Cars & Trucks Logo
Posted on Aug 25, 2008
My 325E BMW is not starting
Hi, my 325E is not starting nor does it make a noise like it want to start. Someone said it is the factory alarm that is stopping it, please help
Anonymous
Level 1:
  • Contributor 2 Answers
  • Posted on Sep 24, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
Helped
1577
Points
Check to see if the raised pin on the fly wheel has has broke off. to do that you, take out the position sensor on the bell housing & look on the flywheel to see if it is there. your have to manually turn the engine whale somebody else looks to see if the pin is still there. if it is not. where it is suppose to be, just put a sheet metal screw in its place. by taking a long drill bit and drilling it out to put the screw. try and see if that's the problem
1helpful
BMW e46 won't start because of the alarm.
Hi, if the car stay for long time the computer box lost memory. Now is not reading the key. You need to program your key again by BMW manufacturer. Also on bmw the alarm is connected to computer box too.
2answers
Odometer stop working 86 bmw 325e
Most likely speedometer cable, check wiring harness to gauges and cable driven cruise control if so equiped
1986 bmw 325e starts and runs fine for about 5-10 minutes, then starts dieseling and dies. wont start for 5-10 minutes,and then will start fine.
I would suggest you check the fuel filter or fuel supply to the engine as it may be a venting problem of a clogged fuel filter.
Cheers
Car wont start, fuel line makes sputtering noise
I have a 1986 325e with high mileage 275,000. Car starts fine and idles ok. I'm experiencing an intermittent problem where when placed in drive the car will sputter, lightly backfire, and not move forward until i pump the gas and give it time to correct whatever is not operating properly. Then it runs just fine. I'm thinking it's an air or fuel issue. Just recently tuned up the car and put some bgk44 after the problem started but still experiencing the same problem.
Nov 10, 2009 • 1986 BMW L7
2helpful
Replace struts on a 1987 bmw 325e
YOU NEED TO REMOVE THE STRUT COMPLETELY USING COIL CLAMPS CLAMP THE SPRING AND REMOVE TOP PLATE UNDOO THE LARGE NUT ON THE STRUT ITSELF THEN PULL OUT THE INTERNAL SHOCK REPEAT THE PROCESS IN REVERSE FOR ASSEMBLEY
1helpful
Reset ''Service Oil'' sensor on a 1985 BMW 325E off dash console
Call your local BMW dealer and ask them...should be free!
Good Luck
1985 bmw 325e
Its your transmission...BMW made bad transmissions up to 1990.
Top BMW Experts
vince
Steve Sweetleaf
Steve Sweetleaf
old marine
old marine
Are you a BMW Expert? Answer questions, earn points and help others
