Start up There are to many program that auto start when I turn my computer on. What do I have to have on start up
    Problem Solver:
  • 11 Answers
Every PC is different, in that we all have different software loaded. But try this. Go to run, type msconfig hit ENTER. Go to startup. uncheck everything except the following. Soundman, all RUNDLL32.EXE commands, dumprep, and your antivirus program.
everything else can be unchecked. This does not delete the programs, it just keeps the boot components from loading on startup.
On reboot, you will get a window that tells you you are doing something (I forget) Just check the box at the bottom that says do not show this again and exit. otherwise this will hound you everytime you boot.
Posted on Aug 25, 2008
  • 60 Answers
The windows components are the only ones you need, these are the ones you need for the computer to boot properly. You can remove unnecesary start up items by typing msconfig on run, then click on start up tab, uncheck those unnecesary programs and reboot the computer.
I use my pc every day however it is very slow to start as it has to download the updates from microsoft auto updates,how can turn off these auto updates?
It is likely not the updates that are slowing down your computer, but rather an accumulation of programs and other information over time.
The best way to speed up your computer is to uninstall programs that you do not use anymore, and to use a program such as Ccleaner from http://www.piriform.com/ccleaner to remove unnecessary files and to clean the registry of your computer.
The updates are very important to maintain the security and stability of your computer. Disabling them will compromise the safety and reliability of your computer in the future.
Aug 23, 2013 | Computers & Internet
Breville you brew auto start not working
There is an error in the manual. Following the directions will, as you discovered, start brewing immediately.
To complete the auto-start programming, in step 8 of "Programming Auto-Start" you should NOT "press the PROGRAM button."
Instead, as soon as you have set the desired minute of the Start Time (step 7 in the manual), press the START / CANCEL button.
The LCD screen will then dim and display 'PROGRAM ON' to indicate that the Auto-Start feature has been successfully turned on.
Hope this helps.
- Owen.
Sep 13, 2012 | Breville You Brew - Single and Carafe...
Recently purchashed the Acer Aspire 5734Z and after installing the antivirus that came with the extra warranty I wasn't able to get into other programs (or it took about 10 min to do so, then it locked...
I offer to start with the obvious, have you tried starting the computer in "SAFE MODE" and tried un-installing then?
Sometimes running the install program (if you have it) offers options like re-install, modify, or remove.
You should mention which AV program you are talking about, and which version (Pro, Home, other).
If it's running slow, try turning off or reducing anti-virus program options, like scan priority, auto-scan, auto-update, web-page status checking.
Aug 26, 2010 | Acer Aspire 4930-6862 Laptop
Please guide the steps to install the norton antivirus 360 latest version one user
The easiest way, open your CD drive and with that open shut down your computer. Insert the Disk in the drive and close it then restart the computer. The installation program should start auto automatically as windows starts. The reason I said to shut down then reboot with the disk in the drive is to allow the program to scan your system before windows starts to speed up the install process. If you insert the Disk and close the drive while the computer is on it will auto start and scan the system anyway but it takes longer. Make sure you stop and uninstall any other anti virus programs or Anti Adware programs, such as Spy Bot, you may have running, the Adware programs only need to be closed.
Jul 22, 2010 | Symantec Norton 360 Version 3.0 Full...
My computer is running way to slow
You need to provide more details...
Anyway, adding RAM is the first and most effective method to speed up slow computer.
Then, run the disk cleanup and disk defragmenter to free up disk space and speed up program responsiveness.
Lastly, run a registry optimizer software, clean and defrag registry.
Dec 07, 2009 | Webroot Spy Sweeper (spysweeper) for PC
Help
a disc came with your new router. put the disc in your computer, it should auto start. follow the directions.
It will walk you through making the router work.
If the disc does not auto-start open it from my computer and run the set-up program.
Jun 28, 2009 | Network Computing Devices (NSH800S/A)...
Can't figure out how to turn on cable on Sony Trinitron TV
Setting Up the TV
After you have finished connecting your TV, you can use Auto Program to set up your
channels. During Auto Program, the TV will automatically search for available channels and
program receivable channels.
(Make sure CABLE is connected on coaxial and you are not using any other connections such as cable box, hdtv or satellite antenna)
1 Press to turn on the TV. The Initial Setup screen appears.
2 Press on the remote control or on the TV front panel to start Auto Program, or press
to exit.
To perform Auto Program again
Press .
2 Press g to highlight Channel Menu.
3 Press f to highlight Cable. Press to select.
4 Press F or f to highlight On or Off according to how you connected your TV. Press to
select.
5 Press f to highlight Auto Program. Press to search for channels.
6 After Auto Program finishes, press to exit.
To reset the TV to factory settings
Turn the TV on.
2 Hold down on the remote control.
3 Press and release the POWER button on the TV front panel. The TV will turn itself off,
then back on.
4 Release .
✍ When you start Auto Program wait until it is finished; otherwise it will skip over channels that are
available. Perform Auto Program again to program receivable channels.
✍ The Initial Setup screen appears each time you turn on the TV until you perform Auto Program.
Initial Setup
Auto Program [CH+]
[CH–]
First please connect
cable/antenna
Exit
Jan 17, 2009 | Sony FD Trinitron WEGA KV-24FS120 24" TV
How to enable auto Protect in Symantic anivirus 2006
want to turn on Auto-Protect permanently
1 Start Norton AntiVirus. If Norton AntiVirus is part of Norton SystemWorks or Norton Internet Security, then start that program. 2 Click Options. 3 In the left pane, click Auto-Protect. 4 In the right pane, check Enable Auto-Protect and Start Auto-Protect when Windows starts up (recommended). 5 Under "Select the duration," select Permanently from the drop-down menu. 6 Click OK. 7 Exit Norton AntiVirus. 8 Restart the computer.
Dec 30, 2008 | Symantec AntiVirus 10.0 with Groupware...
My Kodak Picture CD will not auto load
If your computer is operating with WINDOWS 95, WINDOWS 98, or WINDOWS NT 4.0 Systems, this CD contains software that automatically launches when you insert the CD. Getting Started:
Insert your Picture CD disc and wait for the software to load (it could take as long as 5 minutes, depending on your machine configuration, CD drive speed, and the number of images on the Picture CD).
Note: This loading process installs some Picture CD program files onto your hard drive. The KODAK Picture CD installer walks you through the steps. The final step may be to restart your computer. If so, be sure to restart to complete the installation.
After your computer has rebooted:
  1. Eject the Picture CD and re-insert it into the CD drive.
    The program should launch automatically.
  2. Click the magazine cover to turn to the Contents Page.
  3. Follow the links to read and do more with your digital photos.
If nothing happens after waiting for the Auto Play, you may need to manually start the Auto Play program. (Auto Play is a program that starts up the CD installation process the first time you use the CD.)
To manually start Auto Play:
  1. Right-click the My Computer icon.
  2. Select Properties from the pop-up menu.
  3. Click the Device Manager tab.
  4. Click the CD-ROM drive icon; click the "+" to view the CD-ROM drive information.
  5. Double-click the CD-ROM driver icon.
  6. Select Properties from the pop-up menu.
  7. Click Settings.
  8. Check Auto insert notification and click OK.
Note: This enables all CDs to automatically run any Auto Play software.
Sep 12, 2008 | Cameras
How can I disable the auto start feature
hi
say pls what run instrartup
i thnk your os missing some files
if u get my doc in startup
then
go type cmd in run then
sfc /purgecache then
sfc /scannow
put your xp cd in rom
then restatrt sys
Mar 23, 2008 | Individual AnyTime Organizer Deluxe 9.0...
Computers & Internet Logo
David Payne
David Payne
