back to the default settings in my profiles.  I will change to my ringtone etc but then with 24-48hrs in reverts back to the default ringtone.
  • ekkamnply May 11, 2010
    please help u meeeeeeee
    this problem!!
The reason for this as I learnt last week is a small switch which is operated by placing the back cover on the phone. Its a 'safety' feature apparently. If you have a picture or ringtone set from the memoery card relese the back. (you will notice it reverts everything back to factory settings. Now do the same but make sure the tone and pic that you use is stored to the phone memory not your card.....presto!! it stays on and dosent revert. People around the globe think its a software bug when actually its not. It prevents you losing data from your memory card. I am currently trying to find out if this feature can be disabled. Its stupid, I know!!!!!
Posted on Oct 23, 2008
This is a known manufacturing fault, i have just had mine repaired by nokia,
Posted on Sep 17, 2008
If you knock the phone or drop it, any ringtones, wallpapers etc in use will revert back to factory IF the said ringtones, wallpapers in use are stored on the memory card, transfer the tones and wallpapers you wish to use onto the phones internal memory and this should then stop the problem.
Posted on Sep 06, 2008
  • Nokia Master
  • 1,800 Answers
Hi there.
ur problem might be referd to a damaged or corrupted phons Firmware.
or just a miss set up
try to give ur phone a Format this is might be helpfull but u need to back up messges/contacs/photos/viedos.
to format press:
* plus # plus 3 plus green call key plus POWER
phone shud be off
- or u can try first the *#7370# then 12345 this is restore the CP to factory defaults
that was a tips i guess hehe..
any way rate this post if u can its easy click on fix ya
Posted on Aug 25, 2008
How to change call ringtone on nokia e63
Hi Violin,
I have this steps for you for work around setting up call ringtone. Hope it helps.
--- there should be no prob to set a custom tone if you go to the tone and select options you should get an option to select from a list from the menu otherwise go to profile and select edit then when you come to ringtone select options and you will get options you should be able to select a tone from the gallery
---I discovered something about this problem. It appears that if you have the same phone number assigned to two (or more) contacts the ringtone plays the default ringtone. Once I deleted one of the contacts with the same number, it played the correct custom ringtone. What is strange is that both contacts had the same ringtone. BTW, the reason I had done this was to simplify the voice command to make a call to this contact.
Apr 25, 2014 | Nokia E63 Cell Phone
Nokia x3-02 ringtone
Go to tones and just set the ringtone.
Jan 30, 2014 | Nokia Headset For C5-03 / X2-01 Hands Free...
How do I personalise message tones for nokia lumia 610??
Well dear, there is no procedure to personalize the desired tones as ur message tone, u can only change the tones that are pre-loaded.
but yes for making a caller ringtone, u have to use Zune software. change the attributes of ur desired ringtone. set the genre of the tone as 'ringtone.' thats all
Jun 25, 2012 | Cell Phones
How to set music as your message tone
You can't change the messaging tone to a song from your music playlist, these options for choosing your own music as ringtones are restricted to an alarm tone, phone ringtone and caller ringtone (caller ringtone is when specific people calls you, a certain ringtone would appear for that caller to differentiate between callers)
Thank you for using FixYa!
Feb 13, 2011 | Samsung Galaxy S GTI9000 Smartphone
How can i change ringtone in nokia n900
From menu, go to settings, then on personalization click the profiles and then click the Ringing Tone button. Choose one of the available tones there or click the MORE button and locate an mp3 you have on your phone. select it and click Done you are ready with your new ringtone
Apr 26, 2010 | Nokia N900 Smartphone
Ringtone
it should be as simple a going into profile select customize then edit pick the song you want and save,,,,,,but hope your changing your voice ringtone,, and not the one that say video ringtone there are right below each other if your changing a ringtone for a specific person ofcourse you must be in contacts,, edit,,, then scroll down and change the default ringtone and save,,,hope it helps.
Jul 29, 2009 | LG KU990 Viewty
Ringtone problem
hey buddy go t user profile , select any prfile u want n den go t customize , go to tone setup, select if u hav dual sim n den go to empty ringtones n u'll hav option of selecting ringtone from card n select tone u want n den select n option of replace n den set it
Jun 08, 2009 | Handmark Software MobileLists (950142) for...
Ringtone, i set it as, won't work for sms
Try this.
Go to PROFILES.
Select ADVANCED.
Select (ie) NORMAL.
Scroll to SMS TEXT and depress the pearl ball.
Select OUT OF HOLSTER and set to TONE.
Select RING TONE and select the tone you want.
Select VOLUME and set to your preference.
You might want to do the same for IN HOLSTER.
Good Luck! ~ :)
Apr 29, 2009 | RIM BlackBerry Pearl Flip 8220 Cellular...
Have nokia 3120 , incoming call does not rings
check if the format of ringtone set is compatible with your phone..
try to restore the refactory settings once.
thankyou.
Nov 19, 2008 | Nokia 3120 Cellular Phone
Ringing Tone
Just copy the ringtone in phone memory which you want to set. It will give you option to set it as ringtone.
Jan 17, 2008 | Nokia 6600
Nokia 6500 Slide Cellular Phone Logo
117 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
