Question about Motorola MU21CV (1 Channel) 2-Way Radio
Motorola GM300 Mobile
Thanks for the advice... I tried the mic and antenna and it didn't work..but I have it remote mounted and after some trial and eror I figured out that the cable was bad. Thank you for your help
  • Motorola Master
  • 1,654 Answers
You're welcome!
Posted on Aug 27, 2008
Can you give me the specs on: Motorola radius GM300 radio? Model: M43gmc29c2aa wanting to know how many channels and how many watts. Thank you.
I think this is what you are looking for: Motorola Radius GM300 VHF 146-174mhz 16 channel 45 watt mobile (MDL# M43GMC29C2AA)
Jul 11, 2010 | Motorola MU21CV (1 Channel) 2-Way Radio
Does a motorola gm300 model number m43gmc29c2aa have ctcss or PL TONES capability's?
Yes, it seems to me that the GM300 radios did have tones as programming options. They were programmed by the dealer using radio service software (RSS) when the frequencies and other channel information were entered. Of course, Motorola discontinued the GM300 a long time ago, and they were wide-band radios, so you could not legally transmit with them anymore. However, you could find someone on eBay to program them receive-only with or without CTCSS (PL) tones and then you could simply listen to them.
Jun 24, 2010 | Motorola MU21CV (1 Channel) 2-Way Radio
Using an older motorola two-way mobile radio with
Rule of thumb: Height and placement of the antenna determines the range. If your FCC license allows, raise the antenna.
As for types of antennas, there are a variety depending on the situation. (Too many to list.) Common would be Unity Gain (aka quarterwave), 3db gain and 5 db gain. Each has their own advantages according to placement and terrian. Talke to your local radio professional or call one of the experienced online companies to get some advice according to your particular situation.
Lastly, be certain your antenna is tuned to the frequency you are using. This alone can add range to your radio.
Oct 16, 2009 | Motorola Radio Communications
I can't xmit or receive on CB channels: Wx channels come in OK. I had a bad WalMart Special mobile antenna which shorted out because of corrosion. Now have a Diesel 15 inch mobile with tunable SWR tip....
If try another mic and see if problem is still
there then you have half of the problem,the
TX an RX all go through the mic if mic good
you will have to go inside of the unit.
Good Luck
Sep 10, 2009 | Cobra 18 WX ST 40-Channels Base CB Radio
I installed a Grant XL SSB/AM mobile radio in my vehicle and it has power but nothing else. I usually have background noise, but nothing. The radio was removed from my vehicle for about 4 months and then...
Honestly I think we've all had this happen. Normally its the obvious things...first thing I would do is check the mic. If the mic is bad then you won't hear anything. Happened to me and I checked everything....then a friend grabbed his mic and it worked perfectly. If its not that I'd check the coax cable....or possibly the mount for your antenna. If you took the mount down from the last use, did you put the nylon spacer to isolate the antenna from the mount? Its not the radio, its more than likely just something you overlooked....Keep me posted on your progress! Good Luck!
Apr 23, 2009 | Uniden GRANTLT 40-Channels Base CB Radio
How to change frequency on gm300
To my knowledge the GM 300 can be programmed only with a DOS based programing software. Start with the DOS, not from the windows
Mar 12, 2009 | Motorola GP300 Compatible 2 Way Radio...
2 way radios
Your radio with model number M33GMC09C2AA is a GM300 made for Central Asia, Eastern Europe and Turkey. It is VHF 25 watt with 12.5 channel spacing. It will do frequencies between 146-174 MHz. It should be able to be "read out" by a Motorola dealer. If it has been in a boat, it most likely is programmed with Marine frequencies. If you have another marine radio you may be able to determine the frequency by process of elimination.
The wiring kit for power is readily available for around $18 ea. If your boat has a marine VHF antenna onboard, you will be able to attach the antenna to this radio. It takes a mini-PL connector.
Sep 14, 2008 | Motorola Radio Communications
Motorola GM300 Question
Check your antenna connections and coax for loose connections or damage. Also check your hand mic. See if the problem disappears if you turn on the radio without the mic attached. The two most common problems with a mobile radio are antenna and mic problems.
If you feel these are in order, it would be wise to have a tech look at the radio.
Aug 23, 2008 | Motorola MU21CV (1 Channel) 2-Way Radio
Motorola GM300 Base Station
Pls check your power supply it can cause a garbled audio once the power supply is not regulated or constant voltage so your transmission also is defective,check also the connector it should be tighten,if not do change your microphone for temporary......
May 19, 2008 | Motorola MU21CV (1 Channel) 2-Way Radio
Motorola MU21CV (1 Channel) 2-Way Radio Logo
104 people viewed this question
Top Motorola Radio Communications Experts
Greg Cann
Greg Cann
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
