Question about Emerson MW8168B Microwave Oven
Timer works but No Go
We inherited an MW8168B with the house that we purchased and it worked. However, recently it's developed some problem. The timer works and it's primed to go, but it doesn't turn on.
It started by working if we held the door button partially in, but now it doesn't go at all.
I took off the cover and checked things out. The top door interlock (szm-v16-fa-63) had burned looking insulation around the terminal connector. Is there a surefire way to check that this is the problem?
If it's the problem, I've found a new one for an LG, which is the same part number. Is it safe to order this?
If one is blown is it likely that the other two are also ready to go or gone?
Thanks for your answers.
  • dbgeezer Nov 24, 2008
    Thanks, Joel,
    I solved this problem but forgot to close it.  I just ordered the part and popped it in.  Worked like charm.
Had the exact same problem on my Mom and Dads Whirpool microwave. The szm-v16-fa-63 interlock switch basically burned out. That switch must be closed in order for the motor to rotate and for the magnetron to radiate the heat. Took it out and tested it with my multimeter and the switch provided only intermittent continuity when button was pressed. A new one is around $3 (USD) from what I googled. I might just jump the two wires that were on each pole of the switch but that would be bypassing a safety device and is never recommended. A new switch should do the trick I think the original one has an intrinsic flaw that causes it to fail so rapidly.
When working on a microwave make sure to disconnect the magnetron and be extra carefull. When I need to test and make sure everything works I usually pop in a damp paper towel and nuke it for a few secs.
Posted on Nov 23, 2008
I have an Emerson MW8168B 1100 watt Microwave. Start Button Problem.
the pads are touchy its probably been white knuckled too long
Apr 03, 2013 | Emerson MW8168B Microwave Oven
Emerson MW8168B microwave fuse
Good job, and thanks for passing along the information.
Aug 31, 2012 | Emerson MW8168B Microwave Oven
Mic.oven takes longer to heat food
The microwave may not be cooking at full power, check the settings. If okay the magnetron is on it's way out and will eventually fail.
Jun 11, 2012 | Emerson MW8168B Microwave Oven
Does the emerson mw8168b have a built in timer. for just timing other things.(without turning the microwave on)
Sorry, but it does not have this feature.
That and the quiet beeper are two big complaints on this model.
Jun 30, 2009 | Emerson MW8168B Microwave Oven
Replace Emerson Microwave Ove Fuse
Most of the manufactory has put them in the back where the power cord comes in.
Mar 13, 2009 | Emerson MW8168B Microwave Oven
Microwave exploded.
Did it make a popping noise, like a .22 cal pistol? Probably one of the larger capacitors on the power supply blew up.
Mar 06, 2009 | Emerson MW8168B Microwave Oven
Lost glass turntable support wheel
I have the wheel you're looking for. We are tossing a broken Emerson MW8168B but I'll hold the turntable support for you if you want it. Let me know.
Apr 19, 2008 | Emerson MW8168B Microwave Oven
MW 8168B - Inop
some mic's have fuses check that out
Feb 15, 2008 | Emerson MW8168B Microwave Oven
Keypad Problem?
look on the back panel for any hole with a "RESET" label next to it. insert a small pin to reset your microwave
May 25, 2007 | Emerson MW8168B Microwave Oven
Emerson MW8168B Microwave Oven Logo
658 people viewed this question
Top Emerson Microwave Ovens Experts
William Miller
William Miller
Jerry Greenberg
Jerry Greenberg
Are you an Emerson Microwave Oven Expert? Answer questions, earn points and help others
