Question about Frigidaire FRS3R5EMB Side by Side Refrigerator
FRS26F4CW1 Freezer not cold, Fridge fair
The fan condensor fan runs but the compressor hums for a few seconds and shuts off. This occurs about every 15 to 20 minutes.
Could it be the "start device"? Can This be replaced easily?
  • jpechin Aug 31, 2008
    Very similar but my problem happens about once a week.
  • 725 Answers
Yes you may need a relay or the compresser mybe locked up..let me know if you want help replaceing it
Posted on Aug 25, 2008
My kenmore 253 upright freezer/fridge is not cooling the fridge part correctly. It's cool but not cool enough to keep the food fresh. The freezer works well sometimes. And sometimes it seems that it's not...
Try this test. Set a window fan behind the fridge to constantly blow air across the lower coils at the floor. If the fridge works well after a while of this, then the lower fan on the fridge needs replaced. Sometimes though, after a while, the fan will finally start working again because the cycle has finally corrected itself with the test. Leave the window fan run on low for a few days before removing it. The hum you hear is the compressor moving the coolant and is supposed to do the hum sound. That's good. Now once the fridge is working, and you still have a good freezer section and not cool enough below in the fridge for you, there is a knob that sets the cool lower by opening flaps under the freezer to let more cold down to the fridge area. Set this knob to colder and the flaps will open more.
Nov 11, 2014 | Refrigerators
Fridge not staying cold and build up of ice on back piping
One of you fans is not running and causing the compressor to eventually making your compressor overheat and eventually shut off
Apr 14, 2013 | Refrigerators
Bottom freezer really hot to touch where door shuts
That is a very bad sign, but before you unplug it pull the machine out from the wall and check to see if it feels hot back there as well. Then remove the lower cover and find the condersor fan motor. Its the only fan back there. I'd willing to bet that the fan is not running. The purpose of the the fan is draw air across the compressor and blow it through the condensor therefore lowering the temperature on both parts. When its not working/ running, the heat from the compressor and the condensor is pass onward to the machine and the machine then acts as a heat sink.
May 22, 2012 | Whirlpool Refrigerators
Fridge not getting cold, ice maker not making ice
It sounds like it is doing some cooling. Check to see if your evaporator fan is running and there is not ice buildup on your evaporator (indicating a defrost issue, common on ge refrigerators, usually heater goes bad), you would either see ice on the back wall of freezer or if you take off the back wall you will see lots of frost. Also check if your condensor fan is running and clean the condensor. The compressor is running since it is getting down to 27 but if it is not being cooled it will shut down. Another common problem on the ge refrigerator is the main board contacts going bad and not running the compressor. If your compressor is running the whole time and none of the other conditions exist it sounds like you have a leak or restriction in the refrigerant or sealed system.
Dec 13, 2009 | GE Profile PSC25PSWSS Stainless Steel...
Our 10 year fridg seems to get very hot on the side...wondering what would cause this Model et18pkxaw00
The condensor coils run along the inner sides of the fridge . The heat you feel , is the heat being pulled out of the freezer which is the purpose of "freon" (to attract heat) . A freezer doesn't get cold , "freon" pulls the heat out , which is then cooled by the condensor fan ( fan which cools the compressor and coils ) . The more heat you feel , the colder the fridge should get ( to an extent ) . Also make sure the compressor fan is working .
Aug 19, 2009 | Whirlpool Refrigerators
Not keeping things cold
check to see if the compressor is running in a cycle. if the compressor is not cycling, you will need to replace the compressor and fan.
if the compressor is humming, it because of a faulty motor and relay(start device). replace the compressor unit in this case.
May 22, 2009 | Haier HRF10WNB Top Freezer Refrigerator
Cold fridge but not freezer
try DEFROSTING the fridge and restart it after COMPLETELY defrosting it.
May 05, 2008 | Fisher and Paykel Active Smart E522B...
Samsung Fridge Freezer (Freezer on top)Model SR-52NXA wont cool
Depends a bit on whether the compressor really is running, or if it's just humming because it's got power on the run coil, but not on the start coil.
Have a careful listen to the compressor. If it's making the trilling or gurgling sounds that go with a working compressor, then your problem is probably one of lost gas. Fixing this is not a do-it-yourself job.
If the compressor sounds like it's stalled, the problem may lie with the starter. Replacements are usually cheap enough for it to be worth fitting a new one just to see if it works.
A.
Feb 28, 2008 | Refrigerators
Trio: humming and temp in freezer rising
It sounds like the condensor fan motor is seizing up. This is the fan that cools the compressor down. Does the outside of the fridge feel excessively hot to touch? Can you feel air being circulated under the fridge or behind the fridge? It could also be a faulty defrost timer. Try to identify where the buzzing is coming from and if it is the condensor fan you can put a normal standing fan behind the fridge, blowing onto the compressor untill the repairman can get to you.
Oct 29, 2007 | Kenmore 24.8 cu. ft. TRIO Bottom Freezer...
Frigidaire FRS3R5EMB Side by Side Refrigerator Logo
175 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
