Remote Code I have a universal remote but the code sheet is missing, and i'm trying to connect it to a philip tv and the code search isn't working, the remote i have is a pm335, thx
  • lizzypj Aug 25, 2008
    Trying to set up Accessory agents universal 4 in 1 remote control to control Matsui 14v1r I have tried numerous codes and auto set up and although I can get the controller to switch on/off and control volume and change channels, I am unable to access the on screen menu which I need to tune in the channels properly. Any ideas?
  • Anonymous Apr 08, 2009
    I cant get the code for my Daenyx dvd player, its not on the list for my RCA 4 in 1 universal remote, any ideas!
I have a daenyx dvd player and a nexxtech remote that i need a code for???
Posted on Aug 25, 2008
Does a philips srp3013 universal remote work on thorn 55thl3ds1 tv if so wots the code please
You can use code search to find something that can handle some or all functions of your Thorn TV. If a search through all codes stored in the remote fails, you may have to try a different universal remote. All universal remotes do not contain all possible codes.
Nov 03, 2016 | Philips Televison & Video
How do I get a code for the Philips Universal Remote to work on a Curtis LED 1930A TV
You should be able to use the code search feature of your Philips remote to find a suitable code for your Curtis TV. If a search through all codes stored in the remote is unsuccessful, you may have to try another universal remote.
Mar 11, 2015 | Philips Televison & Video
Need the code for my philips universal remote and my insignia tv
You can find many universal remote control codes at InsigniaProducts.com, just search for your TV model number and click on the Support Tab.
Feb 20, 2010 | Philips Magnavox Learning Universal Remote
Philips universal code search for older electrohome tv
Me thinks IF you tried the 'code search' function and none worked, I sincerely doubt if any other 'codes' will marry your Philips Remote to your electrohome TV.
This is because your "SEARCH" effort already went through ALL of the possible codes THAT Philips Remote knows and can deliver. It is also possible that a different MODEL of Philips Remote MAY stumble on codes that DO work!
IF you have a 'original' remote, SOME NEWER remotes can LEARN the proper codes from the original remote! BUT you NEED that original remote to send the desired IR data pulses to the smart student remote.
And GOD ~ those TV's are SO OLD, did they even HAVE remotes??
Anthony
Jan 30, 2018 | Philips Universal PH301S Remote Control
Philips universal remote - tv codes for Sylvania
Several people in the on-line forums suggested inputting the brand search codes for Philips and Magnavox sets -- but it didn't work for me. Someone else suggested that Funai Corp (China) now makes some Sylvania sets, and their rep said that universal remotes don't work for their products. My Philips Universal Remote says to enter "0" for the brand search code, and that will instruct it search for all the codes installed in it. But there are approximately 300, so be very patient. And it didn't work for me anyway. . . but maybe it will for you.
If you do find an answer/solution, pl post it, OK? Thanks.
Donna
Jan 13, 2009 | Sylvania W4913TA 13" TV
Philips universal remote codes for symphonics tv
try to ask a copy from the store where you bought the unit. or search in the internet. send me the model and ill help you search in the internet.
Dec 10, 2008 | Universal Remote Control Remote Control
Need codes for a philips universal remote code sheet
http://www.remotecodelist.com/remotes/magnavox/Philips-Magnavox_PM525S.pdf
This is the user's manual for a Phillips remote control. There is a list of codes in it. They should be rather universal. There's also instructions as to how to program it. I believe that there is a way to program it without using the codes.
Programming with Code Search
1. Manually turn on the device (TV, VCR, etc.) to be controlled.
2. Press and hold Code Search button until the red indicator stays on. Release the Code Search button.
3. Press and release the desired mode button (TV, VCR, etc.). The red indicator blink, then stays lit.
4. Press the Channel Up button repeatedly (up to 300 times) until the device could be controlled changes channel. The red indicator blinks, then stays lit. If you accidentally overshoot the code required, press the Channel Down button to backtrack through the library until the device changes channel. Pressing Channel Up changes direction to forward again. Press and release the Mute button to install the code.
Hope this helps :)
Jun 21, 2008 | Philips Magnavox Learning Universal Remote
My remote dont work
Try this website for the codes
http://www.universal-remote.net/philipsmagnavox.html
May 22, 2008 | Philips 5-Device Universal Learning Remote...
Manually turn on the device you want to control
1. press and hold the CODE SEARCH button til the light stays on release the code search button
2. Press and quickly release the desired button ( TV, DVD, etc ) the red light blinks off once
3. Press the CHANNEL UP button repeatedly ( up to 300 times ) til the device changes channel and stop
(the red light will blink off after each time the channel up button is pressed )
4 Press the MUTE button to set the code
hope this helps
Nov 23, 2007 | Televison & Video
One more 'lost code list' person. I have a philips SRU 2040/17 universal remote and a sanyo tv. 'code seach' doesnt work, i need the actual 3 or 4 digit code. HELP! my kid wants to watch cartoons and i cant turn the tv from video back to cable.
Aug 22, 2007 | Philips PM3S Remote Control
Televison & Video Logo
997 people viewed this question
Top Televison & Video Experts
