Hi there my name is keith i am trying to load win me on a clean hard/dr about 130 gb and it would start very good take the id key # evey thing and then it would stop and a mes come up saying can not load mes sud 325 this never came cross this prob before can you help me thanks keith
    Problem Solver:
  • 11 Answers
Need more info. Is this a reload on an old PC, or are you trying ME on a new PC, and what specifically is the pc?
Posted on Aug 25, 2008
Have a ASUS Eee PC 1005 (?). My 500GB USB hard drive won't work. Either not recognized at all or disconnects while in use. Error code 43. Does this on more than one computer windows vista and windows 7...
Hi
The issue here is with your USB 500 GB hard drive.So you need to try to connect the same hard drive on any of your friends computer and check if it works.
So try to connect any other USB device like flash drive and check if USB port is functioning properly.
If the flash drive is not getting detected then the permissions have been revoked.
You need to login as administrator, if your are the only user then login with your ID on start up.
Press and hold the Windows sign key( Do not release) and press R key, this opens the run command box.
On the command box, type "inf" and hit enter key
Go to file name " usbstor " and " usbstor.pnf" and right click and go to properties and select security.
Under Group and Names, sellect your login ID and check for permissions at the below of the same screen.
If it is not under full control then USB device will not get detected.
You need to edit the permissions and get full control.
Hope this helps you.
Thank you
Gowtam R
Jan 06, 2011 | Computers & Internet
Cratfman push lawmover not starting,I put a new spartplug,new gazoline,new air filter still not starting
Hi..my name is Keith..and it could be several things..that your carb needs cleaning..the fuel pick-up tube needs cleaning..if you have no spark..it could be the coil..it could also sheered the key in the flywheel and this will throw off the timing..i hope these suggestions will help
Jun 20, 2009 | Craftsman 20 hp 42 in. Deck Yard Tractor
I CAN NOT FIND PRODUCT KEY FOR MS.OFFICE 2007 LOADED ON VISTA
hi there... if you lost your product key for ms.office 2007..the best thing you buy a new one cd...or you can search at internet using search engine (ex:google) and typing descripsion that you want...i hope you can find what you need..good luck..
Feb 02, 2009 | Western Digital My Book Essential Edition...
Os instalation will not load
Hi Dobssand, the most common reason for a CD-ROM (With a Windows CD in it) does not start to load is the motherboard's bios is not set correctly. While in the bios go to the title Boot & enter boot order. This is a common boot order for a PC.
1st boot device = [Floppy disk drive]
2nd boot device = [CD-ROM drive] (Model number of the CD-ROM drive).
3rd boot device = [Primary Hard Disk Drive] (Model number of drive).
Second most common reason is the data cable to the CD-ROM drive is loose or not fully connected either at the CD-ROM or at the motherboard. (Check it).
If you choose not to enter your bios, you can still get the CD-ROM drive to boot the Win CD in this fashion. Load the Win CD into the CD-ROM drive. Power off the system. Than power on the system & start to press the F8 key once every two seconds. Windows "Please select boot device:" window will open. Using your keyboards up & down arrow keys high-light the CD-ROM drive that has the win CD in it & press the enter key. Windows should start to load. If you receive an error message stating windows can not find your hard disk drive. Than you must enter your bios & go to the title Boot. Your hard disk drive is not listed in the boot order section. Worst case! Your hard disk drive may be faulty. Find the manufactures name printed on a large white sticker on once side of the HDD. Go to the manufactures web site & download their drive setup software so you can create a bootable floppy disk. This will allow you to check/test the HDD & format it for a windows installation.
Or is this not the issue you are having?
Mike
Sep 26, 2008 | Computers & Internet
Maximum hard disk support
this hard drive size will work with your motherboard but the problem is the size will be detected only up to 130 GB or less, so if you will be using that size of hard drive you will just waste it.. so better use a 120 GB of hard drive or upgrade your motherboard so you can use a 250 GB.....
Hope that helps.............
Sep 01, 2008 | Computers & Internet
I am trying to load win me on a clean hard/d about 130 gb it start very good it take lic key # and it gos nicely then it stop and say it can not load it mes sud 325what can i do ...
This may not work, been a long time since I dealt with ME, but I do know that both ME and XP originally had Partition limit sizes below 130 GB. I think XP original partition limit was around 96 GB and I'm almost certain that ME's would have been less then XPs.
So my recommendation to start out with would be to partition your hard drive into 40 GB partitions before attempting the install of ME and make sure your partitions are formatted into FAT32 partitions as FAT32 was the scheme that ME was developed for and most used on.
Don't be afraid to partition to 20 GBs if the 40GB doesn't work. Partitioning serves a lot of useful purposes and should be used much more then it is as this one trick alone as done more to save data on a computer then probably any other trick around. Luckily for everyone virii/trojans/malware, tend to attack the C: partition where the active OS installation lies. Well over 90% of the time any data located on partitions other then the C: partition is recoverable even after a major crash caused by conflicting softwares or malevalent softwares.
Aug 25, 2008 | Computers & Internet
External drive wont mount
Try doing flea power & the power cycle.
1. Disconnect all the peripherals like keyboard,mouse,printer, scanner & monitor and power supply from the CPU.
And press & hold the power button for 2 min, it will release the flea power from the mother board.
Restart the system & check.
2. Disconnect everything.wait for 5-10 minutes and then connect every thing.
Restart the system.
If it does not resolve the issue then you can try this :
Check this before you try to edit the registry values.
http://developer.apple.com/documentation/Darwin/Reference/ManPages/man1/profiles.1.html
Just remove the registry key it happen when this key is corrupted.
HLKM\System\CurrentControlSet\Enum\USBSTOR
And delete all references to the external hard drive.
And also HLKM\System\CurrentControlSet\Enum\USB
and found the keys associated with the USB to IDE value.
After restarting the system, the drive shold be detected & configured automatically by the computer.
Disclaimer : I will not be held responsible for anything that happens to your computer as a result of following my guide. Use this guide at your own discretion and risk.
You can use the Disk utility in MAC to run the diags on your drive.
Good Luck.
Live, Love, Laugh.
May 14, 2008 | Iomega 33089 250 GB Hard Drive
Restoring Partition
If you did the install by formatting C drive, it was a clean install and all other data from Win 98 will be gone. Also XP uses NTFS rather than only FAT. It becomes a real mess when you try to install XP over 98 without starting on a clean slate.
Nov 05, 2007 | Seagate Barracuda 7200.7 ST380011A 80 GB...
Flashing Loading sign on start up
I HAVE THE SAME PROBLEM HOW DO I FIX THIS ??? george.hennessey@ntlworld.com
Nov 15, 2006 | JVC DR-MH30S DVD Recorder
Computers & Internet Logo
65 people viewed this question
David Payne
David Payne
