Question about Toshiba MW27F51 27 in. TV/VCR/DVD Combo
Toshiba MW27F51 We have had this television for about 2 years...it is still under warranty. The other day the picture began to flicker. We thought that maybe it was the cable, but after turning that off, we realized that it was the actual tv. Is this common in this tv and could there be a wire loose? It's a pretty annoying problem. Any help would be great! Thanks
    Problem Solver:
  • 18 Answers
If it is still under Warranty, take it to an ASC for repair.
Posted on Feb 03, 2009
    Problem Solver:
  • 15 Answers
There could be a number of reasons for that. The High Voltage (Flyback) could be loose or going bad. only and experienced tech wouls wanna go in there because of the high voltage that needs to be discharged. Or a cracked circuit board or cold solder connection could cause this.
Posted on Oct 17, 2008
Is my color wheel need replaced?
the bearings of the color wheel could be worn. the screws hold it in place, & there is a plug-in wire connected to it.
for part# contact: http://support.toshiba.com/
Dec 02, 2014 | Toshiba 50HM66 52" Television
Flickering picture and color smear
Trash it Toshiba T.V. and laptops have a flickering problem with is caused by a failty power supply
May 27, 2009 | Toshiba 52HM95 52" HDTV Projection...
I have a Toshiba TV/DVD/VCR combo model # MW27F51-had it for a couple of years. Turned it on, have sound but no picture. I have the cover off the back of it now.
sound like a defective part inside the set. i could tell you what one went bad, this is not user servicable, and could shock you bad. i would take it for service or get a new one. due to the cost of these against the cost of repair.rule of electronics-if the cost of repair is 60% of a new one you should not repair it. good luck! hope this helps!
Feb 27, 2009 | Toshiba MW27F51 27 in. TV/VCR/DVD Combo
Bottom left corner, red part of the picture is making an arch
11 years old, you may need a new one, as service can be costly. if the cost of repair is more tha 60% of a new one, get the new one. the fact it is 11years old, makes this an easy choice. good luck.hope this helps..
Feb 22, 2009 | Toshiba MW27F51 27 in. TV/VCR/DVD Combo
Is my Toshiba MW27F51 TV Digital?
pretty much if the television is older than a year-it probably has analog tuner. you can buy digital box (add-on) i have one and it does make picture nice. about 40.00 bucks. i'm ot sure if they still offer the card that gives you a 40.00 dollar off. look up digital converter box. good-luck, hope this helps!
Feb 21, 2009 | Toshiba MW27F51 27 in. TV/VCR/DVD Combo
Toshiba CX32G60 1/2" vertical inward bow center of video
change the electrolytic capacitors in the vertical section of tv. you do need a qualified tv tech to do this repair for sure
Nov 30, 2008 | Toshiba MW27F51 27 in. TV/VCR/DVD Combo
Flickering screen with semi-circular middle whitish flicker and static sound
Use your warranty, as most warranties are vioded if you open the set up.
Jun 12, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Flickering Picture
Is your TV the Toshiba 52hm95? I had a similar problem but my TV went out completely. I had a service tech out this morning..it was my light engine and will be $900.00 to 1000.00 to fix. I hope that's not your problem too...Toshiba said they have had no other reports of such a problem with this particular tv.
Oct 17, 2007 | Toshiba 52HM95 52" HDTV Projection...
Dim screen...
it could be the ballast lamp, or it could be the optical engine, can you see in the rear of the TV if you can see if the ballast lamp is lit up. usually you need to unplug the ev and remove the rear cover or at least the vant over it to see if it is lit. If it is dead replacement is usually covered under warranty, within a year or so otherwise they cost around 200-300 dollars. If not, then the Optical engine is probably having problems and I would suggest replacing it if under warranty.
Jan 31, 2007 | Toshiba 51H84 51" Rear Projection...
Toshiba MW27F51 27 in. TV/VCR/DVD Combo Logo
82 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
