Question about RCA F32450 32" TV
Screen flickered, burning smell no picture
Opened it up and found a cap or thermistor over by the fuse that was blown in half. Can I find a schematic for this model to find out what blew up?
  • threerailout Sep 17, 2008
    From the back, power cord goes to circuit board. There is a fuse and a small transformer. This is from the back on the right hand side. The part that blew is in between LB02 and RB02 just to the left of this x-former.
  • RCA Master
  • 5,138 Answers
What is TVs chassis location # where part is bad?
Posted on Sep 17, 2008
HI. My Yamaha D80 while playing gave a burned smell and than sound quit. Rest works. I opened rearcover and notice 3rd fuse in the back was blown. Changed it. Blew again. So I stopped fidling around.
If the fuse blows and a smell of burning is present then its obvious there i a fault somewhere ahead of the fuse, the fuse is a protection device.
Oct 08, 2016 | Yamaha Cars & Trucks
TV wont power on
Device is a thermistor (thermal resistor)
thermistor and a vatistor control the on
time of the degausser Sams Photofacts has the
Some public Libraries stock photofact schematics you
may be able to go to al local library and get the part number
or the specs as to whether it is ptc or ntc etc to get a match
or online here
Dec 28, 2007 | Zenith B27A11Z 27" TV
A power surge zapped my TV, I turned it back on, it tried to bring up the picture but shut off again. A green light keeps blinking.
if a power surge shut down the unit than a circuit, capacitor or fuse is blown and or burnt and you wont smell that most of the time and since it does have power fuse wasnt blown so a circuit -diode-capacitor is fried somewhere problem is common for an electricial damaged tv but to diagnose an electronic tech would need to tear it apart
Aug 26, 2015 | Sharp Aquos Televison & Video
Model 110 73932101 kenmore elite. Blew the circuit board replaced it and checked the relays. Wont heat, found the thermal fuse is blown. Checked the high limit thermostat and the thermistor. Thermistor...
there is thermal fuse, Hi limit, and thermistor. the thermistor should have continuity at room temp I don't know what resistence(ohms) it should have. Most units I have seen provide a schematic and trouble shooting guide taped under the control panel for service personal.
Apr 15, 2011 | Kenmore Dryers
Norcent plasma had smell of electrical burning and
get real bright flashlight shin close to the screen in dark roomand try to push the menu button if its the bulb you'll see some picture with flash light shining that shows your backlight is out
Feb 15, 2010 | Norcent Technologies PT-4291HD 42 in....
Found fuse burned-out. Have not replaced fused but does burn-smell can be from the fuse and non others ?
Typically fuses are made from a specific material which will burn in half just above the rated current. The material is enclosed in either a glass tube, ceramic tube or epoxy tube. I have seen many fuses blow and blown and never smelled anything. They are designed to go quickly and not give off anything. More likely you are smelling the burned component. Could be a bad electrolytic capacitor or more likely a bad output transistor. Check all the capacitors (the ones that I am talking about look like little cans) to see if any are bulging or have exploded or have liquid ozing out of them. If nothing is visible I would check to see if any output transistors are shorted with a DMM. It will be one or the other. If you need more specifics on how to do the testing or any questions let me know.
hardrocko
Thank you for using FixYa.
Feb 12, 2010 | Marshall MG100HDFX 100-Watt Amplifier Head
Flat tv, sound but no picture. have tried
I had one that had a black screen and fixed the problem by repairing the inverter. When I opened the unit I looked at the capacitors on the inverter board and found them swollen. I looked at the bottom of the board and found that the fuse had opened up. The caps were a cheap quality low temp variety 150uF at 25V I replaced them with 330uF 25 volt 105C caps. I then replaced the 2.5A surface mount fuse with an axial 2.5A pico fuse and the TV worked beautifully.
Jun 12, 2009 | Philips 15PF5120 15 in. LCD Television
No picture
Mar 26, 2009 | Philips 15PF5120 15 in. LCD Television
Orion FTDV 2004 Dead Set
Question, when I clicked on this I clicked on a problem for a Sony KV27S10 but your text say's Orion, is it a Sony or a Orion?
Aug 18, 2007 | Sony KV-27S10 27" TV
AKAI FIX
My set had the same issue with the picture and burning smell. On my set, I just removed the cap and the set works great without it.
Aug 08, 2007 | Akai PT4799HD Rear Projection Television
RCA F32450 32" TV Logo
50 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
