SOURCE: Bosch dishwasher SHU9922UC
Sounds like you already know how to fix it. The inlet valve is only held closed by water pressure...if you have low water pressure it could be causing this. Its more likely just a bad fill valve though. The water inlet valve is accessed by removinf the lower kickplate and the sheild behind that. Then all you have to do is remove the water line from the valve, remove the 2 screws holding it and pull it out far enough to disconnect the 2(possibly 3) wires and the fill hose. Make sure to mark where your wires go, if you hook it up wrong it could continue to fill and overflow. Hope this helps!
SOURCE: Bosch Dishwasher, SHU 5300 - Cycle stuck on 2H cycle
yes it needs a new control and its pretty easy to replace..
SOURCE: BOSCH dishwasher SHU5302UC12 water will not fill
was the safty tab on the inside of the units water receiver removed?
SOURCE: Bosch SHU3036UC/U11 dishwasher does not stop filling with water
It sounds as if the main program board has developed a fault - as it should come to a complete stop. The fact it kept the water valve open with the door open is a serious fault- so I would have it checked before using it again.
Most machines have a water-stop feature - so if it develops a leak - it will shut off the water. This clearly didn't happen.
SOURCE: My Bosch dishwasher detergent dispenser lid will n...
Contact the authorized BOSCH service provider.
