Question about Microsoft Xbox 360 Console
SYSTEM ERROR IT DOS NOT WORK THERE IS A RED LIGHT, I UNPLUG, TURNE IT OFF AND ON AND DONT WORK
  • 89 Answers
Have one part of the xbox circle is red how do i ficks thisd
ok not much detail but here is a list of red light problems and solutions if you have one red ring is external hardware fail unplug all cables and check for damage also look at power brick problems should be green or orang not yellow or red if its 2 red lights its blooked vents and dust pileup used canned air or a vacum to get as much dust out as posible its causing over heating 3 red rings is death whitch can be mutible errors most likly the most common one is the x clamp or loss of pressure to the motherboard if this dont help you can open up your system for diagnostic exams ther easy to fix error codes if you need the error code hold the controller sync button on console and press eject 4 =0 1=1 lights and so on if you need a repair call microsoft at 1-800-4my-xbox dont void your warrenty because you might not be succesful at self fixing but they gurante they fix it but they dont help you if your system is opened up
Dec 05, 2010 | Microsoft Xbox 360 Console
My wii system will not turn on. every time I hit the power or eject button the red light will flash yellow and then turn off. If I unplug the cords the light will be red again, but I push the power button...
Hi, you may just need to reset the power lead, to do this unplug it from the wii, then unplug it from the wall, now leave it all unplugged for 5 min this will allow the power lead to reset then plug it all back in and give it a try.
if after doing the above it still dont work then the chances are the wii has over heated so check if you have any warranty left as this fault is covered, if you dont then you need to find someone who can reflow the solder for you on the 2 main chips under the heat sink, this is not easy to do and could cause more harm then good so be warned.
let me know what happens after unplugging the lead ok
Nov 28, 2010 | Nintendo Wii Console
My xbox 360 is not working. there is 3 flashing red lights it say error 73 . all the repair ways cost money how can i get it repaired for free?
E73: General Hardware Error: Ethernet port... this error is caused by a problem with the Ethernet port. Try this troubleshooting. Remove the A/V cord from the back of the XBox 360. Stick two sticks into the fans to prevent them from spinning. This will cause the system to overheat within five minutes. You will know its done when the first and third quadrants light up red on the system (indicating the system has overheated). Unplug the system, plug it back in and turn it on to see if it was successful. (Note: While this method does not void your warranty, if your XBox is still under warranty I suggest sending to Microsoft to fix.
Nov 27, 2010 | Microsoft Xbox 360 Console
Three rings are green one red on tv says error e73
Turn on unit until the red light flashes and the error code(E 73) shows up on the screen. Next insert toothpicks in the back of the console(while unit is running) into the cooling fans, this is to suppose to overheat the console and start two red lights flashing. Turn off console when this happens(unplug all cords from console) and turn the system back on.
Thank you
Jun 04, 2010 | Microsoft Xbox 360 Console
Flashing red light on the bottom right of the ring and an error code 73 picture on the screen
Hi,Turn on unit until the red light flashes and the error code(E 73) shows up on the screen. Next insert toothpicks in the back of the console(while unit is running) into the cooling fans, this is to suppose to overheat the console and start two red lights flashing. Turn off console when this happens(unplug all cords from console) and turn the system back on.
This solution will fix your problem for sure. Thank you!
May 12, 2010 | Microsoft Xbox 360 Console
Xbox 360 q1 and q2 lights going red
i dont now because my xbox 360 do the same thang
Apr 21, 2010 | Microsoft Xbox 360 Console
Xbox 360 E73 error. What do I do?
Apr 07, 2010 | Microsoft Xbox 360 Console
Xbox 360 error 73
Sometimes the easiest way is the fastest way. The signal reset button (the little one to the left of the power button) is also the unofficial reset button for the Xbox 360. With the Xbox turn off, press this button and keep pressing it while you press the power button. Do not release the reset button until you see the system booting up normally. Of course, if there is a permanent or a more serious damage to the system, it won’t work or the error will be recurrent until it is solved. Resetting just clears the error from memory.
Dec 09, 2008 | Microsoft Xbox 360 Console
1flashing red light
one red light is also the E71 error as well.
Aug 04, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
