Question about Kitchen Ranges
My gas wall oven is experiencing delayed ignition. When it finally lights there is a loud noise because of gas buildup inside the oven. I have replaced the igniter twice in one year. It works okay for a short while only.I have also cleaned the burner with a wire brush. The oven is a 1965 Caloric wall oven model RWS214
    Problem Solver:
  • 10 Answers
The pilot must be adjust
the burner has a device to provide air to burn the gas it must be adjust
hamid
Posted on Aug 25, 2008
My kozy world wall heater makes a boom pop when it lites. It's like a delay in lighting and then it lites.
If the furnace made a clicking noise trying to turn on and then makes the BANG noise at the furnace, it’s most likely a delayed ignition. Imagine a room full of gas and then someone decides to light a match. Big problem. That's what’s happening in your furnace if the ignition of gas is delayed.
A variety of issues can delay the combustion of that gas. So the gas builds up in the furnace until—BOOM—it ignites, causing a mini-explosion. This can harm the heat exchanger, which is very expensive part to replace. Some causes of delayed ignition includes:
1. Dirty burners
2. Flames are lifting away from the burner outlet due to too much primary air
3. Too much gas
If you're handy enough to understand what I've said then burners can be cleaned/replaced, and primary air can be adjusted. With some units gas flow can be adjusted as well; other times the gas valve will need to be replaced.
If you've no idea what I've described, GET HELP before you ruin the heat exchanger and have a more expensive problem on your hands or worse...
Dec 24, 2016 | World Heating & Cooling
1. Dirty burners
3. Too much gas
Making a load bang wnen starting
This could be a delayed ignition, whenever a gas appliance makes a loud bang you should call and have it serviced by an authorized service technician before you use it again. Safety first!
Apr 11, 2011 | Baxter BXA2G Stainless Steel Gas Single...
Emy amana oven will not immediately ignite. we will turn it on and there is a delay before it ignites and prior to that there is a loud popping noise which even rattles the oven door as if there is gas...
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Sep 30, 2010 | Amana Ovens
FAN NOISE in convection mode, as in a loud whirring sound, suggesting a problem with the fan. Any one else experiencing this?
FAN NOISE IS NORMAL BUT IF ITS SQUEELING THERE IS A PROBLEM WITH THE COOLING FAN. YOU DO HAVVE TO REMOVE THE OVEN FROM THE WALL TO REPLACE.
Jan 24, 2010 | KitchenAid KEBC107 Electric Single Oven
I have a Lenox furnace. Before this igniter kicks off, there is a loud noise comes from furnace. Where is that noise from? Thanks.
This is what we call a "delayed ignition",(gas is not being ignited right away), gas builds up in the chamber and then lights causing a boom. The cause of this problem could be from having dirty burners or ignitor not position to ignite the gas right away or your ignitor may not being glowing enough to ignite the gas being released, check all, Good luck.
Jan 08, 2010 | Goodman GMS90703BXA Heater
Adjust resonance screw makes loud noise on start up
I'm not sure what you mean "adjust resonance screw". I'm going to guess the adjustment screw your talking about is under at screw cover and is the appliance regulator screw. It adjust the gas input to your burners. Too low pressure is caused by backing the screw off and can result in delayed ignition or a "loud noise". It's really a small explosion caused by built up gas and damage your heater. Too high of pressure is caused by turning the screw in too far and can over-fire the heater which is also dangerous. I'm assuming you burn natural gas because with propane the appliance regulator is wide open. Your gas company may come and use a manometer to set the manifold pressure to factory settings (3.5 to 4.0 W.C.) for you. Otherwise, turn the screw back in until the ignition is not delayed and the loud noise is replaced by a nice quick ignition. Good luck.
Jan 02, 2010 | Empire DV-215 Direct Vent Natural Gas...
The oven of maytag range mgr5775qdw poorly
The ignitors/burners need to be cleaned properly.
Build up of grease, dirt, rust, mineral deposits, etc can cause improper gas flow resulting in a delayed ignition. That causes a build up of gas and the delayed ignition ignites it all at once, and you have your WHOOMP mini explosion.
Sep 25, 2009 | Maytag Ovens
My maytag gas oven model #MGR5755QDW makes a loud poof noise when first turned on. It doesn't do it all the time and it only happens when it is first lights.
You are getting a delayed ignition fom the oven burner. Either the ports on the burner near the ignitor are clogged or you have a weak oven ignitor. part # 12400035 @ $70.00
Apr 08, 2009 | Maytag 30" Self-Cleaning Freestanding Gas...
Ignitor problem with gas oven
The spark ignition coil is failing. As this is an oven, it can be dangerous not to have a strong ignition spark. A gas buildup in the oven could cause an explosion.
You should replace the spark generator coil which is located at the back of the oven and is usually orange/black or blue in color. Ariston usually use ITW Ispracontrols ignition coils.
Mar 26, 2009 | Ovens
Kitchen Ranges Logo
250 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
