Question about Refrigerators
GE Refrigerator, model PSS26MGPBBB, stop making ice. Water dispensor works fine. Green light on ice maker is blinking. Have tried recycling power to ice maker no change. Have check to see if obstruction in ice tray, clear. At time sounds like is is trying to make ice but do not hear water valve come on.
  • Anonymous Sep 16, 2008
    I have same model number - ice machine stopped working quite a while ago and now it is making howling sounds.
  • ihatework Mar 16, 2009
    I have a GE Profile Artica PSS25MGMB BB, with the same problem..no ice, green light blinking. Tried turning the fridge off..thought there might be a ice freeze up in the line supplying the water..but the problem remains. Help please!
PROBLEM IS ASSOCIATED WITH THE TEMP SENSOR INSIDE ICE MAKER. I HAVE TRIED TO FIND THE PART, BUT WITH NO LUCK. IT LOOKS LIKE WE WILL HAVE TO PURCHASE A NEW ICE MAKER.
Posted on Aug 15, 2009
Ice maker not working
OK, that should be no problem. Test your ice maker and fill with water if empty of ice. If full of ice and not moving to dump tell me. I need to help you locate the problem doing that and answering will tell me the problem. Also look around the door frame and inside for the model Profile that you have. and get back with me as soon as possible, Thanks Sea Breeze
Nov 19, 2009 | GE Profile Stainless Bottom-Freezer...
GE REFRIGERATOR'S ICE DISPENSOR PROBLEM
CAN U TELL ME WHAT YOU DID TO FIX THIS PROBLEM. I AM NOW EXPERIENCING THAT EXACT PROB!
Nov 09, 2009 | GE Refrigerators
Ice maker will not make ice
Make sure the ice maker is turned on ( green light ?) . Pour about 2/3 cup of water into ice maker . If it freezes and dumps the cubes , but doesn't fill with water , replace the dual water inlet valve ( one coil for water dispensor , the other is for the ice maker ) . If it does not dump the frozen cubes , then replace the ice maker .
Sep 17, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Profile Artica - Water & ice dispensor not working.
This could be as simple as the door switch or as complex as the dispenser control board. I would try the door switch first. When the door is close it turns on the dispenser controls. If the contact is defective in the door/light switch then this happens. Unplug remove the door switch and mark wire locations. 1 Powers the lights and the other powers the dispenser. and one is the power itself. Sea Breeze
Jul 26, 2009 | GE Profile Arctica 25.4 Cubic Feet...
My Jenn Air refrigerator ice maker quit working
My Jenn-Air refrigerator (JRSD2790) quit making ice, dispensor works, water dispensor works. Do I need to replace the entire
ice maker?
bjones03@comcast.net
Mar 25, 2009 | Jenn-Air JCD2389G Side by Side...
GE side by side refrigerator: water/ice dispensor
I bought a brand new smartwater replacement filter and after a very short time, my water stopped coming through the door.. took out the new replacement filter and inserted a brand new one .. problem solved.. apparently some of the g.e. smartwater filter replacement cartridges don't have the high enough two plastic inserts which are attached to them at the top of the filter when you screw them on... if you have taken your cartridge in and out a few times, i think it wears down the plastic so it doesn't fit properly and won't put up whatever it is supposed to push up to make the water come through.. I personally think this is a g.e. problem with the replacement filters...
Jan 31, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice maker not making ice
Sounds likw the water fill tubs is frozen shut, look where the tube comes into the freezer compartment and take a hair drier and thaw it out. Good Luck
Jan 07, 2009 | Kenmore 53642 / 53644 Side by Side...
you need to check the inlet screen on the solenoid down below for blockage, also make sure that the freexer is cold enough
Dec 26, 2008 | GE GSS25JFPCC / GSS25JFPWW Side by Side...
Ice Maker Problem
my ice maker stopped making ice. Green light is on. Drinking water is ok
Feb 17, 2008 | GE GSS20IEP Side by Side Refrigerator
Refrigerators Logo
520 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
