Bliry screen - Televison & Video
  • 125 Answers
Do you mean blurry picture?
Posted on Aug 25, 2008
Screen mirroring
Screen Mirroring:
The screen of your mobile device will be displayed on the tv screen this is known as Roku screen mirroring. That displays the web pages, videos and photos etc.
This feature will not support on all the Roku devices.
To use this feature your Roku and mobile device on the same wireless network.
Steps To Enable Screen Mirroring on your Roku Device:
Press Home button on your Roku remote
Select Settings-->System-->screen Mirroring-->Enable Screen Mirroring
If screen mirroring is not available in menu selection, then your Roku does not support Screen Mirroring.
If need technical guidance for Roku-related issues call this toll-free: +1-844-965-4357 and https://www.rokuactivationcode.com/
Jan 12, 2014 | Roku 3 Streaming Player 4200R
The color is bliry and faded . if it is a night scene the picture is really dark you can hardley see anything, depending on the pic. if a pic is blue all u see is blue. it is also bright
Projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both. Repair kits with instructions are also avail from www.TvRepairKits.com
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
69189a5.pngSOLUTION #1
For more more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Apr 16, 2011 | Philips 50P8341 50" Rear Projection...
Screen is bliry and has a few blue lines kind of like a outline
This is a common problem called convergence, I will attach a few photos of typical convergence problems.
In your set it is a fairly easy repair but does require being able to get at the two convergence chips.
Parts cost will be under twenty dollars (I can tell you best place to find them)
If you are able to solder let me know and I will assist you.
SD TECH
Nov 26, 2010 | Hitachi FDX Series 43FDX10B 43" Rear...
SCRATCH ON SCREEN
front screen is a protector but also helps with the image quality. new screen runs about 190 dollars
Jun 02, 2009 | Akai PT61DL34 Television
Help I need a replacement screen
You can find a new OEM RCA replacement lenticular screen and Fresnal screen (availble together as the screen assembly) for a model # R52WH73 from a major RCA distributor at the following links:
RCA R52WH73 Replacement Part Screen Assembly (Fresnal Screen w/ Lenticular Screen)
And here's a link for the protection screen if needed:
RCA R52WH73 Replacement Part Protection Screen / Super Shield
Apr 10, 2009 | RCA HD52W59 HDTV Projection Television
How do I rotate the screen when I rotate the Acer B203w
For Windows XP -- within the control panel, click on Display Icon and the following screen will appear. I have 2 monitors (Laptop and HP L1925 monitor). On the display properties screen, near the top of the screen, click on the “Settings” tab. When the “Settings” screen displays, select the “Advanced” button near the bottom of the screen.
The “Plug and Play Monitor …” screen will appear as shown below. From this screen, click on the “INTEL(R) Graphics Media Accelerator Driver for Mobile” tab near the top of the screen. Note: Tab stretches the full width of the screen.
The "Plug and Play Monitor ..." screen will change to show Intel Graphis Media Screen. From this screen click on the “Graphics Properties” button near the center of the screen.
The screen will change to show the graphics properties. Note, the screen actually comes up with “DISPLAY SETTING” selection (in dark Blue on the Left hand side of screen). To change Display settings click on the words “DISPLAY SETTINGS” (left side of screen) and the screen will switch to show Rotation options. On the top of the screen, select the “Monitor” you wish to change by clicking on “Monitor” button. Next make sure the “Enable Rotation” box is check on the right side of screen and then click on “90”. Your monitor should rotate at this point to portrait. A message will appear letting you confirm if you wish to keep this new setting. Specify yes to keep the new setting.
This should do the trick.
Joe Buus
Jan 29, 2009 | Computers & Internet
Pioneer SD-P5185-K
pull off speaker grill on fron( held on by velcro )t. then look for screws beneath the screen. remove screws and pull bottom of screen bezel out and lift up. remove screen and clean lenses and mirror
Craig www.classtorations.com
May 30, 2008 | Proscan PS32500 32" TV
43A10 43in
Yes, the screen can be replaced. The screen is comprised of 3 screens. The Fresnal Screen (inner screen), Lenticular Screen (middle screen), and the Protective Screen (outer screen). Please see below for links to these items.
Need all 3 to complete screen assembly.The only screen that is still available is the innermost screen, which is probably not the 1 you need. You will only be able to find the middle (lenticular) and outer (protective) screens from a distributor that has them in stock as no one will be able to order them from the manufacturer.
  1. Fresnal Screen
  2. Lenticular Screen (no longer available)
  3. Protective Screen (no longer available)
Apr 02, 2008 | Toshiba 43A10 43" Rear Projection...
SCREEN
Replacement Screen (need all 3 to complete screen assembly)
  1. Fresnal Screen
Mar 25, 2008 | Samsung HCP4252W 42" Rear Projection...
Where can i get a Screen for toshiba 42pw33p model ??
The model number 42pw33p is not a valid Toshiba model number. However, 42H81 is a valid number. The listing below is for model 42H81 ONLY! Double check you number before purchasing.
There are 3 screens that make up the screen assembly The inner screen is the Fresnal Screen. The middle screen is the Lenticular Screen and the outer screen is the Protective Screen. Please click on the links below to purchase these items.
Fresnal Screen
Lenticular Screen
Protective Screen
Mar 06, 2008 | Toshiba 42H81 42" Rear Projection...
Televison & Video Logo
210 people viewed this question
Top Televison & Video Experts
