Question about Kodak EASYSHARE 5100 All-In-One Printer
I cannot get the photo light to come on so I can print
I can print from the pc but the scan or copy light are the only ones that are lit up not photo and it is very slow in printing thru these modes. and doesn't seem a dark any help is appreciated! Thank you
Margie
  • Anonymous Mar 26, 2014
    printing OK - photo copying too light
  • 40 Answers
Why don't you try going to www.kodak.com/go/5100downloads , and there download the Firmware (which is what actually allows your printer to work). It should fix that problem.
Posted on Nov 20, 2008
Can I scan pictures to my computer?
Yes ... your all-in-one can print, copy and scan.
http://h10032.www1.hp.com/ctg/Manual/c00737535.pdf
Scan an image
You can start a scan from your computer or from the HP All-in-One.
This section explains how to scan from the control panel of the HP All-in-One only. To use the scan features, the HP All-in-One and computer must be connected and turned on. The HP Photosmart Software (Windows) or HP Photosmart Mac Software (Mac) must
also be installed and running on your computer prior to scanning.
● On a Windows computer, look for the HP Digital Imaging Monitor icon in the Windows system tray (at the lower right side of the screen, near the time) to verify the software is running.
Note Closing the HP Digital Imaging Monitor icon in the Windows system tray can cause the HP All-in-One to lose some of its scan functionality. If this happens, you can restore full functionality by restarting your computer or by starting the HP Photosmart Software.
● On a Mac, the software is always running.
Tip You can use the HP Photosmart Software (Windows) or HP Photosmart Mac Software (Mac) to scan images, including panorama images. Using this software, you can also edit, print, and even share your scanned images. For more information, see the onscreen Help that came with the HP All-in-One.
To save a scan to a memory card
1. Make sure your memory card is inserted into the appropriate slot on the HP All-in- One.
2. Load your original print side down in the right front corner of the glass.
3. Press the Scan Menu button.
4. Press to highlight Scan to Memory Card, and then press OK.
The HP All-in-One scans the image and saves the file to the memory card in the JPEG format.
To scan a photo and reprint it
1. Press Reprints.
2. When prompted, load your original photo print side down on the right front corner of the glass, and then do one of the following:
To reprint your original photo using the default print settings
➔ Press Print Photos.
To change print settings before reprinting your original photo
a. Press OK.
Basics Guide 13
HP All-in-One overview
b. Press or to highlight a paper size, and then press OK.
The paper size choices available vary depending on your country/region.
Note Depending on the paper size you choose, you might be prompted to choose a layout for the photos on your pages.
c. When the Fix Faded Original? prompt appears, highlight Yes or No as appropriate, and then press OK.
The HP All-in-One scans your original and shows a preview of the photo on the display.
d. Press OK to display the selection menu.
Tip If you want to print more than one copy of the selected photo, press to highlight Copies, and then press OK. Use the arrows to increase or decrease the number of copies.
If you want to edit the photo before printing, press to highlight Edit
Photo, and then press OK.
e. Press to highlight Done, and then press OK.
The Print Summary screen appears.
f. Press or to highlight one of the following options, and then press OK.
Print Options Enables you to manually specify the type of paper on which you are printing and whether you want to print a date and
time stamp on your photo.
By default, the Paper Type is set to Automatic and the
Date Stamp setting is set to Off. If you want, you can
change the defaults of these settings with the Set New
Defaults option.
Print Preview Displays a preview of what your printed page will look like. This enables you to verify your settings before printing and
wasting paper and ink on potential mistakes.
Print Now Prints your photo with the size and layout you selected.
To scan to a computer
1. Load your original print side down in the right front corner of the glass.
2. Press Scan Menu.
3. Press to highlight Scan to Computer, and then press OK.
4. If the HP All-in-One is connected to one or more computers on a network, do the following:
a. Press OK to select Select Computer.
A list of the computers connected to the HP All-in-One appears on the display.
Note The Select Computer menu might list computers with a USB
connection in addition to those connected through the network.
Jul 06, 2009 | HP Photosmart C5180 All-In-One InkJet...
Scanner and copier do not work
In your case, the scanner light is not lit during the scan or copy. If you print something from the pc, it would print just fine. Try to powercycle the printer, then try copying again. If it persist, scanner is defective but you may still use it to print from pc.
Mar 05, 2009 | HP PSC 2355 All-In-One InkJet Printer
MP 160 Cannon Printer Won't Scan
try checking if you have completely installed all the drivers for your printer. scanning and copying dont usually needs drivers because you can do that even without a computer. but scanning requires your scanner to be read by your pc. try checking for the scanner driver from the cd that came from your printer.
Feb 06, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Does printer need to be connected to a pc?
From the Brother website: The MFC-5440cn offers both a versatile flatbed and an automatic document feeder with faxing and copying that don’t require the use of a computer. Add to that the spectacular high-resolution printing and scanning with both a USB 2.0 full speed and an Ethernet interface and you have the perfect all-in-one for the Small Office/Home Office user to create and print professional color documents. You can even print borderless photos.
Hope this helps & please remember to rate my answer. Thanks.
Dec 27, 2008 | Brother MFC-5440CN All-In-One InkJet...
Stripes on scanned photo
Do copies come out the same? How about when you print? If you get the stripes whenever the printer prints from the computer or copies, then you probably have a bad ink cartridge. If you get it only when you make copies or scan, then check for dirt on the scan glass. Clean it anyway with some commercial glass cleaner. See if that works.
Dec 01, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Will print but not copy or scan
sir,
click this link to solve your problem
thanks
good luck
Nov 26, 2008 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
Scan light
HI-
Yes the bub for it needs replacement. please consult a service technician that is accredited by epson, you can check one on your area by going to www.epson.com site and look for a servicer.
Hope this helps
Sep 22, 2008 | Epson Stylus CX5400 All-In-One InkJet...
Dell No. 962 (All-In-One Printer)
you need to go to your printer settings and make sure it is set as the default printer for everything. Make sure it is also set as your default scanner. you may also try lightening the image with the lighter/darker setting on the machine. if this continues, you may want to see if a section of the light is burnt out. this wiill cause darkness on scan & copies but not printing from the c drive. Make sure the machine is lighting up completely when is scans or copies. If part of the lighting is burnt out it will be a fix or replace situation.
Mar 05, 2008 | Dell 962 Photo All-In-One InkJet Printer
Photos
Does this help? You obviously have to insert the media type into the media slot on the far right.(omoademola) Using the top control panel Printing tasks Scanning/Copying/Faxing tasks Troubleshooting
The top control panel lets you print an image from a photo card, scan a document or image, and copy a document or image with the press of a button.
Button/Light: Function: 1 Power : Turns the All-In-One on or off. 2 Copy: light Illuminates when Copy Mode is selected. 3 Mode: Changes the copy, scan, or photo card mode. 4 Scan: light Illuminates when Scan Mode is selected. 5 Photo Card: light Illuminates when Photo Card Mode is selected. 6 Rotate: Rotates the image 90 degrees. 7 LCD Panel: Number of Copies- this changes the copy count. Note: This feature is not active in Scan Mode. 8 Display: Shows copy, scan, and photo card selections. 9 Resize: Enlarges or reduces the size of the image. 10 Page Preview: Shows a preview of the output. 11 Select: Secures an option. 12 Menu: Provides options for image. 13 Arrow : Scrolls left, right, up, or down. 14 Stop/Clear: Cancels a print job or clears a selection. 15 Color Start: Initiates color copy, scan, or photo card output. 16 Black Start: Initiates black copy, scan, or photo card output.
Jan 10, 2008 | Lexmark P4350 All-In-One InkJet Printer
Scanning trouble PLEASE HELP!!!
1. does scanning from the pc looks good ?
2. printing photos from the pc looks good ?
3. does standalone copy (placing image on the scanner bed then pressing the COPY button on the printer) looks good ?
Dec 31, 2007 | Epson Stylus CX7800 All-In-One InkJet...
Kodak EASYSHARE 5100 All-In-One Printer Logo
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
