Question about Olympus Camedia Stylus 300 Digital Camera
Stylus Digital Is underwater housing available for the Stylus Digital?
    Master:
  • 852 Answers
Yes, the PT-016 underwater housing is designed for use with the Stylus Digital. It can be used at depths up to 141 ft.
Posted on Sep 01, 2005
SOURCE:
Is canon ixus 50 is waterproof?or can use underwater?
No, the IXUS 50 is not waterproof. You cannot use it underwater without an underwater housing.
May 12, 2012 | Canon PowerShot SD400 / IXUS 50 Digital...
No, the IXUS 50 is not waterproof, you cannot use it underwater without an underwater housing.
Olympus 790 sw. what if the lcd turns to pink after i use it! underwater
Hi I recommend most of olympus underwater camera problem due to future problem. Skype me pcc0814@yahoo.com at any time after 6 pm. if you have time. I will tell you everything. Thanks and best regard!
May 23, 2011 | Olympus Stylus 790SW Digital Camera
My Olympus Stylus Tough -6000 lost its underwater capability. it gets wet no matter how much i make sure the battery and USB gaskets/seal clean. can it still bi fixed? how?
I wish there was a way I could shout this to everyone so they would all know it at once....ALL SO-CALLED "WATERPROOF" POINT AND SHOOT CAMERAS WILL EVENTUALLY LEAK. THIS WILL USUALLY HAPPEN AFTER YOU HAVE TAKEN THOSE "ONCE IN A LIFETIME" PICTURES. The only real underwater cameras are in a special underwater housing.
Apr 08, 2011 | Olympus Cameras
Ttl auto does not work
Digital Camera Fully Compatible, Newly Developed S-TTL System "S-TTL" enables TTL auto shooting by an external strobe for a digital SLR camera as well as for a point & shoot digital camera.
INON S-TTL auto strobe supports any manufactures' model providing highly accurate exposure control.
Film camera era without strobe selection problem TTL stands for "Through The Lens" and TTL auto strobe system controls flash amount to provide correct exposure based on calculation by camera's internal sensor metering reflecting strobe light from a subject through the lens. This TTL system meters actual light amount reflecting from a subject providing accurate exposure.
When we start with the history of underwater TTL auto strobe, underwater camera?"NIKONOS V" released in 1984 was the first to provide automatic TTL flash control for underwater strobe SB-102, SB-103 succeeded by NIKONOS V compatible underwater strobes form other manufactures. The 5 pin electrical sync connector for NIKONOS V is most popular and widely adopted to connect an underwater strobe and underwater film camera (underwater camera/housing).
A film SLR camera has flexibility to select an underwater strobe. As far as housing has NIKONOS type electrical sync connector and properly wired, automatic TTL flash control is usable with any TTL auto strobe like Nikon SB-105, INON Z-220, Z-22 connected via electrical sync cable.
NIKONOS type 5 pin electrical sync connector and NIKONOS V with INON Z-22 strobe
Film camera compatible strobe is not usable for a digital camera!? Underwater TTL strobe circumstances have been drastically altered with the spread of digital camera among divers. Some underwater housing for digital SLR camera has NIKONOS type electrical 5 pin sync connector as same as film camera housing. Since the housing has same NIKONOS type sync connector, existing film camera compatible underwater strobe has been considered compatible with a digital SLR camera via 5 pin sync cable but happened to experience error message on the digital camera or blackout on an image even the strobe worked. Why this happened?
This is because automatic TTL strobe system difference between a film camera and a digital camera.
The film TTL auto system makes single flash while digital TTL auto system employs pre-flash type making two to three flashes. Film TTL auto strobe system starts firing at the same time the shutter opens and reflecting strobe light from a subject is recived at a film. The reflecting light on the film is metered by the sensor to determine when to cease firing for correct exposure. This process takes only about 1/1000 second.
In contrast, digital TTL auto strobe system can not calculate adequate exposure based on reflecting light from a subject since image sensor (CCD/CMOS) reflectivity is comparably low comparing to a film. So digital TTL strobe system gives preliminary flash for very short period of time (pre-flash) just before the shutter opens metering reflecting light from a subject by the sensor to calculate necessary amount of light for correct exposure and starts emitting main flash at the same time the shutter opens. Canon E-TTL and Nikon i-TTL employs this system.
When we connect conventional film camera compatible TTL strobe to pre-flash type digital SLR via sync cable, the strobe makes full dump by pre-flash signal then the shutter opens before the strobe has been fully charged resulting in quite under exposed image only with ambient light. Even two time flash compatible strobe like INON Z-220 strobe, does not fully support a digital TTL and force to use Manual flash mode.
Film SLR:
A strobe starts firing at the same time the shutter opens and quenches firing when correct exposure has been obtained.
A film compatible TTL strobe connected to a pre-flash type digital SLR via electrical cable flashes does not support TTL auto exposure resulting in synchronization only with first pre-flash or totally uncontrollable.
The birth of digital fully compatible S-TTL S-TTL auto compatible INON D-2000 strobe and Z-240 strobe works in TTL auto mode by simply setting their main dial to S-TTL position. A film camera seems to depend more on photographer's skill, experience and feel since the camera does not allow checking images on site. A digital camera allows us to check images right after shooting and enable to try to shoot again as much as we like. And high capacity memory card further allows to shoot hundreds of images. The digital camera makes entry level of underwater photography getting down and nowadays more people buy a digital SLR camera and underwater housing even they have just started underwater photography. However underwater photography gets more difficult because underwater strobe does not work in TTL auto.
INON is among the first to support digital TTL auto system with "S-TTL" auto mode equipped D-2000 strobe and Z-240 strobe.
The proper name of S-TTL is "Optical Synch TTL". S-TTL enables to perform in TTL auto exposure as same as genuine TTL strobe from camera manufacture, based on camera's built-in flash light to use as a signal to be transmitted to a strobe. S-TTL uses digital camera's built-in flash light not as a light source but as like a controller to trigger S-TTL strobe.
The built-in flash of a digital camera makes weak flash (pre-flash) before main-flash to calculate exposure. This pre-flash is transmitted to S-TTL strobe to control the strobe to make pre-flash to a subject. The reflecting light from the subject goes through the camera's master lens to an image sensor then a processor calculates main flash light amount for correct exposure.?Finally the built-in flash makes main-flash which is transmitted to the S-TTL strobe to cause main-flash of the S-TTL strobe.
Digital camera's built-in flash lights are transmitted via an optical fiber to the
S-TTL strobe to make pre-flash and main-flash instead of the built-in flash.
Apr 30, 2010 | Olympus FL-20 TTL Flash
HOW TO AVOID GET FOG ,CONDENSATION INSIDE THE HOUSING
Mothers rubbing compound gets rid of gunk on your head lights, and keep the plastic lubed up, get some silicone II "aviation glue" to create a tighter seal to keep; water from going in around the lights edge sondensation may still built up but on the inside
Dec 13, 2009 | Ikelite 6038.02 Underwater Video...
Blurry lens after using it underwater
Sadly that symptom indicates that the camera is broken.
The device's seal protects both from the condition that you are seeing, but also protects the internal circuits from moisture.
If water has gotten inside the camera, I would pursue returning it and getting a replacement from the company.
http://www.olympusamerica.com/cpg_section/cpg_servicerepair.asp
Apr 29, 2009 | Olympus Stylus 850SW Digital Camera
Not so waterproof?
Since the camera is billed as waterproof I would send it to an Olympus service center for an evaluation to see if it going to be covered under warranty for repair if I were you. The repair techs will evaluate the camera and let you know if it is indeed repairable.
http://olympusamerica.com/cpg_section/cpg_servicerepair.asp
Olympus will charge a flat rate repair fee for this product if beyond the one year factory warranty or the warranty is voided. The cost is $107.85 plus your local sales tax. This covers parts and labor, factory cleaning and diagnostic check, 6 month warranty and the cost of shipping the product back to you is all included in that price.
Apr 12, 2009 | Olympus Stylus 710 Digital Camera
Can my pentax optio WP can go underwater without a water housing unit? How deep under can it go?
The pentax optio WP can go underwater without a water housing unit. It can only go underwater about 5 ft.
Aug 30, 2005 | Pentax OptioWP Digital Camera
Olympus Camedia Stylus 300 Digital Camera Logo
57 people viewed this question
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you an Olympus Camera Expert? Answer questions, earn points and help others
