Question about Maytag Neptune FAV6800AW Top Load Washer
Machine dosent seem to drain model #lat8840b maytag
Hello there,my name is pete i h ave a maytag clothes washer that dosent drain the water , then spins and drains a little water.. i had it tonight end the cycle with water still in the drum? The load was balanced correctly please help me pete grossmann
  • rdial54
    rdial54 May 11, 2010
    does anyone have any experience with the maytag washer and it not finishing the sppin cycle?
  • Anonymous Mar 25, 2014
    When done with a load there is a little bit of water still in the machine
You might want to pull the front panel and look at the pump assembly. You may find debris in the pump and you will be back in business.
Worked for me... Good Luck.
Posted on Sep 04, 2008
Clothes inbetween the drum and outer wall hold up normal spin cycle or uneven load kicking out the switch the safe guards any damage to machine as far as uneven loads
My machine had a pair of kids underware stopping the water from entering the draij pump,you may have clothes inbetween the drum and outer wall stopping the normal rotation
Mayta mav275aw washer does not get all of the water out of clothes
The drain pump on those are fairly common to have problems...
It could be that the washer is not getting all the water out of the tub so the close stay wet. here's a link to the part:
Drain Pump 35 6780
It could also be that the tub is not spinning fast enough to squeeze water out of the clothes... Does it seem to bee spinning well?
Jun 11, 2014 | Maytag PAV2300 Top Load Washer
Hello I have a Maytag Washer Model A512 The machine goes through a regular cycle OK - However, it DOES drains the water out during the rinse cycle, but does NOT drain the water out during the spin...
The timer will always advance to the next program if the machine does not fully drain. There is ALWAYS a spin when draining the water out, there is only one pump and one motor. The waterlogged laundry maybe telling the timer that there is still water in the tub. Put the machine on "Spin" and cheat the lid switch into thinking that the lid is closed. Use a clothes peg or wide ended screwdriver and see if there really is a spin....
Apr 07, 2017 | Maytag Neptune MAH5500B Front Load Washer
Where is the drain pump (and how do you access it on the Neptune MAH6700 front load washer?
i have maytag neptune mah6700 and dosent rince good in the end of each wash the cloths steell to mutch water in the cloths dosent rince it good i thing the speed of the spin not that strong and the motor its very good but i thing is someone played with the fron the code and i dont have the manual to check those code
Oct 03, 2010 | Maytag MAH6700AWW Neptune Front-Load...
Dosent squeez the water
Here is a tip that I wrote that will help you with your dishwasher2_bing.gif not draining problem...
Dishwasher2_bing.gif Problems - Water will not drain out
http://www.fixya.com/support/r4078724-dishwasher_problems_water_will_not_drain
heatman101
Jun 05, 2010 | Maytag Neptune MAH5500B Front Load Washer
LAT9604AAE No agitation but drum spins and drains water
cold possibly be just the agaitor but odds are u need a transmisson not worth repair
May 20, 2009 | Maytag PAV2300 Top Load Washer
My maytag neptune washer will not perform the final spin cycle. Therefore the clothes are still wet. Any solutions
Maytag washer parts, GE washer parts, and other brand names on the market are all designed to work interdependently with each other. This system starts to break down if even one part begins to encounter difficulty. Your washer's spin cycle flings a large amount of water out of the clothes, but if the water can't drain, the clothes will soak it all back up, defeating the purpose of the cycle. Excessively wet clothes after the spin cycle may not be caused by faulty washer parts, but rather a blocked drain is a very good bet. Check the drain line for a blockage and try again. If your hose is kinked or bent, this can also cause a drainage problem. The failure of one simple part creates a larger problem for all the washer parts. What can cause a blockage? A number of items; paper left in the pockets of your jeans, coins or other debris, even socks. Check your hoses, and make sure your laundry has empty pockets for future loads.
Feb 18, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag MAF1200AAW
WASHER MAGIC is the revolutionary product specifically formulated to safely and effectively clean the family washing machine. Top loading machine use whole bottle. Front loading use 1/2 bottle. You may rub Washer Magic on with a rag to eliminate odors.
Why Use WASHER MAGIC? Every time you wash your clothes, hard water and detergents causes lime scale and rust to build up inside the tub, pump and hoses. This build-up reduces the ability of your washing machine to perform. Mineral build-up acts as an abrasive increasing the wear on your clothes. The result: your clothes are not as clean as they could be and wear out sooner.
If you are unhappy with the way your clothes comes out of the wash, then WASHER MAGIC may be the solution you have been looking for. Only WASHER MAGIC can restore the family washing machine to the way it performed when it was new. Use once a month for optimal washer performance and to keep control of trouble causing build-up.
Aug 04, 2008 | Washing Machines
Maytag Washer Not Completely Rinsing
If your washer has an extra rinse button try pushing it. My Maytag refuses to wash unless that button is pushed, so in your case it may not be completing the rinse cycle correctly.
Just a suggestion.
Jan 03, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Water in Outer Tub
My washer does this too and I called Maytag and was told it was normal. I don't like that answer, though.
Mar 06, 2007 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune FAV6800AW Top Load Washer Logo
207 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
