Question about Westinghouse W33001 30 in. HD-Ready LCD Television
Westinghouse W33001 Red LED lit, will not turn on.
The TV will not turn on. LED over on/off is Red. When depressing the reset button on the priamary PCB, (S7 i believe), the LED over the on/off button will turn green then go back to red.
Power supply internal LED is green. Did not measure voltages from PS since I have no moanuals.
  • Anonymous Oct 12, 2008
    I've had to disconnect and reconnect the power cord to the adapter recently to finally turn on my Westinghouse 30" LCD TV. Now it will not turn on at all. Red "standby" lite illuminates. Thanks for the help, Monte
  • Anonymous Jan 23, 2009
    ditto
2 Suggested Answers
SOURCE: Westinghouse W33001 Will not power on
I had that happen to my tv and took it to be repaired and it was the power pack where it attaches to the tv it just like snaps on and will arch and burn the power pack and it wont power on so the repair guy charged me $89 parts and labor he put one in but sodered it so it will not draw moisture and arch and it works great now....
Posted on Oct 26, 2008
Where is the reset button
They do not use reset buttons on sets anymore.
Oct 04, 2010 | Westinghouse W33001 30 in. HD-Ready LCD...
My westinghouse w33001 flat screen tv keeps shutting off. It will be fine for a few minutes, then shut down. No power (red light out). Power cord is plugged in. Checked all connections.
It is shutting down may be because of bad power supply or shorts circuits in the backlight inverter board. You will need to do in-depth troubleshootting to narrow down the problems.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Aug 18, 2010 | Westinghouse W33001 30 in. HD-Ready LCD...
Codes for living solutions remote + westinghouse lcd tv
The codes for your Jumbo Universal Remote to control a Westinghouse television are 097, 100, 130, and 155.
To program your remote by entering a code, follow these steps:
  1. Turn on your TV.
  2. Press and hold the CODE SEARCH button for at least 3 seconds until the red LED lights up and stays lit.
  3. Press the TV button on the remote so that the LED blinks once and then remains solid red.
  4. Enter the first set of 3-digit codes from the list. The LED will blink once every keypress. After the 3rd digit, the red LED will turn off indicating that the code was recognized for the device. If the code was not compatible, the LED will flash several times and you need to return to step 2 to try that code again or to try the next code in the list.
  5. After the LED has turned off, aim the remote at the TV and press ON/OFF. If the device turns off, you have used the correct code and the remote was successfully programed. If the device does not power off, return to step 2 and try again with the next code in the list.
I hope that helps.
Oct 10, 2009 | Innovage Jumbo Remote Control
I have a Jumbo universal remote by Innovage and I need the programing codes for the tv. Do you have them???
To program your remote by entering a code from a manufacturer's list, follow these steps:
  1. Turn on your TV.
To have the remote try each TV code it knows one at a time, follow these steps:
  1. Turn on your TV.
  4. Press the ON/OFF button slowly and repeatedly until the TV turns off. The LED will blink once each time you press the ON/OFF button.
  5. Once the TV turns off, press the ENTER button to store the code and the LED will turn off.
I hope that helps.
Aug 21, 2009 | Innovage Jumbo Remote Control
Wont turn on no red light
its the inverter board more than likely
Jul 25, 2009 | Westinghouse W33001 30 in. HD-Ready LCD...
My Westinghouse w33001 30" flat will not turn on. No red light at the on button. The power supply has 12.1 vdc output & a green ind light. The connection from the power supply to the TV (seems) ok. Any...
the motor on the tv has been tampered with or has been worn out .chances are it could blow up suddenly or damage body parts when it suddleny gives a electric shock so i would advise you to receycle it comment bak
Jul 09, 2009 | Westinghouse W33001 30 in. HD-Ready LCD...
WESTINGHOUSE MODEL W 33001 GREEN LIGHT NO PICTURE OR SOUND
It's posible your TV when into protection mode to prevent further parts from being damaged. This normally happens when a single parts goes bad inside your TV.
You may have to take it to a repair shop.
Feb 09, 2009 | Westinghouse W33001 30 in. HD-Ready LCD...
Aug 25, 2008 | Westinghouse W33001 30 in. HD-Ready LCD...
Westinghouse W33001 30 in. HD-Ready LCD Television Logo
668 people viewed this question
Top Westinghouse Televison & Video Experts
Jaime Hernandez
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
