Question about Car Audio & Video
Parts for my MB Quart RAA1000 amp
Hello. I'm trying to ask anyone I can. I need a power/ground/remote turn on plug for this amp. do you know where I could get one? thanks
  • leblanc78 Aug 25, 2008
    I put an email into MB Quart today so hopefully they reply back this week. Do you think they still have the part. There newer lines of amps look almost exaxctly the same. Do you think they nay stilluse the same plug thing? thanks
  • 631 Answers
I think it was custom made for MB Quart. Have you tried contacting the, to see if it is still available?
Posted on Aug 25, 2008
  • Perry Babin Aug 25, 2008
    I've only seen a few of the older amps so I don't know if the new ones will work with the older amps.
    Post what you find from MB Q. It may be helpful to others.
MB QUART WIRED REMOTE WRC-S1 NOT WORKING
test the LED hit any key viewing with digital or cell digital. see the diagram THE LED must be TURN ON, if not open the remote and clean the keypads contacts from dirty+corrosion+bad contacts+clean the contacts battery too and replace by new ones.Try it again.
God bless you
Jul 14, 2013 | MB Quart WRC-S1 Round Wired Remote Control
Need help trying to locate.the Power and speaker plugs for Mb Quart RAA1000 monoblock 1975 Car Amplifier.
I am assuming you are referring to the actual connectors/plugs that are needed to wire the MB Quart RAA1000, a complete wiring kit is available here. It includes patch cord, power cable, grounding cable, turn-on lead among others.
If you want a pictorial layout of the wiring and connectors, the owner's manual would be of help and is available here.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Jul 09, 2008 | MB Quart Car Audio & Video
I have an old soundstream reference class a 5.0 and a set of mb quart pwe 254 10 duel voice coil subs. i would like to know how to wire this set up for the most power. parrallel the voice coils then run...
The Soundstream Class A 5.0 will deliver its full power at 1 ohms mono.
I think your subs are two dual 4 ohm voice coils.
If you wire the voice coils for each sub in PARALLEL, that's 2 ohm for each sub. To get 1 ohm mono, you need to hook up the subs in PARALLEL to the amplifier, in bridge mode. That's the way to get to 1 ohm mono. Please add a fan to your setup as the amplifier will get very hot. You will need to use a relay to hook up the amplifiers and fan(s) to or you will damage the remote ouput of your HU (if you hook up the fan straight to the remote of the HU) as the remote output of the HU is not designed for the amount of current a fan draws.
Good luck. If you need help with the relay issue, have a look here: http://www.caraudiohelp.com/newsletter/multiple_amplifiers.htm
Jun 27, 2011 | MB Quart PWE-254 Car Subwoofer
What are the specs,rms ect on my older mb quart psc 216 speakers
Any type of 4 channel amp that will allow the speakers to be hooked up at 4ohm. I would check your local walmart. The brand VR3 are made by Rockford fosgate as well as lighting audio. From what I have heard they are some really good amps at affordable prices. If you are looking to spend some money I would recommend a JL Audio e2150
Oct 28, 2009 | MB Quart Car Audio & Video
Amp flashes red light only, no other power seems to work on amp
Hello markrich78,
First determine if it is the amp or the wiring that is causing the problem.
Disconnect all wiring except ground, power and remote turn-on and see if the amp powers up properly. If it doesn't, the amp itself is defective and needs professional repair or replacement. If the amp powers up OK with just ground, power and remote turn-on connected, check all of your other wiring for shorts and grounds, or reconnect them one at a time.
Hope this helps.
Sep 19, 2009 | Kenwood Car Audio & Video
Amplifier turns on but not the subwoofer?
Hello thedj3214,
You can find the color codes for a 1999 Buick Regal here. There is no dedicated amp remote wire. Neither is there a power antenna wire.
You could use the 12V "switched lead (yellow) from the radio or any switched 12V lead directly from the vehicle fuse box. I'd wire it through a dash mounted toggle switch so as to be able to turn the amp on and off manually.
The Sony 2150GSX is a 2-channel amp with the speaker terminals on either side. You do not want to ground the subwoofer itself, only the ground terminal should be connected to bare metal on the vehicle chassis or body as close to the amp as possible. The ground wire does not need to be run to the negative battery terminal.
A ground on one of the speaker leads will probably cause the amp not to power up. A ground on a speaker wire usually activates the amps protection circuit, causing it to not operate until the fault is corrected.
Hope this helps.
Jul 28, 2009 | Sony XM-2150GSX Car Audio Amplifier
My amp is not powering up anymore
take the amp out the trunk and connect directly to the battery, use a jumper wire for the remote from the constant power 12volt , if the amp fail to turn on it may be damage. check the fuses and look for any burnt connection.use a test light to test for power at the connection.
Aug 30, 2008 | MB Quart RAA1000 Car Audio Amplifier
Amplifier won't turn on
You need to confirm that you have voltage on the B+ and ground terminals and have a good ground.
With your multimeter set to DC volts, the black meter lead on the ground terminal of the amp (not on the point where the ground wire connected to the vehicle) and the head unit on (so the amp will have remote voltage applied), touch the red lead alternately to the B+ and remote terminals of the amp. If the voltage is below ~11 volts, you need to check the wiring feeding whichever line is too low.
If all of that checks out, the amp probably has an internal fault (blown parts, broken connections...).
Let me know if you have any other questions.
Aug 24, 2008 | Pioneer GM-X324 Car Audio Amplifier
Can't find Power and Speaker Plugs For Mb Quart RAA1000 1975 mono block Car Amp.
Probably not. The best thing you can do is either contact MB directly or go to a shop that sells that amp and ask them.
Jul 09, 2008 | MB Quart RAA1000 Car Audio Amplifier
Amp powers on, but stays in protect mode
Shorted output transistors are the most common reason for amplifiers to go into protect. How much do you know about electronics/electronic components?
If you're a newbie, read THIS page.
Would it be possible to send me a set of high quality photos of the amp's internals?
Apr 17, 2008 | MB Quart RAA1000 Car Audio Amplifier
Car Audio & Video Logo
140 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
