Question about Insignia Televison & Video
My isiginia NS-M100HD the screen started to go black and I read in the top left corner that it lost input signal. The flip down is only user when we go out on trips, it would appear that an internal connection is loose. Is this common and how do I fix it?
5 Suggested Answers
PcExpert
  • 293 Answers
SOURCE: black screen
Is your HDD LED flashing? -Try pressing F8 on startup to show the boot menu option of your OS if it is Windows. If it does appear use Safe Mode first. If not successful try re-installing your OS.
Posted on Sep 14, 2007
SOURCE: TEVION TSD-DR40HD. CONNECTED TO A
IT APPEARED TO BE A FAULTY CABLE
THANKS
Posted on Jun 22, 2008
SOURCE: small bluish, black triangle at far right corner
This is the same problem as other posts have mentioned about the right side of the screen having a bluish-balck stripe down the side of the screen. Here's what's happening. There's a small light tunnel which has 4 very small mirrors located just behind the color wheel. The lamp shines light through the color wheel as it turns and the light goes through this small tunnel and is then relected off several mirrors before it is projected through the lens and onto the screen. Optoma apparently did not use a very good heat resistant expoxy glue when they assembled these mirrors and over time the mirrors drop down causing a shadow effect on the screen. It can be repaired without paying some repair shop a small fortune. Previous posts have a solution from another contributer whihc includes photos. I had to repair mine and it's worked fine since I used a decent expoxy to hold the mirrors.
Posted on Sep 20, 2008
  • 3 Answers
SOURCE: the top screen s really loose and flips back anf fourth
Try buying a tri screwdriver on ebay and using this guide: www.youtube.com/watch?v=vRzTgfo2PsM then take it apart and use some glue.
Posted on Apr 17, 2009
SOURCE: screen display is flipped
I simply turned my television off while emailing fixya and reading the user's manual. The television was turned off for about ten minutes. I think what happened was that the dvd skipped while ejecting and caused the screen to flip....who knows, I'm just happy it works properly again because I love to watch movies.
Thanks anyway,
Brett
Posted on May 18, 2009
Why a black screen on xps l701x w7 i7 1.73
Black screen - no flashing white cursor in the upper left corner - no picture at all, i.e. the initial Dell start-up screen doesn't show up either:
- LCD is dead or isn't getting a signal - not an easy fix; or
- the LCD isn't being sent a signal - holding down the function [Fn] key and press display Function key to toggle through its settings (LCD panel only, Rear VGA output only, both LCD and VGA output)
Black screen - flashing white cursor in the upper left corner - the screen goes black after the windows loading screens come up but before the windows login screen comes up - it is probably a windows video driver problem. Try starting in Windows Safe Mode with VGA. Press [F8] after the Dell startup screen disappears to access the windows startup menu
Oct 19, 2014 | Dell XPS Computers & Internet
Insignia NS-30HTV 30 screen is black on all inputs, and says digital channel signal strength is low, can i fix this?
you need to get a digital aerial first .then you can sort out any other problems from there
Oct 03, 2012 | Insignia NS-30HTV 30" TV
Panasonic viera black line split screen horizontal 3/4 left 1/4 right
Visit the site named 'Electro-help' for more details. Check this link and select the site. View it in 'Flip card' option, which can be selected from the drop down box menu at the left top corner or the display window. It will make search easy.
Aug 08, 2012 | Televison & Video
No picture no sound. Message on screen 'weak or no signal' The signal is strong. Also in top corner it says - A-----2 Auto panoramic
Reset the tV to its factory settings. Refer its user manual for details. If it do not help you, visit the site named 'Electro-help' for more details. You might ahve to enter its service mode option to reset it to its factory settings. Check this link and select the site. View it in 'Flip card' option, which can be selected from the drop down box menu at the left top corner or the display window. It will make search easy.
Aug 06, 2012 | Sony FD Trinitron WEGA KV-32FS120 32" TV
I need the wiring colour codes for 2002 santa fe car stereo
Basically the wiring of the large harness corresponds to the pins like this.
Starting in the upper right hand corner and working down the right side from A12 down to A1.
1=Left rear output-red
2=Left rear output-blue
3=Right rear output-black
4=Right rear output-yellow
5=empty
6=Left front input-black
7=Left front input-yellow
8=Left rear input-orange
9=Left rear input-green
10=Amp 'ON'-blue&orange
11=empty
12=Amp sensor-black&orange
Back up to upper left hand corner on the large plug
13=Right front tweeter output-red
14=Right front tweeter output-blue
15=Left front tweet output-red
16=Left front tweeter output-blue
17=empty
18=Right front input-red
19=Right front input-white
20=Right rear input-blue
21=Right rear input-red
23=Right front sub (+) output-yellow
24=Right front sub (-) output-black
The small harness is the same above with the upper right position being pin 1 going down to pin 4 then back up to the top for pin 5 down to pin 8.
1=Memory Power-Lrg White
2=Amp Ground- Lrg Black
3=Left front sub (+)output-yellow
4=Left front sub (-) output-black
5=Left front mid (+) output-white
6=Left front mid (-) output-brown
7=Right front mid (-)output-brown
8=Right front mid (+) output-white
Hope this will help you.
Thank you
Jan 04, 2011 | 2002 Hyundai Santa Fe
1/2 screen Blk w 2" Stripes & UPSIDE DOWN/drop Dell Inspiron2200
well im not a great tech but i can give you one solution, you can try to connect it to ANY monitor from the VGA port of your laptop, just find a PC monitor to do this with. to "flip" the screen to different angles you will have to be logged on.
Hope this helps, i you have any further questions just ask
Apr 10, 2009 | Dell Inspiron 2200 Notebook
No display on flip out screen
I have a Sony DCR-TRV30. Your camara is probably similar. On the bottom left outside corner of mine, there are two buttons, labeled "exposure" and "program AE," and a small thumb wheel above them. Set the indicator to "camera" and open the screen. Push the "exposure" button and a light grey rectangular screen with a minus sign on one end and a plus sign on the other will appear near the top left corner of the screen. Rotate the thumb wheel so that the small black square in the rectangular screen will move from the "+" side towards the "-" side while the image on the screen gets darker.
Jan 04, 2009 | Sony Handycam DCR-DVD108 DVD Camcorder
Green semi-circle of lines on Samsung 55" HDTV (projection)
I believe i have the same problem myself. When my TV is on any of the Component Inputs without my DVD player turned on i usually get the normal green screen. But now that is a dip in the green at the top of the screen from the top left to almost the top right and black pushing down on the dip. Almost like a green curtain was sagging at the top and you can see the black behind it. It does this on every input and distorts every picture you see. The distorted picture has all the green slightly off from where the rest of the picture is and where the dip at the top of the screen is there is somtimes purple instead of black.
I know the basics of how the picture gets onto the screen and its my guess that the Green "gun" for lack of a better term and somhow come loose, or been missaligned to a great extent. I would love to find an answer to this problem, and anyones best guess as to how much a repair man will charge, just so i know the ballpark.
Jan 31, 2008 | Samsung HCN653W 65" Rear Projection...
I cannot acquire satellites signal. What to do ?
I experienced the same problem about acquiring satellite signal even when it's a clear sunny day. After 30 mintues, it was still searching! The unit appeared to have "stuck" in this acquiring mode. The following worked for me: 1) open the GPS antenna 2) press the bottom left screen while holding the power button to turn the unit on 3) enter maintenace mode 4) select diagnostics 5) clear error report, do NOT clear any user data 6) restart unit the usual way My GPS 350 was able to acquire satellite signal in less than 1 minute after the above steps were taken.
Jul 21, 2007 | Garmin nuvi 350 GPS Receiver
Televison & Video Logo
159 people viewed this question
Top Insignia Televison & Video Experts
Jaime Hernandez
Dave Naylor
Dave Naylor
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
