Question about Carrier XHB123D X/Y Series Heat/Cool Air Conditioner
Blower Turns off if ac unit comes on. No air coming through vents
I had a brown out so I turned off the air. The power came back on and I came home and turned on the air conditioning and the outside unit is working but the furnace doesn't blow the cold air into the house.. I have checked for frozen lines and there are none. I turn the air off and the fan to on and there is air coming out of the vents inside the house so I turned the air on and then the air quits coming out of the vents. Please help:)
  • miyoshi21 Aug 26, 2008
    Is the circuit board something a do it yourselfer could fix? I have never worked on a furnace/air conditioner but I do work on cars and other things around the house.
This only could 1--2 things, a bad circuit board fan relay or bad thermostat. To check for bad thermostat, take off the front cover to reveal the 4-wire terminial and jump the red-wire (power)-cool,(yellow -y or blue)--- green--fan white-(heat)..........red to yellow-or y=cool. Thank-you-very-much!
Posted on Aug 25, 2008
Cool air from home vents with central AC outdoor unit fan will not turn on. Inside home really loud when on!!
its look like blower problem , 1st check blower speed controller, check blower motor , check its ball bearing etc , its does not have any link to external unit .
Jun 15, 2014 | Goodman Heating & Cooling
I have a 2001 dodge grand caravan sport with duel air front and back and the blower comes on but only on hi and only blowes a small amount of air from the vents
I have an 07, and my blower went out too. Turns out that it's a common problem. I haven't fixed mine as of yet. But, when I did a search under " broken ac blower , dodge caravan 2007" , I got numerous hits and they all gave a similar fix. It was a $20 piece (a resistor) that goes out. It is located under the dash on the passenger side(behind the glovebox).
You could start here:
http://www.samarins.com/glossary/blower-motor-resistor.html
http://m.youtube.com/watch?v=FdD_m_UayN4
http://www.cargurus.com/Cars/Discussion-t4302_ds588226
Jan 04, 2014 | Covercraft 2001 Dodge Grand Caravan -...
I have a Trane XE1200 AC unit which emits a slight electrical burning smell when it turns on / cycles throughout the day. the smell is very similar to that of the furnace when it initially turns on during...
I would have a tech come out and check the voltage going into the fan relay and fan itself. The smell being as how it is coming through the vents in the house tells me that the problem has got to be at the blower or in the area at the blower fan which leads me to the possibilty that the smell could be the windings on the motor. This could be because the voltage may be to high. Good luck on repairs
Dave
Sep 01, 2009 | Heating & Cooling
1995 ford explorer
blower relay or resistor bad.also the AC and HEATER control switch could be bad.
Jun 29, 2009 | 1997 Ford Explorer AWD
Coleman evcon blower not working properly
My Coleman Evcon ac unit,heater and blower does not work.not even the outside condenser comes on.Any ideas on what is the problem?
Jun 22, 2009 | Coleman Heating & Cooling
Came home today and the AC will not come back on. The out side unit is working, but the blower inside will not come on. Also the light on the control board will not light up at all. Does anyone hav
turn off power to indoor unit feel the fan motor if hot and turns rough bad if hot and turns smoth then most likley capacitor if cold check 5 amp fuse on the board jump red stat wire to green if no fan relay bad if fan stat bad hope this helps
Jun 03, 2009 | Goodman CLJ30AR32 Air Conditioner
AC unit outside turns on but no air blows through the vents
The first problem sounds like the wiring is wrong up at the heating unit not turning on the blower fan in the heater when you call for cooling. Most typical is either something has chewed the wires or the wires have been stripped b something else. The AC not cooling your house can be either it is low on freon or the system is to small for your house. Also check your filter and make sure that it is not blocked and everything is clean with the filter
May 28, 2009 | Heating & Cooling
Air conditioner not working
the outside condesor unit is not coming on for a number of possible reasons. First check your breakers for a tripped breaker, even if they appear on, turn the ac breakers off and then turn them back on. if after this, turn on the thermostat, outside you should here the contact switch on the condensor unit humming. if still no power, check for any breaks on your wires going in from the house, still nothing give a call back
Jun 24, 2008 | Ruud UAKA030 Air Conditioner
Coleman Evron CH/CA unit won't blow the air through the vents
Relay for fan operation in the cooling mode may be bad and not bringing on the blower for the air.
May 22, 2008 | Heating & Cooling
My Blower Turns itself on when it is not supposed to.
If your indoor unit is located in the attic, you may be experiencing the result of a high temperature safety device (possibly too sensitive) that is responding to warm air drifting up the return air duct. The function of this device is to turn on the fan at a given set point and cool the unit back down. Have someone identify your limit rating and change the limit device with one rated the same or see if the maker of the unit has an upgrade/service bulletin on this fault.
May 03, 2008 | Ruud Handler Air Conditioner
Carrier XHB123D X/Y Series Heat/Cool Air Conditioner Logo
282 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
