Question about Canon imageRUNNER 8500 Copier
Canon ir6000 error codes E000061-0001..
My copier canon IR6000 shows error code E000061-0001. plaese help me what to do clear the error code. i've tried the ussual clearing error but it doesnt work. please help :(
  • 1 more comment
  • rajbal32 Mar 06, 2009
    canon ir6000 error codes E000061-0001.."
  • Anonymous Mar 26, 2009
    coad 733
  • J. Carlos Munoz Aug 15, 2013
    My copier Canon irc51851 shows error code E0000057211, can you pleas help me about it?
Error E061 poblem
Posted on Dec 02, 2008
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Canon Master
  • 1,362 Answers
E061 Specific potential is not required or the limiter is activated as the potential is controlled.
I beleive it is the Potential of the "drum sensor"
there is a sensor that reads the drum and adjust the machine, this may need to be adjusted, cleaned or replaced. Has to be done by a tech.
Posted on Aug 25, 2008
  • CheckitRight
    CheckitRight Aug 25, 2008
    (pay a tech on the side to do, most techs do side jobs, but only if they feel they can trust you and will not rat them out even if something goes wrong afterwards. )
    New Friend:
E0061 ?
use the additional function star 2-8 star > copier> function >DPC (1) . ? select the DPC feed the value 0 press oky. then machine power off/on your machine problem is solve.
Posted on Apr 02, 2013
  • Ritesh Rahi
    Ritesh Rahi Mar 08, 2016
    your guidence is very helpful,it solved my problem.,Thanks.
    Problem Solver:
  • 16 Answers
One change corona wire to primary and transfer corona if its solve the problem ok, if not make potential control in service off
if not replace laser unit
Posted on Dec 30, 2011
Error code E00020
Posted on Feb 05, 2009
I have problem about my copier. message error 246 whats happend
Posted on Oct 08, 2010
Gimana memperbaiki error 302001
Posted on Aug 12, 2012
E000
Posted on Jun 18, 2012
Canon ir6000 error code is morning E0061
Dear
The mode selection has problem, pl. check the laser unit shutter, LSU and DC controller PCB.
The above are the measure if the error code has no sub-error.
Thanks.
Jan 19, 2015 | Canon imageRUNNER 6000 Copier
How to solve this e000061-0001 error
Hi
The description for this error can be found here:
Error Codes Canon iR6000 Code E061 0001
and is the same for both the IR5000 and IR6000. There is a link on this page as well to download the full service manual for the model displayed, which should enable you to solve the problem.
On the right at the top of the page you can change the error code you are looking for to get a quick reference.
Hope this is helpful, if so would you please register that with Fixya
Cheers
Nov 27, 2014 | Canon iR5000-6000-L1 PS Ver 1.0
How to fix error e000001-0000 for canon ir6000
You can try to reset error code in service mode, but if the error persist after clear, you need to rectify the problem and replace fault component which is fairly fixing easy to do.
The problem can be in thermistor, sub thermistor or dc controller pcb, or ... call service!
To reset error code:
while ready to copy/showing the error code:
1) Press the user mode key ( * ) on the control panel.
2) Press the 2 and 8 keys at the same time.
3) Press the user mode key ( * ).
Choose: COPIER>FUNCTION>CLEAR>ERR
Turn off and back on the copier.
Jul 30, 2014 | Canon Imagepass L1 Print Controller For...
Canon IR6000 shows error code E000061-0002
this is problem Error E000061-00021 how to solve plz send Answer
Dec 14, 2012 | Canon imageRUNNER 5570 Copier
My canon photocopy machine displays an error code presenting as (E 000602 - 0003)Please help me solve this problem.
Hi these means that you have HDD trouble, and it needs to be changed and upload the system on it - CALL SERVICE.
Aug 19, 2010 | Canon Office Equipment & Supplies
ImageRUNNER 7200 Copier: hi I'm Akar I have a canon ir6000 copier my...
The problem is with toner section. The copier cant get toner to toner unit or the toner motor is faulty.
In one case eaven the main pcb caused the problem.
I would try to replace toner hopper assy.
call service.
May 16, 2010 | Canon imageRUNNER 7200 Copier
Getting a problem with a canon ir 6000 error code E 350-001
ji guys I need ur help, I've error code on cannon ir6000 "000732-0001", please help me send to my mail ahlalrasyid@yahoo.com. ty
Feb 16, 2010 | Canon Office Equipment & Supplies
Error code 277-5802
what i can tell you is that there is a comunication problem between the printer board and main controller. the only suggestion i have for you is to call for service and have someone come out and check all the boards. unless you know how to remove them and try putting them back in
Jan 28, 2010 | Canon imageRUNNER 8500 Copier
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} E061
Main Cause The laser shutter is faulty. The laser unit is faulty. The potential measurement
PCB is faulty. The DC controller PCB is faulty.
Mode of
Detection
0001 As the result of potential control, the drum surface potential (VL2)
of the white background is about 200 V (generating solid black images).
0002 The primary charging output used for print output and the drum
surface potential after laser output has been made are about 200 V
Sep 08, 2009 | Canon imageRUNNER 8500 Copier
Canon imageRUNNER 8500 Copier Logo
9,506 people viewed this question
old marine
old marine
