Question about Olympus EVOLT E-500 Digital Camera
My camera won't auto focus
I'm not sure whether or not it's broken or if I hit a setting that I'm just not sure of.  The camera will start to focus, and then get completely blurry.
  • mspussycat2u Aug 27, 2008
    thanks, i'll try that !!!
  • oo7ebarron Sep 26, 2008
    My camera won't auto focus?
    Sergeant:
    Champion:
  • Olympus Expert
  • 479 Answers
In low light or low contrast situations, the camera will not focus...press the [---] and change the point to center focus and increase the iso
Posted on Aug 27, 2008
Canon lens won't focus
If it focuses OK in manual but not in auto then you may have broken ribbon cable in the lens.
Jan 20, 2013 | Canon EF 24-70mm f/2.8L USM Lens
Won't auto focus
Make sure the auto-manual focus switch on your camera is set to auto (A) and also make sure the auto manual focus selector on the lens is in auto (A) as well. If your lens contacts are dirty then this will affect the function of the lens as well. Clean those with either a lint free type cloth and alcohol or methylated spirits.
May 26, 2012 | Nikon Nikkor 18-55mm f/3.5-5.6G ED AF-S DX...
New Canon EFS 18-135mm IS lens failed to auto focus on EOS Rebel XTI and shutter won't release to take photo. Lens over a few months has worked without a problem. What is the problem?
Make sure both the lens and the camera are switched to af (auto focus). If that doesn't work remove the lens and replace it to make sure it is mounted properly. You can also check the camera with a different lens to make sure it isn't a problem with the settings on the camera. If all of that fails take it to a camera or electronics store that does service work to make sure it hasn't been damaged.
Jul 30, 2011 | Canon Cameras
When shooting thru glass (like at a zoo or museum) using the Coolpix L20, will the autofocus detect the glass and focus there instead of on the subject? If so, is there a way to avoid or counteract that?
It depends how clean the glass is, whether the display/animal space is brighter than where you are shooting from, and whether there is any light hitting the glass itself and causing glare. Usually you just have to keep attempting to focus until you hit the focus spot you want. Also, some models do have a manual focus setting - see if your camera does and just set the focus to a particular distance when shooting. Hope this helps!
Hiram
110 East 13th Street
New York, NY 10003
212-673-8400
Jul 06, 2011 | Nikon COOLPIX L20 Digital Camera
Shots are blurry
This issue can occur in the following circumstances:
The subject is too close to the camera lens Insufficient lighting Subject movement Camera movement Incorrect camera settings Incorrect camera operation Follow the steps below to help prevent taking pictures that appear blurry, out-of-focus or distorted.
If the camera has both an auto focus and manual focus mode, make sure it is set to auto focus. Make sure there is enough lighting to allow the camera to focus on the subject. Make sure the camera settings are set appropriately. When taking close-up or macro-type shots, ensure the subject is not closer than the minimum focus distance of the lens. Also, if the camera has a zoom option, set it to the W (wide-angle) position. If you have a fast-moving subject and the camera has a Program AE mode with a higher shutter speed (such as Sports action), make sure it is enabled. Also, if the camera has an ISO control, set it to a higher setting. If your camera has a SteadyShot/anti-blur function, ensure it is enabled. Aim the camera at the subject. Press the shutter button halfway down. NOTES:
Pressing the shutter button halfway down allows the camera to focus automatically. A flashing green indicator will be visible in the LCD or viewfinder. When the indicator stops flashing, focusing is finished and the camera is ready to take the picture. Some camera models have a Monitoring AF setting that can be selected which allows the camera to focus without the need to hold the button halfway down. Consult the instruction manual of the camera for information whether or not this is applicable for your model.
Jan 01, 2011 | Cameras
My auto focus will not work.
lens af unit gear is broken, or lens af saft if broken, or lens af flex is broken.
or could be camera sub mirror spring is come out from mirror unit.
take it to canon repaire centre to estimate
Jul 05, 2010 | Canon EOS Rebel XSi Digital Camera
Will not auto focus
There is a switch on the top of the camera that has your focus modes. switch to C-AF for Continuous auto focus. If you have it set to MF - Manual Focus that would explain this easily.
Mar 03, 2009 | Fuji FinePix S7000 Digital Camera
Can't get camera to go into Manual Focus
hey, i have one too, just take the camera out of auto adjustment and put it in say, program auto or some other setting on the thumb wheel...
Apr 24, 2008 | Sony Cyber-shot DSC-H2 Digital Camera
Focus Problem
Low light focus lock can be a problem with this camera. But in normal or bright light there should be no problem with auto focus lock. If this is a new problem, you should check to see if a setting has been changed. With so many options, it is easy to accidently set something that causes unusual results (been there, done that). First ... Go to the Setup Menu and see that the "All Reset" option is selected. This will cause everything to be reset to factory default each time you power-on the camera. Turn the camera off and then turn the camera on. Then take some test photos to see if your auto-focus-lock is improved. If that works, there is no need to check the items below. If that does not work, here are some control changes to try. Remember if you turn off the camera everything gets reset. That camera uses contrast detection for auto focus and it is normally set to "Multi-Area Auto Focus". Try changing it to "Spot Auto Focus" and do some tests, including with the camera set to one of the programs or manual mode. There is another setting called "Autofocus Area", you should investigate. Check your manual to determine what you can do with this control. There is another control called something like "continuous auto focus". Check the manual for further information. If none of the above help, it is time to see about some camera repairs.
Sep 06, 2005 | Olympus Camedia C-740 Ultra Zoom Digital...
Olympus EVOLT E-500 Digital Camera Logo
177 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Are you an Olympus Camera Expert? Answer questions, earn points and help others
