Question about Carrier Heating & Cooling
Carrier air conditioner
Air doesn't feel as cool as normal and the air will not shut off by itself
    Sniper:
  • 81 Answers
Are the filters clean? Get the system serviced and checked for refrigerant loss.
Mat
Posted on Jul 18, 2009
Is this a window unit or split system? If window check wall plug for power or just plug in something that uses the same voltages..example 110-120volts plug in a lamp... if a 220-240-volt system , plug in .........???? or a volt meter to read your voltage s.?!.
Posted on Aug 25, 2008
Just started making an odd noise. Normally compressor blows out warm air. Air being blown out now is very cool
Unless I'm missing something in what you said, air conditioners are supposed to blow out cool air, rather than warm air. Or does the air just feel cooler than what you had the thermostat or comfort control set on? If that's the case, turn the comfort control or thermostat Up a bit.
I hope this helps. Thanks for choosing FixYa.
Jul 26, 2011 | Carrier Heating & Cooling
Please help carrier 38ck03040 outside unit hums but not cooling....top of unit feels hot
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool...
AirConditioner Trouble - Review the Possibilities
heatman101
Jun 25, 2011 | Carrier 38CKC042 Air Conditioner
The air conditioner cools the room but it shuts of. The power light doesn't come on while unit is on. Can I replace the plug?
"The air conditioner cools the room but it shuts of." -- Temperature reached, but does not turn back on automatically? Stops short of reaching temperature? Shuts off for a period, but will come back on only to shut off again later?
Most importantly, how do you get it to turn on again?
"The power light doesn't come on while unit is on." -- If the unit is on and the power light is not, then the power light must not be operating (is burnt out).
Actual answer: "Can I replace the plug?" -- Of course you can.
What is causing you to feel that the plug needs replaced?
:o).
Jun 04, 2011 | Daewoo DWC-056CL Air Conditioner
My carrier heat pump has frosting on the outside on it's coils. I know that it's cold outside but is that normal?
Yes it is normal especially with high humidity. The moisture freezes on the coils just like on the evaporator coils in a freezer. The heat pump will defrost itself by shutting off the fan outside and reverse the flow of refrigerant to melt the ice when it build up then switch back to normal heat. That's why at times you may feel cold air coming out of the vents in the house. The outside coils are defrosting.
Dec 16, 2010 | Heating & Cooling
I have a Carrier 38CKC036 Air Conditioner Unit. When I turn the thermostat on cool the compressor comes on but the fan on th unit clicks like it wants to come on but it dont. Could the fan be bad? What do...
Hello, this is one of 2 items...the motor itself, or the start capacitor. The capacitor is responsible for boosting the motor to get it started. Follow the wires from the motor and they will lead to an oval or round cylinder. Check the cylinder for any bulging or leaking oil. When the motor should be running, reach in with a stick or ruler and try to assist the fan to get going. If the it feels resistant...it is most likely bd motor. If it trys to start and feels smooth it is most likely capacitor.
May 13, 2010 | Carrier 38CKC036 Air Conditioner
Is it normal for fan on outside unit to be on while on heat mode
Yes, it is normal with a heatpump, you run the outside unit in cooling and heating.
It is also normal when the outside unit goes into defrost for the outdoor fan to shut off during the defrost mode and to see steam coming out of the outside unit, while it's melting the frost or ice, then the fan will come back on.
Jan 06, 2010 | Carrier XHB123D X/Y Series Heat/Cool Air...
Furnace overload limit switch
Here is the service manual with wiring diagram.
Dec 19, 2009 | Carrier XHB123D X/Y Series Heat/Cool Air...
Cools only at night
Possibly low on gas . Take Thermometer and check the outgoing air. Should be close to 45 degrees If not low on gas. Rusty
May 06, 2009 | Carrier XHB123D X/Y Series Heat/Cool Air...
Only for two or so hours
You need to look at the outside half. See if the compressor is overheating and shutting of to protect itself.
Jul 05, 2008 | Carrier 38CKC036 Air Conditioner
Heating & Cooling Logo
80 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
