I charged my mp3 on the computer and now all it gets when I cut it on is file error
The above problem is faced due to virus in ur mp4 player .
Virus Name Genric trojan
Posted on Aug 25, 2008
BUSH MP3 MPK4312BUK does not charge up when inserted into USB drive
to get this device to charge it is more complex than just plugging it in.
when i first bought mine it wouldnt charge at all, the way i found to get it to charge while plugged into a usb powered device is to have it switched on, press the M key until it starts playing then hold the play/pause button until you only see the charge bar. then your mp3 player will charge correctly. if only the manual was even slightly relevant to the product...
Oct 10, 2011 | Audio Players & Recorders
MP3 Audio Book sync problem with Nana 8G
yes you can, plug the ipod into your computer, you will need to get show hidden files enabled from the folder settings and browse into the ipod and transfer the mp3 files there.
Aug 28, 2008 | Apple iPod nano 3rd Generation
My mp3 displays file error when I try to open any file
Your mp3 player may have corrupted files on it, or even a virus if it was plugged into an unprotected computer with a virus or internet connection. Try letting the batter die completely, then give it a full charge and try again. There may also be a "reset" protocol for your particular model somewhere on the internet.
Oct 04, 2009 | Coby MP-610 MP3 Player
How can i get my coby mp-610 stop saying file system error???
View MP-610:
http://www.cobyusa.com/?p=prod&prod_num_id=212&pcat_id=1001
Manual:
http://www.cobyusa.com/files/manuals/MP610_MN.pdf
Quick setup guide:
http://www.cobyusa.com/files/setupguide/MP610_SG.pdf
File system error refers to incomplete startup often due to low battery, faulty firmware or not matching files in the player.
When the startup failed try point 1.Resetting and 2.Charging:
1. Try to reset using the reset button hole on the backside (8).
299c492.jpg 2. Make a connection with the computer and have the device charging for a long period, full load needs 8 hours. Make connection directly to the USB of the computer preferred at the backside of the computer.
When using a laptop see to it that the USB is powered: laptops often switch the USB off going to sleep op hibernate mode.
When this didn't solve the problem, perform a format and reinstall of the firmware, point 4 - 8:
4. Connect the player to the computer and backup your data to the computer using the Windows explorer: copy MUSIC, MOVIE, PHOTO and TEXT directory to a location on the computer.
5. Format the removable disc of the player in Windows explorer.
Check your removable disk having its full memory capacity free after format.
6. Download the firmware for the player: firmware download for MP-610 ( zip file ):
http://www.cobyusa.com/files/software/MP610_Firmware.zip
7. Unzip the file: once unzipped there's a pdf instruction added in the zip file how to perform the firmware update.
8. After the firmware reinstallation the player is ready for transferring
data again. Remember the requirements for the format of files that is put on the player.
Sep 23, 2009 | Coby MP-610 MP3 Player
My mp3 YP-U1 is cannot read in my computer pls. help me :(
Device is charging once connected to USB-port.
Is recognised by the computer but cannot be accessed.
Sep 09, 2008 | Samsung YP-U1 MP3 Player
KEEPS CUTTING OFF
It doesn;t have a virus. She plugged it into a computer that is running Windows Media Player 11, and now the player is toast. WMP 11 replaces a key system file in GoGear HDD models and some early SA models - like SA178.
Connect your mp3 player to the computer.
Open the Philips Device Manager
Run the Repair function.
If the Device Manager does not recognize the player, connect the player to the computer (while the player is in the OFF position) while holding in the volume + button. Continue holding the vol + button for 5-15 seconds until a window pops up on the computer screen that says Found New Hardware Wizard. Follow the directions and it will lead you to do a Repair in the Philips Device Manager.
If this strategy doesn't work, your player is screwed. Call Philips and find out how to get an in-warranty replacement (or take it back to the store).
-Tha Mp3 Doctor
Jul 29, 2008 | Philips GoGear SA178 MP3 Player
Boot error on mp3 player model 4008a
There are two ways to format an Mp3 player - one on the computer itself, and one in Windows Media Player. Both methods will end up erasing all the songs on the player, but the player will be "good as new" after that. Sometimes reformatting in this manner will override the player's native formatting and cause problems - this can be reversed in most cases by updating the player's firmware. Firmware upgrades are available from most manufacturers' websites.
WARNING: The following procedures will erase all songs on the player.
Check if the file system is NTFS. If yes, format it to FAT or FAT32. - Connect player to computer, double-click my computer, right click on icon of mp3 player and select format. This only applies to Windows-based computers.
You can also format the player in Windows Media Player itself:
Connect your Mp3 player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "name of Mp3 player here 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
-Tha Mp3 Doctor
Jul 04, 2008 | RCA OPAL M4001 MP3 Player
Reformt the player:
-Tha Mp3 Doctor
Feb 23, 2008 | RCA OPAL M4001 MP3 Player
Samsung YP-U2JQB MP3 Player
Can I post a solution without being registered?
Jan 30, 2008 | Samsung YP-U2JQB MP3 Player
 Grubhead
Grubhead
