Question about Westinghouse W33001 30 in. HD-Ready LCD Television
Westinghouse W33001 Will not power on
The TV will not turn on. LED over on/off is Red. When depressing the reset button on the priamary PCB, (S7 i believe), the LED over the on/off button will turn green then go back to red.
Power supply internal LED is green. Did not measure voltages from PS since I have no moanuals.
  • 3 more comments
  • Anonymous Nov 04, 2008
    I HAVE THE SAME PROBLEM,
    REPLACED THE POWER CONVERTER AND STILL, RED OR NO LED.
    WILL NOT POWER UP.
    IF I PULL THE PLUG AND REPLUG IT SEVERAL TIMES AND SOMETIMES IT COMES ON AFTER SEVERAL ATTEMPTS
  • ecturkum Dec 11, 2008
    I have the same issue and would like to know how to find someone local who can fix lcd tv's
  • yessir477 Jan 09, 2009
    Same problem as previous post. I have to unplug and replug the TV in a few times and them it works. Some days its twice other days it can be 10 times or more. Some times it will get a scrambled picture like it wants to come on then it will go to the black screen. I just keep trying. Real PITA but its only 4 years old for crying out loud.
  • ecturkum May 11, 2010
    I want to understand which part or parts were reffered to here. I also checked the power brick and the light on the brick stays green even after the red led on the front of the lcd goes off. Is the part referred to the power brick or the cable and some component that it connects to on the other end?
    I really could use your help here TIA
  • David Dickinson
    David Dickinson Jan 20, 2012
    "When depressing the reset button on the priamary PCB, (S7 i believe)..."
    Where is the PCB?? What is it? I've been looking all over for a reset button. Is it inside the TV??
I had that happen to my tv and took it to be repaired and it was the power pack where it attaches to the tv it just like snaps on and will arch and burn the power pack and it wont power on so the repair guy charged me $89 parts and labor he put one in but sodered it so it will not draw moisture and arch and it works great now....
Posted on Oct 26, 2008
I'm curious about what he soldered, did he open up the case and solder the pigtail to the mother board or was it something else. And when you say arch do you mean arc, as in an electrical arc?
Posted on Jul 25, 2009
Problem: Westinghouse SK-32H240S HDTV has a flashing/blinking blue/red power led
hi when the colours flash again, press the menu button on the remote control and retune the tv hope it helps
regards
shaun
Mar 28, 2014 | Westinghouse SK-32H240S Television
My westinghouse w33001 flat screen tv keeps shutting off. It will be fine for a few minutes, then shut down. No power (red light out). Power cord is plugged in. Checked all connections.
It is shutting down may be because of bad power supply or shorts circuits in the backlight inverter board. You will need to do in-depth troubleshootting to narrow down the problems.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Aug 18, 2010 | Westinghouse W33001 30 in. HD-Ready LCD...
Westinghouse 33001 won't turn on power pack has green light could it be a fuse or a switch that needs to be reset?
The green light means the 5v standby circuit is working, yes it can be a fuse for the main power supply section that gets the control signal from the main board to turn on, so it can be the main power supply or the main control board.
Nov 03, 2009 | Westinghouse W33001 30 in. HD-Ready LCD...
Codes for living solutions remote + westinghouse lcd tv
The codes for your Jumbo Universal Remote to control a Westinghouse television are 097, 100, 130, and 155.
To program your remote by entering a code, follow these steps:
  1. Turn on your TV.
  2. Press and hold the CODE SEARCH button for at least 3 seconds until the red LED lights up and stays lit.
  3. Press the TV button on the remote so that the LED blinks once and then remains solid red.
  4. Enter the first set of 3-digit codes from the list. The LED will blink once every keypress. After the 3rd digit, the red LED will turn off indicating that the code was recognized for the device. If the code was not compatible, the LED will flash several times and you need to return to step 2 to try that code again or to try the next code in the list.
  5. After the LED has turned off, aim the remote at the TV and press ON/OFF. If the device turns off, you have used the correct code and the remote was successfully programed. If the device does not power off, return to step 2 and try again with the next code in the list.
I hope that helps.
Oct 10, 2009 | Innovage Jumbo Remote Control
My Westinghouse w33001 30" flat will not turn on. No red light at the on button. The power supply has 12.1 vdc output & a green ind light. The connection from the power supply to the TV (seems) ok. Any...
the motor on the tv has been tampered with or has been worn out .chances are it could blow up suddenly or damage body parts when it suddleny gives a electric shock so i would advise you to receycle it comment bak
Jul 09, 2009 | Westinghouse W33001 30 in. HD-Ready LCD...
Slow blinking red light
Yes you can first try this:. Red status LED, self-diagnosis error 44, check for open F9A06 on the Power PCB part # 283P128050 on the Power PCB 2. Red lamp LED, self diagnosis error 34. Check for 5-volts DC at J-9 connector pin 1 and 2 on the Engine Driver PCB if missing replace the Power PCB part # 930B921002 3. LED stops blinking after 70 seconds of plug in but will not power on. This model is equipped with a keyboard lock feature, this can be mistaken as a no power condition. To unlock the keyboard press and hold the "menu" button on the front panel for 10 seconds 4. LED stops blinking after 70 seconds of plug in but will not power on. Check for 3.2 volts DC at connector LE pin 3 and 4 on the Control PCB, if low suspect problems with the switches/buttons on the Control PCB part # 935D776001 5. LED stops blinking after 70 seconds of plug in but will not power on. Keyboard is not locked and key inputs at connector LE pin 3 and 4 check good. Suspect the E2P PCB part # 934C121001 6. LED does not stop blinking after 70 seconds of plug in. Disconnect the USB connector from the card reader to the front from the Chassis, if the unit will then boot up replace the Card Reader part # 299P271010. 7. LED does not stop blinking after 70 seconds of plug in. Disconnecting the USB connector from the Card Reader did not help. Suspect the DM PCB part # 934C116002
Sep 11, 2007 | Mitsubishi WD-52525 52" Rear Projection...
TV NO TURN ON
Hello erraez, I would suggest that you first get a schematic for this set (either call the manufacture or go to a sams photofact site and order one). It sounds like you have a powersupply problem, the only way to make sure is to have someone or yourself check the power supply levels to determine what is happening. You will also need a multimeter for this task. If you do not feel comfortable doing this you can lok for a shop on fixya.com or find one in your neighborhood that will look at it and give you an estimate on what is wrong.
Sep 08, 2007 | Mitsubishi WD-52525 52" Rear Projection...
Westinghouse W33001 30 in. HD-Ready LCD Television Logo
1,703 people viewed this question
Top Westinghouse Televison & Video Experts
Jaime Hernandez
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
