Question about Gateway Computers & Internet
Gateway fpd2275w repair
They say this monitor has a bad inverter board. How do I open the case and remove the board?
  • 37 Answers
Screws under the front cover need to be removed at least thats the way it was on my monitor. The front frame around the display is then pushed up about three eights of an inch and then lifted off. This will reveal screws that hold the display to the unit. There are wires that connect the LCD to the inverter board and to the video board. You can determine the inverter board by the larger wires. IT will have CCFL's on it. Google CCFL to get a generic picture. good luck.
Posted on Aug 26, 2008
My FPD2275W LCD Monitor will only lit up solid white light. I have turned it off, unplugged it and everything else I can think of. It didn't how any signs of a problem yesterday, just all the sudden today...
Solid white meas the T-CON board is not getting the signals or 5vdc feeding it from the logic board or it has blown fuse.
Check all the caps in the power supply and on the logic board first, be warning, this case is real hard to open and MUST BE REAL CAREFULE WHEN SEPARATING THE FRONT BEZEL FOR THE BACK CASE!
http://s807.photobucket.com/albums/yy352/budm/Gateway%20FPD2275W/
Aug 17, 2010 | Gateway FPD2275W LCD Monitor
My gateway monitor flashes gateway logo then it (FPD 2185 W)
Look for bad DC filter caps in the power/inverter board.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Capacitors kit: http://lcdalternatives.auctivacommerce.com/
Jul 27, 2010 | Gateway FPD2275W LCD Monitor
When i put on my computer the gateway FDP2145 W. Monitor stopped coming on together with the cpu . I have to unplug the monitor several times before it finally comes on.is this repairable or tome for A new...
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed GATEWAY monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
May 21, 2010 | Gateway FPD2275W LCD Monitor
I don't have power save on but my screen goes from bright to dim
Look for bad caps in the power supply/inverter board.
http://www.badcaps.net/forum/showthread.php?p=73310
90% of my LCD repair are due to bad caps, see example here of what is involved in repairing the monitors:
Make sure to use good caps, PANASONIC FM or FC series from DIGIKEY.
Post back what you find so it will help other people also.
Replacement bd: http://cgi.ebay.com/Power-inverter-board-monitor-FPD2275W--LP2207-E131175_W0QQitemZ370358203047QQcmdZViewItemQQimsxZ20100402?IMSfp=TL1004021510002r18789
Apr 05, 2010 | Gateway FPD2275W LCD Monitor
When I power up my computer the Gateway icon shows up but monitor stays black...I repeatedly hit the power button on the monitor until the screen finally shows up..and once its on it stays on all day until...
hi, these are exellent monitors. i have repaired and made good profit on these. there is about 8 capacitors on the main board that go bad. all are 470uf 25 volt. if you have good knowledge of soldering, you can perform this repair. even broken, these monitors go for 100 dollars on ebay. contact me back if you want more info on how to repair yourself.
Feb 08, 2010 | Gateway FPD2275W LCD Monitor
I have a Gateway FPD2275W LCD Monitor, and it will not come on.
have encountered this same issue with a monitor like yours its very common especially for lcdmonitors there is a bad diode on your monitor board and you will not be able to fix this yourself you can buy another or use just a regular crt monitor2_bing.gif or your best bet is to have it repaired im sorry and i hope this helps
Dec 19, 2009 | Gateway FPD2275W LCD Monitor
Gos black after 2-5 seconds, no picture at all not even with on the monitors own menu.
You may see very faintly that there is an image. The inverter or the filter capacitors are likely culprits. Open up the back of the monitor to get to the circuit board and if the capacitor is bulged out on top or leaking from the bottom, it is bad and needs to be replaced. They can be found all over ebay for under $5 with shipping per 5-10 caps. Hope this helps
Oct 04, 2009 | Gateway FPD2275W LCD Monitor
Monitor goes blank after it comes on for two seconds
bad capacitors on the power board internal to the monitor they need to be replaced, let me know what you would like to do
Mar 22, 2009 | Gateway FPD2275W LCD Monitor
Black monitor
Power light coming on and sound effects when you plug it in but no lighting of the screen is usually caused by the power inverter board having gone bad. Once in a while it is a bad bulb.
I repair these 90% of the time
bammbamm@ptd.net
Jul 03, 2008 | Gateway FPD2275W LCD Monitor
Ccfl inverter board
The most prevalent failure on these boards are the transformers and or the ic that controls the frequency of the lamp drive. More times than not you will find a bad transformer.
srich
May 19, 2008 | Gateway FPD2275W LCD Monitor
Computers & Internet Logo
561 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
