Question about Kodak Cameras
I CANNOT TRANSFER PICTURES FROM MY CAMERA TO COMPUTER
  • 12 Answers
If youve got a software for your camera, try to install it to your computer. after installation connect the cable to your camera which is included in the box. then connect the cable to your pc . wait for the pc to recognize the camera, copy the photos to your pc.
second option is, if you have a memory card in your camera, remove it and insert it to your pc memory card reader. if you havent got one, buy a memory card reader so you can transfer the photos to your pc. hope this help.
Posted on Aug 25, 2008
How to transfer images from computer to nikon coolpix
I don't understand why you would want to transfer pictures from the computer to the camera. Normally you transfer pictures from the camera to the computer. But, if you really want to restore pictures to your camera's memory, you can remove the SD memory card from your camera and transfer the pictures on any computer equipped with an SD card reader/writer. These devices are built into most Apple computers, many PC's and are available as USB accessories for all other computers. I have seen them for under $20. When you connect the device and insert your camera's SC card, your computer will recognize the card and treat it as if it were another hard drive. You will be able to read or write or drag and drop picture files just as you would with any other file on your computer. By the way; most professional photographers use this method to transfer there photos rather then transferring them using a USB cable from the camera.
Jun 27, 2014 | Nikon Coolpix 4100 Digital Camera
PICTURES NO LONGER TRANSFER TO MY COMPUTER
Try NOT connecting your camera to your computer.
The best way to transfer pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo management program such as Picasa.
Organize edit and share your photos
Feb 15, 2014 | Canon PowerShot SX130 IS Digital Camera
Transfer pictures computer
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Nikon Transfer.
Aug 09, 2013 | Nikon COOLPIX L19 Digital Camera
Kodak M763 how to transfer pictures from computer tp camera?
Use a card reader to copy pictures from the computer.
The camera is designed to capture pictures for ultimate transfer to a computer. It's not really intended to receive pictures from a computer. Thus the camera's data transfer capabilities are designed to go one way. To go the other way you need to use some other device, such as a card reader.
Be aware that if the pictures were taken by a different camera, or have been edited in any way, then the camera may not display the pictures. Opening a picture in a photo editing program and saving it without making any changes counts as editing.
Feb 03, 2013 | Kodak EasyShare C315 Digital Camera
My memory card is full and I want to transfer to my computer. I tried to transfer to internal memory but it says there isn't enough space. Anyway to transfer all at once instead of tagging individual...
Connect you camera to the computer using the USB cable. It will be shown as a removable drive(If the autorun is enabled windows should list the option to transfer pictures.Choose this option if it does so). Open the drive and and transfer the pictures to your computer.
Hope this helps,
Sai.
Dec 24, 2009 | Kodak ZD710 Digital Camera
DSC-S730 copy my picture to my computer?
The procedure to transfer pictures to a Computer depends on whether or not the Camera has the capability of using Picture Transfer Protocol (PTP). If the Camera is capable of PTP (in this case; DSC-S730 - YES), set the USB mode in the Camera menu to PTP and then use the PTP procedure to copy the pictures to the computer. Otherwise, use one of the standard USB transfer procedures.
This procedure must be performed while logged in as Administrator or to an account with Administrator rights:
  1. Turn on the Computer.
  2. Turn on the Camera.
  3. Insert the recording media containing the pictures into the Camera.
  4. Set the USB connection or Transfer mode setting in the Camera menu to PTP .
  5. Use the USB cable supplied with the Camera to connect the Camera to the Computer. NOTE: Connection through a USB hub or other USB device --such as a printer or keyboard-- is not supported and cannot be guaranteed. The Camera should be connected directly to a USB port on the Computer.
    NOTE: The Scanner and Camera Wizard should automatically start.
  6. In the Scanner and Camera Wizard window, click the Next button.
  7. Under Choose Pictures to Copy , do one of the following:
    • Click to select each picture you want to copy.
    • Click Select All to select all the pictures for copying.
    NOTE: Selected images will be marked with a green check mark.
  8. Click the Next button.
  9. Under Picture Name and Destination , in the Type a name for this group of pictures field, enter a name for the folder where the pictures will be saved.
  10. Next to the Choose a place to save this group of pictures field, click the Browse button.
  11. In the Browse for Folder window, click to select the location on the computer where you want to save the pictures.
  12. Click the OK button.
  13. In the Scanner and Camera Wizard window, click the Next button. NOTE: The pictures are copied to the Computer.
  14. After the transfer process it finished, under Other Options , click to select Nothing, I'm finished working with these pictures .
  15. Click the Next button.
  16. Click the Finish button.
If you are still unable to transfer pictures, please switch the USB mode of the Camera to Normal or Mass Storage and try again.
After following the steps above, the pictures from the camera should successfully be copied to the computer. If for some reason the pictures did not copy, try using the method for standard USB picture transfer.
I'm assuming you are using the Windows XP Operating System in the Computer. If not then follow this link:
http://www.kb.sony.com/selfservice/documentLink.do?externalId=C116935
Good Luck!!!!!!!!!!!!!!!!!!!!!!!
Sep 06, 2009 | Sony Cyber-shot DSC-S700 Digital Camera
Unable to download pictures to my computer
Consider NOT connecting your camera to your computer.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program.
Dec 31, 2008 | Nikon Coolpix 5700 Digital Camera
I have a Kodak Easyshare C530 how do I transfer pictures from computer to camera?
hey, yes you can transfer pictures from the computer to your camera...you take the memory card from your camera and insert it in your computer (if you do not have the slot to insert the memory card you cannot transfer pictures) thn sync pictures to the memory card and then insert memory card back into camera.
Jul 19, 2008 | Kodak EasyShare C315 Digital Camera
Pictures not transferred to the computer
The cause and solution may include one of the following: The AC adapter or USB cable is not securely connected. Check the connections, and then try transferring pictures again. Kodak EasyShare software is not installed. Install the software. There are too many programs running on the computer. Close all software programs and try transferring pictures again. The camera was removed from the dock during picture transfer. Replace the camera on the dock, and press the Transfer button. The Transfer button was not pressed. Press the Transfer button.
Aug 29, 2005 | Kodak EasyShare C360 Digital Camera
Cameras Logo
578 people viewed this question
Top Kodak Cameras Experts
Tony
Are you a Kodak Camera Expert? Answer questions, earn points and help others
