Question about RCA 3-Device Universal Remote with Dedicated DVD Menu Key
Remote the sequence needed to set remote
    Champion:
  • 226 Answers
Youll need the code booklet for it. must search for that.
Posted on Sep 25, 2008
How to get CC on Harmony 650
You can do this by setting up a sequence on your Harmony remote. A sequence allows your Harmony remote to send up to 5 commands with one button press.
To create a sequence, follow these steps:
Click Customize Buttons beside an Activity
Click Add Sequence
Give the Sequence a name
Select the device(s) and commands that will be included in the sequence
Click Add another Sequence to append additional sequences to the list
Click Done
Sequence will now appear as a selectable item in each drop down menu in the Device column
If Sequence has been selected in the Device column, all the Sequences that have been created will appear in the Command column
Select a Sequence
Click Done
Click Update Remote to download these changes into your remote
Sep 08, 2017 | Televison & Video
Mts mode for preset manual trans auto start function enable,does not allow car to start, instead the park light blinks seven times and give an error tone ... Thank you
There is a sequence necessary to set the Viper every time you exit the vehicle: park the vehicle, put in neutral, place foot on brake, set parking brake,remove foot from brake, remote start vehicle with remote, remove key (vehicle should remain running), exit vehicle and close door, arm the alarm with remote (vehicle should shut down). The system is now set for MTS remote start. Test the system by remote starting the vehicle now (it should remote start at this point). If you open any door after the MTS remote start has been set, you will have to do the programming sequence again.This is a safety feature because something may have changed, i.e. parking brake released when the door was opened. You have to do this sequence each time you park the vehicle if you intend to use the remote start feature.
If this does not work, there may be an issue with the installation, i.e., the door trigger connection. Using dome supervision as a door trigger won't work because during the arming portion of the above mention programming sequence(when the vehicle shuts down), the interior lights will illuminate and the Viper will read it as a door opening. So, actual door trigger wires must be used.
Oct 23, 2010 | 5900 SST 2-Way Security System / Remote...
Panasonic DVD S1
Please follow the steps : To change the player region code
1. Be sure players drive is empty (nodISC)
2. Enter following key sequence using remote control:
Enter, 6, >=10, <<, 00F2, Audio, 8, * requested region code here (1-8) *, Subtitle, 1
3. Player will reset and requested region code will be set.
- For example to set region code to 3 press: "Enter, 6, >=10, <<, 00F2, Audio, 8, 3, Subtitle, 1"
To set the player to RCE proof region free
Enter, 6, >=10, <<, 00F2, Audio, 8, 1, Subtitle, 4
3. Player will reset and set to "region-free" and "RCE-free" mode
To restore players factory region code
Enter, 6, >=10, <<, 00F2, Audio, 8, 9, Subtitle, 1
3. Player will reset and set to factory region code
Regards, Jay__mlkp
Jun 08, 2010 | Panasonic SA-HE70K
Can I reprogram channel 783 to channel 003
Well unfortunately, the Harmony 520 doesnt support favorite channels (I dont think). However, you can certainly set this up as a sequence.
1. In the software, click 'Customize Buttons' next to the icon for your Watch TV Activity.
2. Click 'Add Sequence'
3. Name your sequence 'CBS' and add the commands '7', '8', and '3'.
4. Save the sequence.
5. In the button customization for the number '3' button (or any button you want), select 'Sequence' as the deivce name and 'CBS'.
4. Save, and update the remote.
If you used the '3' button, then now in your Watch TV Activity, is you press the '3' button the remote will send 783.
Hope that helps:)
Jan 24, 2010 | Logitech Harmony 550 Remote Control
L need a multi region code for a panasonic dmr-ez47v.
Panasonic DMRs cannot be unlocked for muliti region simply by entering a code form the normal remote or front panle controls.
Panasonic machines require a special remote control in order to make them multi region. Panasonic dealers will unlock your machine for you but will charge you - this is expensive.
Alternatively, if you search eBay you will find devices that will unlock your machine that can be purchased or "rented", for considerably less than a dealer will charge.
Nov 07, 2009 | Panasonic DMR-EZ47V DVD Recorder/VCR
Need region free code for Panasonic DMR-ES46V DVD/ Vcr Recorder
Regards, Jay__jn89
Oct 18, 2009 | Panasonic DMR-ES46VS DVD Recorder/VCR
Change DVD Region Code
Regards, Jay__okj4
Oct 15, 2009 | Panasonic DMP-BD60K Blu-ray/DVD Player
How to program favorite channels in the harmony 520 remote by logitech
The Harmony 520 remote does not support Favorite Channels.
However, you can set this up by creating a sequence to send the number commands for a specific channel, then map the sequence to a button. See the following link for a walk through of how to do that.
http://logitech-en-amr.custhelp.com/cgi-bin/logitech_en_amr.cfg/php/enduser/std_adp.php?p_faqid=9185
The article is for a Harmony 1000, but it is the same process for any remote that supports sequences.
Sep 12, 2009 | Logitech Harmony 520 LCD Remote Control
Setting a universal remote
http://www.remotecentral.com/features/remotes.htm
follow linjk above(its to let you explore it yourself to prevent future(if theres any :) ) and also read the older model manual please :)
Oct 21, 2008 | Uniden Cordless Phone
Samsung TXN2726 Televison Remote
hiya sounds like the remote has de-registerd it self with the telly. all you need to do is find out the infered codes for that telly and do the [set] - [TV]combo with the numbers after.
Oct 02, 2007 | RCA 36V550T 36" TV
RCA 3-Device Universal Remote with Dedicated DVD Menu Key Logo
15 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
