Question about Radio Communications
Alinco DR-610T problem
My Alinco DR-610T worked fine last night when I installed it into my truck. It was accidentally turned on today while I was double-stick taping it to my console. I turned it back off, stuck it to the console, turned it on, and now the screen says: set up
and then goes to: --- ---
Nothing but the power button seems to work, I can't reset it.
Help?
  • 1 more comment
  • calismoonelf Aug 26, 2008
    I am certain that no buttons are stuck. I even swapped the head unit with another than I had with the same results.
  • ke6zfi May 01, 2009
    I have the exact same problem. Any luck fixing it? What was it? Thanks
  • Patrick Patterson
    Patrick Patterson May 11, 2010
    Are you sure that none of the buttons are stuck? If one of the buttons was pressed and remained in the pressed position it may cause this problem.
    New Friend:
  • 109 Answers
Have you checked the caqble that goes between the head and the radio. I have had radios come into my shop that have had bad cables or the cable connector on the board gets a cold solder joint. be sure to check the connector on the head and on the radio side. If this is not the problem then it's time to take it to your local ham store for service. If it's still under warranty then let the factory take care of it.
Pat N5SLI
Posted on Aug 27, 2008
Alinco dr 610t I just purchased this radio from a
sorry your question is not proper, we need to understand what kind of cable do u need for it, just take a snap and forward it to me, will surely help u, or mail me the snap to sunjy26@gmail.com
Oct 18, 2013 | Radio Communications
MY ALINCO DUAL BAND 2 METER/70CM HAM RADIO DISPLAY STARTS TO BLINK SHORTLY AFTER POWER UP
Hi Leslie,
This may lead to the info you need to resolve the issue.
Join yahoo group Specific to your radio Make/Model, Be as detailed as you can when giving them your queries. They have a wealth of info and you can download manuals, schematics and other goodies for your radio, if available and all this is free.
I hope you do resolve the blinking issue with your Alinco.
Cheers,
Peter
Mar 17, 2013 | Alinco Radio Communications
When I used my push button 4x4 the other day it was just fine but last night I had to use my 4x4 because I had accidentally backed into a mud hole covered in grass and it would not lock in 4x4 hi or lo but...
most likely it is the transponder switch in the dash not shutting the system off.try unplugging the switch yhen plug it back up , it may have a loose connection.
Aug 17, 2011 | Chevrolet S 10 Cars & Trucks
Toshiba regza 47" flat screen last night i was
Check your power cable. Unplug it from both ends and plug it back in
Mar 05, 2011 | Toshiba REGZA 47HL167 TV
New customer. Installed yesterday. Worked fine last night. Turned on today, all I get is searching for signal on satellite in 2.... (771).
Go to your menu and find your signal strength bar.It's possible that your dish has shifted.The bar should read at least 60% or above.
Sep 25, 2010 | Directv Plus DVR DTV Receiver / 100-Hours...
97 intrepid shut off fine last night, today will
sounds like a fuel pump or maybe check on the asd relay or fuel pump relay try taking them off and tap on them then try to start if no start sounds like a fuel pump or timing belt issue. good luck
Jan 05, 2010 | 1997 Dodge Intrepid
No TV Picture
Unplug,replug an hour later,might reset to factory setting.Tries stop all timer setting.
Dec 29, 2009 | Televison & Video
Alinco DR-635. On two meters, there is no received audio.
I think your 2M section has a dead FET in the receiver front end. The FET transistors are bad about being destroyed by ESD, as they are not gate protected. This is a repair shop job, unless you are very good with repairing surface mount technology. The 635 is a good rig, well worth the repair costs. Consider using a factory repair shop, to get the job done right. There is an Alinco group on Yahoo Groups, join them and ask where to send your radio for repair. They will know who is reliable enough to trust your treasured radio to for repair.
Good Luck,
Longshorts.
Jul 06, 2009 | Radio Communications
Dell inspiron 1501 work fine turn off last night now wont turn on
You mentioned trying a different battery, try a different AC adapter.
When plugging in the ac adapter to the wall, see if the POWER LED comes on on the adapter, then when you connect it to the computer, see if the LED stays on.
If the issue occurs with both AC adapters (No battery installed) then the motherboard has failed. If one ac adapter works but the other doesn't then the adapter is bad
Feb 01, 2009 | Dell Inspiron 1501 Notebook
Radio Communications Logo
478 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
