Question about byD sign 3032 30 in. HD-Ready LCD Television
Power supply for byD:sign 3032
Did you ever find one, because I need one also. Thanks
  • 3 Answers
I have a new OEM power supply for this tv.
If intertested, please email me your contact info.
Thanks,
Art
Posted on Mar 19, 2009
  • Lboogie12601 Mar 09, 2011
    Hey I'm not sure if you'll get this but I need a power supply and can't find one anywhere. Please write me back if you getthis email. Cory112c@aol.com
I want to sign in as ben parry
sorry but we have no idea where you want to sing i . certain it is not to a TV
Oct 06, 2016 | byD sign 3032 30 in. HD-Ready LCD...
I need a power cord for a BYD LCD tv model D:3032
Power cords can be bought from most of the electronics spare part selling shops at your town. There is no special attention to choose one. Select a good quality power cord from a reputed brand. that is all.
Jul 03, 2012 | byD sign 3032 30 in. HD-Ready LCD...
The picture on my BYD:sign 3032 has been going out, sound is OK
It's a backlight or backlight inverter issue. (The backlight itself usually fades or makes the on-screen image change to pink/red.) For an out-of-warranty TV, open up the back of the TV and remove the shielding. Look for any scorch marks or bulging or damaged capacitors. (Sometimes other parts will fail on this part but these can be spotted easily. Capacitors look like cylinders on a tripod.)
If you borrow (or have a) high-end multimeter (able to measure high frequencies - 50 kHz) or an oscilloscope, hold the multimeter probes a fraction of an inch apart about an inch above the board and power up the TV. If you see a 1 or an actual value, you have a good inverter. If you see a reading near 0, the board is bad or the multimeter can't resolve the frequency.
In either case, you can buy a replacement inverter for $50-150 and just do a simple swap. Disconnect all of the wires (connections are similar to molex and ribbon cables in a computer) and remove board (a few screws usually). Connect the cables to the new inverter. (If you google backlight inverter replacement, you'll find videos and text descriptions.) Note the part number on the board, including the Rev number, and order the exact one (shopjimmy.com or lcdparts.net are good starting points). Universal inverters do exist but can result in reversed controls (up to lower the brightness). Replacing individual parts on the board is cheaper but more prone to not tracking down all of the bad parts.
If the inverter is good, then it's probably backlights themselves (several in most TVs). These are sandwiched on the perimeter of the TV (usually under some tape that holds the lamp, reflector and other parts together. You need to order by length and width and get ones for your TV size. Remove the tape, and separate the reflector (make a note of how things are put together) then you have to Dremel (or use another rotary tool) to remove the plastic to get the backlight out. (They are often molded into the frame.) Then put in the new backlight and reassemble everything.
With a good spare backlight, you can test an inverter for condition (plug together and turn on the tv while the box is open). Similarly a good inverter can test the backlight.
I hope this helps.
Jul 08, 2010 | byD sign 3032 30 in. HD-Ready LCD...
I have Power, but no picture or sound
is there a screen saver that appears or a No signal popup?
check the connections from the source. maybe remove the source cable and look to see if the no signal screen appears...
if not maybe some damage has occurred.
May 18, 2009 | byD sign 3032 30 in. HD-Ready LCD...
Peascorn
I have a New OEM power supply for a byDesign 3032 TV.
If interested, please email me your contact info.
Thanks,
Art
Jul 17, 2008 | byD sign 3032 30 in. HD-Ready LCD...
Power Adapter
I NEED a new power adapter ttttttttttoo.. can you HELP please,, I allready had a so called TV repaire Man try to fix it he said he cant get a new power adapter for it to be fixed .... I stupidly PAYED him waited 9 months later, and still no TV fixed..Im taking him to smalls claimes court.....Very un happy persone ,I just want a new power adapter,....please some one out there...peascorn...I have d:sign TV 3032- ad-13d-2...
May 25, 2008 | byD sign 3032 30 in. HD-Ready LCD...
50 inch byd:sign 5032 plasma
negative, this problem needs some technical job to be done by a spedcialist. you have a problem with your power supply and it overheats thus shuts down
Apr 10, 2008 | byD sign d:5032 50 in. HD-Ready Plasma...
No picture
btw for anyone experiencing these problems with the infamous "is-lcdtv32" byd:sign is the same manufacuterer as insignia, its the same company with a different sticker. i know this isnt a solution, but parts for all discontinued insignia';s can be purchased thru byd:sigh(by design). hope this helps .
Oct 06, 2007 | byD sign d:4232 42 in. HD-Ready Plasma...
byD sign 3032 30 in. HD-Ready LCD Television Logo
349 people viewed this question
Top byD sign Televison & Video Experts
Jaime Hernandez
Elise Lacoursiere
Elise Lacoursiere
Are you a byD sign Televison and Video Expert? Answer questions, earn points and help others
